New Radiator? - Overclock.net - An Overclocking Community
New Radiator?
post #1 of 35 (permalink) Old 04-11-2019, 07:49 PM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1555 (Unique: 1017)
New Radiator?
So I'm looking to retire my old Phobya V2 Copper radiators. The 360mm and 420mm versions. Both are around 45mm thick.
I've been looking at the EK SE and the Magicool G2 Slim or Pro III.
The G2 seems to be very cheap (£40) and beats the EK SE in reviews. For £7 I can get the Pro III (G2 but thicker I think).
I'm basically looking for new 360mm radiators at affordable prices but better performance than my old Phobya radiators. Would do you experts say on the matter?
I plan to run the loop in a Tt X71 Core.
Thank you.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
AMD ASUS STRIX OC VEGA 64
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO NVM.e 250GB
SeaSonic 1250W Gold
Corsair 900D + Custom Loop.
BradleyW is offline
post #2 of 35 (permalink) Old 04-11-2019, 07:55 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
I have this Magicool 360 radiator than 45mm thick and run a 8600K and GTX1070 with Gentle Typhoon 2150 fans with no issues...just make sure you clean it with vinegar to get out the flux.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #3 of 35 (permalink) Old 04-12-2019, 05:49 AM
News Fiend
ryan92084's Avatar
Depending on your desired fan speeds and ability to deal with the restriction its hard to beat the HWL GTS. They are around £60.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #4 of 35 (permalink) Old 04-12-2019, 07:12 AM
toolmaker03's Avatar
Rep: 86 (Unique: 65)
Thank you.
really your question is about radiator design, and most people here seem to simply ignore this very important point. BTW a hardware labs GTS radiator is basically the same thing you have now, it would not improve the performance of the water loop at all.
ok, you have a 10 FPI radiator now, this is a low FPI radiator and will work well with fans up to about 2000RPM's. this is the point that radiator is at it's maximum performance level. I will assume that you currently have 6 X 2000RPM fans attached to that radiator already. here is my build, with two monstra radiators attached, with 6 X 2350RPM fans on each.
https://www.overclock.net/forum/61-w...ooled-rig.html
what you are looking for is a black ice GTX 360mm radiator or better. the black ice GTX is a 20FPI radiator, and with 6 X 3000RPM(noctua IPPC 3000) fans attached, it will out preform what you have now.
http://hardwarelabs.com/blackice/gtx/gtx-360/
http://www.performance-pcs.com/black...n.html#Details
or if the best performance possible is what you are after, the koolance HX 360-XC is a 30 FPI radiator, and with 6 X 4000RPM(koolance or delta) fans attached, will outperform anything on the market.
https://koolance.com/hx-360xc-radiat...-30-fpi-copper
https://koolance.com/fan-120x38mm-184cfm
so to give some numbers to go along with these radiators.
the phobya will top out at about 400watts
the hardware labs will top out at about 600watts
the koolance will top out at about 800watts
so as you can see the koolance radiator, can actually provide twice the performance you have now. so it is up to you to decide how you would like to rebuild this water loop, and with what hardware.
EDIT I do not know what has happened to this site, but for some reason it is killing the links that I placed in this post, maybe a moderator could look into this issue, and fix what ever is causing this to occur?
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #5 of 35 (permalink) Old 04-12-2019, 07:49 AM
Shawnb99's Avatar
Rep: 28 (Unique: 19)
Both those Radiators are thicker than 45mm which is what the OP was looking I replace so they may be to thick.
