Leaking radiator, I'm an idiot, fix possible? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 04-09-2019, 05:45 PM - Thread Starter
Wanting to add some cooling capacity and in the process of rearranging stuff tightened down a fan screw too much I guess. EKWB PE 360 rad is leaking where one of the fan screws goes in, this thing has been fine for 2 years, no doubt I was the cause . Guess I can just accept it and buy a new radiator, but what are my options to repair it? I'll search endlessly all night I am sure...
Quote:I'm gonna throw in my 2 cents. Not because I'm an expert but because I have a keyboard.
bfromcolo is offline
post #2 of 7 (permalink) Old 04-09-2019, 05:49 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
If you can see the spot on the tube where is punctured, you can generally repair it with a butane torch and solder like it used to be done on car radiators.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #3 of 7 (permalink) Old 04-09-2019, 06:05 PM
Invalid Media
J7SC's Avatar
Rep: 27 (Unique: 13)
...as an alternative to bringing it to an automotive rad shop for soldering, I have used this stuff before to fix (automotive) rads, fuel lines (!) etc etc. After cleaning the affected area, use sparingly and build up in layers, letting it touch dry in between applications.
J7SC is offline
post #4 of 7 (permalink) Old 04-09-2019, 06:59 PM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
Rad is inside a shell remove and repair if you want too flux and solder...
Otherwise trash it and buy a new.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 7 (permalink) Old 04-09-2019, 08:16 PM
Rep: 455 (Unique: 387)
I'd try it on a car because you can open the hood, spray a hose around in there and it'll be fine, things are a bit different inside a PC
Darren9 is offline
post #6 of 7 (permalink) Old 04-09-2019, 09:24 PM
white owl's Avatar
Rep: 136 (Unique: 103)
I've fixed rads for trucks and stuff, if youc an solder it's pretty easy but you'll have to cut out some fins.
Find the exact spot in the tube, strip the fins away, burn/grind/brush off the paint, heat, tin, heat, solder, rinse, use.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #7 of 7 (permalink) Old 04-20-2019, 11:30 AM
yevonxxx's Avatar
Rep: 0
i've made my car rad used for pc being repared by radiator engineer shop several times during years,
it cost about 60 euro,if you want to risk a cheaper solution there are some glues out there but nothing last forever like a soldiering work.
Bianco&Nero
(0 items)
yevonxxx is offline
