Tank Choice + D5 - Overclock.net - An Overclocking Community
Tank Choice + D5
post #1 of 32 (permalink) Old 04-15-2019, 08:42 AM - Thread Starter
Rep: 0
Tank Choice + D5
Need some help here.
I need upgrade my old, more than 10 yeras EHEIM 1046, since with new cooling system it can`t handle with pressure...
My rig is a WB Heatkiller IV Niquel, + 120mm radiator Black Ice extremm + alphacool triple ultrathin radiator on top.
The pump will be a D5 with mechanic 5 level adjust: Lowara, Aquacomputer, EK...i think its the same..
Now my problem:
I want a tank, to sit vertically, and not atached to rig, like my actually EHEIM 1046, and somthing that i can adjust level liquid on top.
The liquid i use its car G12 + tapped water.
So far my options are:
- Alphacool Eisstation
- XSPC D5 Tank Reservoir (V3)
- EK-XRES 140 SPC PWM Classic RGB
-HEATKILLER® Tube 100 D5
The tube is flex 10/13mm. All option are welcomed.
Mordorr is offline
post #2 of 32 (permalink) Old 04-16-2019, 02:07 AM
Ashcroft's Avatar
Rep: 80 (Unique: 63)
Just in case you weren't aware, the EK pump/res you linked above is not a D5 compatible reservoir. It is an EK SPC pump which is a bit like a low powered DDC.
When it comes to D5 pump/res combos I always recommend the EK D5 Xres units. They are fundamentally different to other units that look similar but have the return port connected directly to the pump inlet which means the res section is mostly or totally bypassed once the system is filled.
The Xres has the return line feeding into the reservoir section, just like you would set up a seperate pump and res, so that all coolant flow must pass through the res. This allows the res section to do it's job as an air bubble trap very effectively.
Other designs like the XSPC and Aquacomp make it harder for the res section to do it's job trapping bubbles and means the res is quite stagnant with very little mixing with the main loop.
Ashcroft is offline
post #3 of 32 (permalink) Old 04-16-2019, 05:13 AM
News Fiend
ryan92084's Avatar
If you want to get into the planning you can look into the Monsoon system. It also has the water flowing into the res and not directly to the pump for easier bleeding.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is online now
post #4 of 32 (permalink) Old 04-16-2019, 05:33 AM - Thread Starter
Rep: 0
Thank you for your reply!
Im very interested on the Alphacool Eisstation. Its simple and the connectors are at the base and not at the top.
I also found a site selling it to VPP version...
Already buy from barroy to 90º connectors just in case...
About pumps:
Real interested on 655 version with 5 mechanic options. Even i own a Asus Cross hero VII, i prefer manual control...
Found also a site selling Lowvara, if not mistake. Or i can go with Aqua computer VP655....any suggestion?
EK seems more weak, even i prefer i own a low waterblock cooling...
Thank you!
ryan92084
Sorry didnt notice your answer. well i look something simple like inovatek tank for EHEIM 1046 conected to the bomb, where i can put on floor of the rig and if necessary put liquid on the top...
So far Alphacool eisstation seems to be the more logic solution.
Thank you!
Mordorr is offline
post #5 of 32 (permalink) Old 04-16-2019, 05:53 AM
News Fiend
ryan92084's Avatar
Yeah, if you want simple the monsoon system is definitely a no go.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #6 of 32 (permalink) Old 04-16-2019, 06:38 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
well I have a water cool, and bitspower reservoirs. they can both be mounted vertically. their is a stand for the water cool, and standing feet for the bitspower. personally I like the water cool reservoir, better than bitspower. I did get the replacement top, with the top ports, for my water cool reservoir.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #7 of 32 (permalink) Old 04-16-2019, 06:39 AM
ezveedub's Avatar
Rep: 142 (Unique: 100)
If you’re going to some of those reservoirs on a D5, how are you going to mount it? You need mounting brackets for the D5 still if it sits on the floor on some of these. As said earlier, that EK SPC is not a DDC pump....I would sort avoid that model IMO.
Sent from my iPhone using Tapatalk Pro
Intel Processor
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
HAF 932
Operating System
Windows 10
ezveedub is offline
post #8 of 32 (permalink) Old 04-16-2019, 07:43 AM - Thread Starter
Rep: 0
Mounting brags? Sorry English is not my native language....
All, of most of all solutions i suggest, have by default a base. Under my EHEIM 1047 i have a spoon, or shock absorber.
Can you guys send some links for that monsoon? I did my homework, but didn`t found any at my taste...
Personally im against vertical tubes+bomb, since they are prone to create more bubbles but maybe im wrong here.....
Mordorr is offline
post #9 of 32 (permalink) Old 04-16-2019, 08:13 AM
Shawnb99's Avatar
Rep: 14 (Unique: 10)
Most of the vertical ones have something to stop a vortex or bubbles from entering the loop. IE deflector plate or a tube or sponge thingy. All the ones I’ve used have been vertical and never had an issue with bubbles entering the loop.
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #10 of 32 (permalink) Old 04-16-2019, 10:29 AM - Thread Starter
Rep: 0
Sorry my mistake (working office and reply same time) i did mean i dont like horizontal one....
Yes i saw that on some models from Heatkiller....
Maybe a photo of my rig helps better to get my idea of pump+tank:
This is my EHEIM + Inovatek tank. I want simple, practical, were i can connect 2 tubes, and put liquid on top.
so far, as i can see, this is the best candidate...
Already buy from Barrow those to 90º curves, just in case.....
But i dont have many feedback of this tank, if suffer from micro fissures for example or other problems....
Mordorr is offline
