Alternative clear flexible tubing. - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 04-17-2019, 12:24 AM - Thread Starter
AMD Overclocker
Alastair's Avatar
Rep: 256 (Unique: 159)
So I am looking for alternatives to Primoflex and EK Duraclear. In South Africa all our local shops only stock Duraclear in 3/8 ID 1/2OD or 3/8ID 5/8 OD tubing. I use 1/2 ID 3/4OD tubing. I also cant find any Primoflex in SA either. So I am going to have to scour local hardware and aquarium shops fort clear flexible tubing. But I am worried about plasticizer leeching and discolouration (Colour is spelt colour in SA.) So my question is what should I look for in flexible tubes? When I look at EKWB Duraclear and Primoflex. They state it is PVC. The tubing at the hardware is also PVC. So what is the difference? And how can I tell good PVC tubing from bad since I cant get Primoflex or any other fairly decent tubing? Some of my friends said I should look for food grade tubing? Some have mentioned silicone tubing?
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 3.5
(29 items)
Rura Penthe
(12 items)
AMD FX-8370 @ 4.95GHz 1.5V 2700MHz NB/3000MHz HTT
ASUS M5A99FX PRO R2.0
Sapphire R9-Fury 3840
Corsair Vengeance 2133 4x4GB @ 2000 9-9-10-27 1CR
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
Antec High Current Pro Platinum 1300W
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
2x EK-FC Fury X fullcovers
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
Laing D5 Vario
EK-FC Terminal Dual Parallel
2x EK-FC Fury X Backplates
EKWB Coolstream CE280
6 Corsair ML140's
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #2 of 10 (permalink) Old 04-17-2019, 12:27 AM
Section31's Avatar
Rep: 3 (Unique: 3)
Go with mayhem tubing. I had primochil and hated it. The tubing required dipping into hot water before if fit onto any compression fittings. No such issue with mayhem.
Section31 is offline
post #3 of 10 (permalink) Old 04-17-2019, 12:40 AM - Thread Starter
AMD Overclocker
Alastair's Avatar
Doesnt look like I can get anything of the sort in south africa. My choices are EK Duraclear or EK Duraclear. And that is not an option since they dont have in 1/2ID // 3/4OD. So I need to look at alternatives. Like hardware bought tubing. So this is why I need to know is there a way I can tell good tubing from bad tubing? what about PUR tubing vs PVC vs Silicone etc.
GHOST rev 3.5
(29 items)
Rura Penthe
(12 items)
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
Laing D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #4 of 10 (permalink) Old 04-17-2019, 12:59 AM
Shawnb99's Avatar
Rep: 14 (Unique: 10)
I’ve found Mayhems to be very bendy and flexible
I second primochill being a pain
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #5 of 10 (permalink) Old 04-17-2019, 01:03 PM
Section31's Avatar
Rep: 3 (Unique: 3)
Its same in canada. Low inventory or items not carried. Often i have to order from us and now direct from europe for german stuff.
post #6 of 10 (permalink) Old 04-18-2019, 12:02 AM - Thread Starter
AMD Overclocker
Alastair's Avatar
Its still not really helping me with the conundrum I am in. What makes watercooling flexible tubing different from store bought. And how can I tell if the store bought tubing I am getting is decent.
GHOST rev 3.5
(29 items)
Rura Penthe
(12 items)
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
Laing D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #7 of 10 (permalink) Old 04-18-2019, 12:51 AM
Section31's Avatar
Rep: 3 (Unique: 3)
I think i remember some ocn thread that talked about using tubing from hardware stores with no issues. Just has to be plastizer free.
I think the quality is all about the same, its the quality control. If an plumber uses the tubbing it cant be bad.
post #8 of 10 (permalink) Old 04-18-2019, 01:26 AM
Not New to Overclock.net
fragamemnon's Avatar
Rep: 247 (Unique: 186)
I was about to give the same advice if you're looking for a last-resort option.
Ask a plumber for advice on which tubing to use. As long as it's plasticizer free, it will work.
You're going to run neither extreme temperatures nor pressure.
MEGATRON
(17 items)
GIGATRON
(10 items)
Ryzen 7 1700
Crosshair VI Hero
Gigabyte RX 580
2x8 G.Skill Trident 3200 CAS14 @ 3466 CAS14
2x1TB WD Black RAID 0
3TB WD Red
Samsung 840 Evo 250GB
FSP Aurum PT 1200W
Stock... hue hue
Thermaltake Core X9
Benq XL2411Z
Dell U2412M
Dell U2412M
Keyboard
KBC Poker II MX Clears
Mouse
Zowie ZA11
Mouse
old school Razer Goliathus
Audio
Aune T1 -> Yamaha A-720 -> Sennheiser HD650 | Sony MDR-XB500
Intel Xeon E5-2650 v4 @ 2.00GHz
SuperMicro X10DAL-i
nay
2x8GB (for now) Kingston DDR4 @ 2133MHz/C16
Samsung 840 120GB
SeaSonic SS850-AM
EK-Vardar F4 on an Arctic Freezer i11
overrated
Operating System
Ubuntu Server 16.04
fragamemnon is offline
post #9 of 10 (permalink) Old 04-18-2019, 01:36 AM
Why is it smoking?
Mr. Mojo's Avatar
Rep: 356 (Unique: 293)
I've been "out of the loop" for a while, but Tygon used to be the preferred tubing for wc systems. There are a few different versions that are plasticizer free/non-phthalate and it's possible to find it in hardware stores.
Da Bestest Juju
(16 items)
Intel Core i7 4710HQ
NVIDIA GeForce GTX 970M
16GB DDR3L
Samsung 850 EVO
HGST Travelstar 7K100
Operating System
Windows 10
BenQ XL2720T
Keyboard
Microsoft Sidewinder X4
Mouse
Gigabyte M8000X
Mouse
Steelseries
Audio
Audio-technica ATHM40x
Audio
MTX iX1 Headphones
i5-4690k
Gigabyte GA-Z97X-UD3H-BK
Zotac GTX 970
Corsair Dominator
Crucial M550 M.2 SSD
Samsung 850 EVO
Seagate Barracuda
Optical Drive
Samsung Blu-Ray
Rosewill Photon 750
stock
EVGA DG - 77 Black
Operating System
Windows 10 Pro
BenQ GL2760H
Keyboard
Microsoft Sidewinder x4
Mouse
Gigabyte M8000X
Audio
Audio Technica ATH-M50x
Mr. Mojo is offline
post #10 of 10 (permalink) Old 04-18-2019, 02:33 AM - Thread Starter
AMD Overclocker
Alastair's Avatar
How will I know if it is plasticizer free?
I just see reels of the stuff at the hardware. No labels or anything? What about tubing used in aquariums? Surely those have to be plasticizer free. As it would be very bad for the fishes to have chemical particulates floating around in their water.
GHOST rev 3.5
(29 items)
Rura Penthe
(12 items)
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
Laing D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
