120mm fans for radiators and watercooling. - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 04-16-2019, 09:59 AM - Thread Starter
Rep: 45 (Unique: 37)
Hello, once again
Im looking for fans swap since im going to rebuild my overall system. Wont go to details because it wont change much (just pc parts basicly) and want to swap some old fans. Looking for some silent solution with best performance possible from them. Uncle google is not helping. Im unable to find some decent or recent reviews or roundups. Any help? All my fans are 120mm, 3 on rad and 4 on case. What should i buy, what are the best silent fans for rads and cases now, and why? some bang for buck solutions are also cool since i dont have tons of hardware to cool. Cheers in advance.
Ryzen 5 2600 | Asrock x470 K4 Fatality | 2x8 3000Mhz DDR4 | GTX 1660 Ti | 480GB SSD | IN WIN 303 | be quiet! STRAIGHT POWER 10 500W
prznar1 is offline
post #2 of 24 (permalink) Old 04-16-2019, 10:42 AM
I have bought a couple of the Noctua Redux line of fans for radiator, NF-P12 redux 1300 PWM. Works fine, mostly inaudible at low speeds.
As far as I know it is the same Noctua fan as the older NF-P12 for a reduced cost, in a different color, and you don't get any of the accessories usually packaged with Noctua fans.
Quote:I'm gonna throw in my 2 cents. Not because I'm an expert but because I have a keyboard.
bfromcolo is offline
post #3 of 24 (permalink) Old 04-16-2019, 11:11 AM - Thread Starter
What about corsair ML series? In store im going to buy stuff they are on sale atm. Web shows me some positive feedback on them, along with BQ silent wings 3. Noctua sadly is not available in that store :C but it was one of my first brands i thought.
prznar1 is offline
post #4 of 24 (permalink) Old 04-16-2019, 11:25 AM
Fluxmaven's Avatar
Rep: 8 (Unique: 5)
Are you wanting to run 3 pin or 4 pin (PWM) fans? There are lot's of good options either way.
The only Corsair fans I would really recommend are the ML series.
The Noctua redux fans are a good way to get quality fans at a decent price
Be Quiet SW3 are good but expensive
The ballin on a budget option would be the Arctic value packs. They have the P12 which are pressure optimized (what you want on radiatiors) or the F12 for just case airflow.
https://www.amazon.com/ARCTIC-ACFAN0...%2C128&sr=1-12
Fluxmaven is offline
post #5 of 24 (permalink) Old 04-16-2019, 11:33 AM
Programmer
BradleyW's Avatar
Rep: 1554 (Unique: 1016)
Take a look at EK Vardar EVO.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
AMD ASUS STRIX OC VEGA 64
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO NVM.e 250GB
SeaSonic 1250W Gold
Corsair 900D + Custom Loop.
BradleyW is offline
post #6 of 24 (permalink) Old 04-16-2019, 12:02 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 381 (Unique: 262)
Personally, I think the sound profile of the be quiet SW3 is much nicer than the Corsair ML. Smoother and not as intrusive. Performance difference is negligible between the two. If a quiet, smooth sounding rig is your goal, the SW3 would be my top choice. The only Noctua that competes with (actually betters) these two is the NF-A12X25, but they are very expensive and only come in the brown color scheme. None of the other Noctuas will match teh SW3 or ML.
Some good info here - http://thermalbench.com/2016/10/21/b...h-speed-fan/3/
He mentioned "silent". Not many who have used the Vardars would recommend them for anyone with noise concerns.
ciarlatano is online now
post #7 of 24 (permalink) Old 04-16-2019, 12:53 PM
Melcar's Avatar
Rep: 636 (Unique: 438)
My ML start to make weird noises when I mount them horizontally. Maybe it's just my fans, but there is that. Like low growling noises. Noticeable and a bit annoying.
Vardars are silent in a way (for the amount of air they can push), but they have bearing noises that will annoy you at any speed. They also in general have QC issues.
Magicbox
(18 items)
Ryzen 7 1700
GA-AX370-Gaming K7
RX 480 Nitro+
Corsair Vengeance
Samsung EVO 850
HyperX 3K
Seagate Barracuda
EVGA G2
Noctua NH-D15
Morpheus II
Phanteks Enthoo Pro
Operating System
Kubuntu 18.04
Operating System
Windows 10 Pro
Dell U2515H
Keyboard
CM Storm QuickFire TK
Mouse
G502
Mousepad
G440
Audio
Xonar DX
Melcar is offline
post #8 of 24 (permalink) Old 04-16-2019, 01:13 PM
Gamer
kgtuning's Avatar
Rep: 106 (Unique: 64)
Yeah Vardars can get loud unless you keep them at a lower rpm. But like Melcar said the bear issues are annoying. I have like 12 and 8 of them needed bearings swapped out. Darkside gentle typhoons at 1800 rpm would be “quiet”. But my quiet and your quiet might be very different. My darkside GTs run at 2200 rpm and I’m happy.
mITX
(0 items)
kgtuning is offline
post #9 of 24 (permalink) Old 04-16-2019, 01:15 PM
ciarlatano's Avatar
Yes, I should have specified that I was referring to the mechanical noises. Like nails on a chalkboard.
post #10 of 24 (permalink) Old 04-16-2019, 01:40 PM - Thread Starter
Hmmm, so long lasting and good fans are BQ? It is silent wings then. Thx for all input.
3 silent wings 3 for radiators, but what about case? shall i go with same or get bit cheaper version of BQ?
Edit: screw it, 3 pwm sw3 on rad, 4 dc on case hope they live to my expectations. Thx for all info again
prznar1 is offline