4000rpm fans? Those must be deafening. At that rpm I should hope it would be twice the performance.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 35 (permalink) Old 04-12-2019, 08:00 AM
really this is about design, low FPI radiators work well with low RPM fans attached. a low FPI radiator to me, is a 7 FPI to 12 FPI radiator. these radiators are not designed to have anything faster, than about 2500RPM fans attached to them. even if I attached a 4000RPM fan to a low FPI radiator, it would not increase the performance of the radiator much beyond what a 2000RPM fan could achieve with that radiator.
this of course will change, as the FPI of the radiator goes up. the higher the FPI of the radiator, the faster the fans attached should be. the faster fans on higher FPI radiators, will allow the full potential of the radiator to be utilized.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #7 of 35 (permalink) Old 04-12-2019, 09:39 AM - Thread Starter
Programmer
BradleyW's Avatar
Thank you very much for the information. I am going to research the suggested radiators to see how much they cost and how they perform.
However, my goal is to beat my current loop, maintain low fan speed and keep it very affordable, hence why the Magicool G2 appealed to me greatly.
I initially thought about getting either 3xG2's or use my Phobya 360mm + 2xG2's.
Thank you.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #8 of 35 (permalink) Old 04-12-2019, 09:58 AM
News Fiend
ryan92084's Avatar
I can't find any reviews that match the radiators you describe from phobya to try and make any direct comparisons. The trend for a while was maximum performance with no regard for noise. Super thick rads with fat delta fans in a mountain mods case would have been the bee's knees when I built my first loop.
some good roundup reviews
360mm https://www.overclock.net/forum/61-w...p-22-rads.html
360mm http://thermalbench.com/2017/07/06/p...mm-radiator/5/
480mm (has some additional models) http://thermalbench.com/2018/09/25/x...in-radiator/4/
360mm This one is quite dated but more fan speeds tested https://www.overclock.net/forum/61-w...p-22-rads.html
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #9 of 35 (permalink) Old 04-12-2019, 10:13 AM
In the meantime, may I ask, If a high FPI RAD requires faster spinning fans (loud), why don't people just buy a low FPI RAD?
Additionally, would a Magicool 360mm G2 slim (16FPI) outperform a Phobya 360mm x 40mm (10FPI) if both RAD's used 3 NF F12's at a fixed speed of 1000rpm?
Furthermore, would a combination of (Phobya 360x40mm + 2x Magicool Copper III PRO 360x40mm) outperform (Phobya 360x40mm + Phobya 420x45mm)? All RAD's using Noctua 120/140mm where appropriate, fixed speeds 1000rpm.
Thank you.
ok, well the issue with this thinking, is you are trying to associate low FPI radiator performance, to mid, and high FPI radiators. you cant do that, because they function differentially. a quite water cooling build needs to have low FPI radiators, so that fans at low RPM will be useful. this creates a quite build as a result. as you have already noticed, a low FPI radiator build requires more radiators to do the job, and keep the system cool. the advantage is that it is quite. a mid FPI radiator, will be able to cool the same hardware, but will require less radiator, and faster fans to do this. a high FPI radiator can do the same job as a low FPI radiators, but with half the radiators, and again it needs even faster fans to do this.
so to me, the real question here is, what do you want to build? a quite build that will need at least two 360mm radiators to cool the hardware, or is space a issue, and you need a high performance radiator build. that could cool all the hardware with one 360mm radiator, it will not be quite, but it will keep the system just as cool.
putting 1000RPM fans on a 30 FPI radiator, would provide horrible performance. the fin placement is to tight, and at that fan speed, it is not enough air flow going through the radiator, for it to preform well.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #10 of 35 (permalink) Old 04-12-2019, 10:29 AM - Thread Starter
Programmer
BradleyW's Avatar
These are great links. I highly appreciate it.
My main goal is lower noise levels. I can fit 3x360mm RAD in my new case (X71 Core). Initially I thought about 3xG2 slims or 2xG2 slims + Phobya 360mm. All RAD's push only.
As said before, G2's are appealing due to low price and decent reviews. 16 FPI, maybe too high for low fan speeds? Then again, it is a very slim RAD!
These are basically the RAD's I have on offer to me. Don't want to pay any more than £50 for a RAD. G2 for £40 sounds good.
https://www.overclockers.co.uk/water...-radiators?p=1
Thank you very much for your kind support and in depth knowledge.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
