Is it possible to run an Aquaero without the use of Aquasuite? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 04-07-2019, 04:18 AM - Thread Starter
trawetSluaP's Avatar
Rep: 0
Hi all!
I'm using an Aquaero XT 6.
Currently have it controlling all fans in my case via the software.
I've been informed that saving the settings then unplugging the Aquaero from motherboard should cause the unit to run independently, however, I tried this and the unit reverted to default settings.
When booting the fans run at 100%, then when my PC has loaded into Windows and the software starts they run at their controlled level, however, if I unplug the Aquaero they just run at full speed.
How do I get the Aquaero to save the setting then run independently of the software?
Thanks,
Paul
Case: Enthoo Elite, CPU: i9-7900X Motherboard: Rampage VI Extreme
RAM: Dominator Platinum 32GB, GPU: EVGA 1080 Ti FTW3
Storage: 960 Pro 512GB, 2 x 840 Evo 250GB, PSU: EVGA SuperNOVA 1200 P2
Monitor PG279Q, MX27AQ
Custom Watercooling Loop + Aquaero 6 XT
trawetSluaP is offline
post #2 of 9 (permalink) Old 04-07-2019, 06:53 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by trawetSluaP View Post
Hi all!
Thanks,
Paul
I think you have to save your settings in profile 1. When I boot my PC, my fans spin based on watertemps. So usually at the lowest setting unless the water is still warm (a reboot directly after playing a game for example). So I guess they work as expected without connecting to the software during that time.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #3 of 9 (permalink) Old 04-07-2019, 06:57 AM - Thread Starter
Rep: 0
I'll give it a try.
My aim is to have the setting saved in the Aquaero unit so the software is not needed.
Is this possible without putting all of the setting onto the unit itself?
post #4 of 9 (permalink) Old 04-07-2019, 07:30 AM
NewUser16's Avatar
Rep: 48 (Unique: 32)
You can no problem and lot of people do. Aquaero will preserve your desire setting but there are some futures that you won't be able to access without Aquasuite.
NewUser16 is offline
post #5 of 9 (permalink) Old 04-07-2019, 07:38 AM - Thread Starter
Rep: 0
That's my issue - when I save the settings then unplug the cable that connects the Aquaero 6 to the motherboard it loses the settings and reverts to defaults
post #6 of 9 (permalink) Old 04-07-2019, 08:42 AM
skupples's Avatar
Rep: 588 (Unique: 329)
you may get more answers here
https://www.overclock.net/forum/61-w...hlight=aquaero
do you click the little save button? I haven't messed with mine in ages, but I remember being able to program in the settings... however, I think any cut in PSU power wipes due to no onboard battery.
I could also be remembering programming other aquasuite devices, cuz that's how you do that too. connect, program, sync, disconnect.
skupples is offline
post #7 of 9 (permalink) Old 04-07-2019, 02:23 PM
drewafx's Avatar
Rep: 5 (Unique: 5)
As long as you use hardware sensors (directly connected to aquaero), you should be able to disconnect USB w/o problems.
The only way for aquaero to use software sensor (any CPU, GPU, Motherboard temp) is via USB cable with Aquabus service running.
Aquasuite program doesn't have to be open, though.
drewafx is offline
post #8 of 9 (permalink) Old 04-08-2019, 01:21 AM
Rep: 29 (Unique: 27)
Yes you certainly can, I am on a V5 and it works fine with the USB disconnected.
You MUST press the little disk icon to save it to the controller though.
It’s not exactly obvious where that is, but I recall it’s on the header graphic of the Named Aquaero section of the side menu, and its only apparent if you have made an edit too.
Stu-Crossfire is offline
post #9 of 9 (permalink) Old 04-15-2019, 07:19 AM
Ashcroft's Avatar
Rep: 87 (Unique: 70)
It certainly is possible to use the Aquaero without Aquasuite or even any connection to the PC. That is the primary benefit of the whole system.
As has been said above though to do that you have to use physical sensors that are connected to the Aquaero to define the fan and pump controls rather than software based controls.
Eg. Use a hardware temp sensor as the data source for a fan controller rather than CPU core temp which is of course software based.
Hardware sensors give a better result anyway. I have found that using air and water delta based on two hardware sensors defining a virtual sensor which is used as the data source for all fan controls.
This way the fan and/or pump controls work just fine even if the system is bluescreened or frozen etc.
Ashcroft is offline
