Lian Li o11 Dynamic, 2xLS360 rad + 3 fans layout. - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 04-10-2019, 05:44 PM - Thread Starter
thomasck's Avatar
Rep: 8 (Unique: 8)
Hi all, I'm about to assemble my 1st loop cpu/gpu soft tubing, in the case above.
My question is about layout. Assuming they will fit, what would best? All 9 fans will be corsair sp120. Why? Just cause I have them lain around.
Top and side exhaust and 3 fans bottom intake
Top exhaust and bottom intake with 3 fans side intake
Bottom and side intake with 3 fans top exhaust
Top and bottom exhaust with side intake
Top and bottom intake with 3 fans side exhaust
Any other suitable suggestions?
Many thanks
EDIT, it's kinda finished. I didn't like the "foggy" finish of the glass of the case but I won't do anything else. Perhaps in the future I'll flip the fans of the rad, and add again a drain valve.
Specs are,
Rainjitek D5 pump
2xLS360
Bykski 10/16 fittings
Bykski GPU and CPU block
Corsair SP120
Sent from my HTC U11 using Tapatalk
It's done. Happy with temperatures, but not with the look, yet.
PCDEBAIANO
(7 items)
Ryzen 3900X
Taichi X370
AMD Radeon VII
HyperX Predator 4000
3x360mm
Lian Li o11d
HANNspree HG324
thomasck is offline
post #2 of 24 (permalink) Old 04-10-2019, 06:17 PM
sgtgates's Avatar
Rep: 57 (Unique: 52)
First off Welcome to OCN! Hope you find what you need here as you go.
Usually your #2 option "Top exhaust and bottom intake with 3 fans side intake" will yield best cpu temps and overall case temps. What gear are you pushing in this 011? I would put a rad on top and on side intake. Leave bottom for the extra 3 fans by their lonesome.
Thanks,
-SGT
SgtGates
sgtgates is offline
post #3 of 24 (permalink) Old 04-11-2019, 04:18 AM - Thread Starter
thomasck's Avatar
Rep: 8 (Unique: 8)
Hi sgtgates, many thanks.
I'll be cooling a 1800x and a Vega 7.
I really don't know what to think, option 2 seems fine but also bottom and side intake + top exhaust looks fine. I think that in the end of the day it won't chage much as long as I have one rad in one rad out and 3 fans exhaust, or, both rads out and 3 fans exhaust no matter the layout.
Your suggestion looks in the counter hand of the air operation, as hot air goes up, the 3 fans will need to pull the hot air through the case to be exhausted.
I'll keep my eye on the next answers, if any , as amazon delayed the delivery of the water and without it I cannot to anything.
PCDEBAIANO
(7 items)
Ryzen 3900X
Taichi X370
AMD Radeon VII
3x360mm
Lian Li o11d
HANNspree HG324
thomasck is offline
post #4 of 24 (permalink) Old 04-11-2019, 04:58 AM
News Fiend
ryan92084's Avatar
I never tried it with a rad in the bottom but I did the following with the sig rig.
  1. Rad side in, Rad top in, Bottom fans out
  2. Rad side in, Rad top in, Bottom fans in
  3. Rad side in, Rad top out, Bottom fans in
  4. Rad side in, Rad top out, Bottom fans out
1 came out tops with 3 close behind (1-2c water delta) and 2 was a stinker (canceled the test early). Afterwards I also used foam on the side and top on setup 1 to make sure they weren't recirculating any air but the benefits were negligible if any for my use case.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #5 of 24 (permalink) Old 04-11-2019, 05:41 AM - Thread Starter
thomasck's Avatar
Rep: 8 (Unique: 8)
Hi Ryan, thanks for your answer.
Rad side in, Rad top in, Bottom fans out - that way the hot air needs to travel all the way down, don't know if is the best
Rad side in, Rad top in, Bottom fans in - this will make a hot box
Rad side in, Rad top out, Bottom fans in - that is one of reliable option, most likely to go with
Rad side in, Rad top out, Bottom fans out - same as option 01, hot air needs to travel down to get exausted
I'm top considering,
Rad top in, rad bottom in, fan side out
Rad top out, bottom rad in, side fan out
And last,
Rad top out, bottom fan in, side rad out
PCDEBAIANO
(7 items)
Ryzen 3900X
Taichi X370
AMD Radeon VII
3x360mm
Lian Li o11d
HANNspree HG324
thomasck is offline
post #6 of 24 (permalink) Old 04-11-2019, 06:03 AM
News Fiend
ryan92084's Avatar
Intake on rads is almost always better and virtually any amount of airflow from a fan will overcome the effect of heat rising so you can just ignore that. Test 2 was just a why not scenario the results were expected.
If you do try side fan out I would definitely recommend using foam between the rad and the panel to stop recirculation or you might end up hot boxing the side chamber.
Also keep in mind the bottom cutouts are more restrictive than the side or the top so that may change things from my test. Oh and the stock filters are crap.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #7 of 24 (permalink) Old 04-11-2019, 06:30 AM - Thread Starter
thomasck's Avatar
Rep: 8 (Unique: 8)
I didn't understand the foam thingy, perhaps cause I didn't try to place anything yet. I still waiting for one more package :/. Did you mean foam in the back panel like creating another chamber just for the rad?
Yeah, as soon as I saw the filters I thought straight "that's a filter for insects, not for dust", lol.
PCDEBAIANO
(7 items)
Ryzen 3900X
Taichi X370
AMD Radeon VII
3x360mm
Lian Li o11d
HANNspree HG324
thomasck is offline
post #8 of 24 (permalink) Old 04-12-2019, 04:36 AM
News Fiend
ryan92084's Avatar
Basically yes, you'd want to make a duct of sorts to ensure the side exhaust air would be going straight through the grate instead of lingering.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #9 of 24 (permalink) Old 04-12-2019, 08:02 AM - Thread Starter
thomasck's Avatar
Rep: 8 (Unique: 8)
Yep, got it! Gonna think about a good way to do it. Perhaps just trimmed part of the foam the comes secured in. Cheers.
PCDEBAIANO
(7 items)
Ryzen 3900X
Taichi X370
AMD Radeon VII
3x360mm
Lian Li o11d
HANNspree HG324
thomasck is offline
post #10 of 24 (permalink) Old 04-12-2019, 08:57 AM
Rep: 0
I have 2700x and 2080ti, i'm cooling the CPU with an AIO and from different configurations what works for me was this:
Top 3 Noctua NFF12 + rad as intake (CPU at 40-45c under load, no OC).
Bottom 3 Noctua NFF12 as intake for the GPU (2080ti Gaming OC, stock cooler) temp are bad 75-80 under load, i'm currently looking at an AIO for the GPU.
and 3 Corsair 120 that came with the H150i pro as exhaust on the side.
The noctua fans are all on fixed speed of about 20% in the bios for silence and the exhaust corsair fans can ramp up as the GPU temp i rising but not too high.
not the same case but i thought it might help you see the GPU temps.
CPU:3900x|Cooler:H150i PRO|Mobo:C7H|Ram:2x16GB 3200 CL14|GPU:RTX 2080TI+G12\KRAKEN X72|SSD1:970 EVO 1TB|SSD2:2x500GB Raid 0|HDD:3TB WD|Case:Lian Li O11B Dynamic|PSU:EVGA G2 750W|Monitor:ACER X34P 120HZ
Vidati is offline
