CPU only GTS or GTX - Overclock.net - An Overclocking Community
CPU only GTS or GTX
post #1 of 17 (permalink) Old 04-18-2019, 04:34 PM - Thread Starter
Rep: 0
CPU only GTS or GTX
I am about to do my first custom loop and for all the research I've done I can really figure this out. I have an Enthoo Luxe and I'm basicly doing an all Phanteks build, but this radiator thing is throwing me off.
PC Specs
Asus x299 TUF Mk 1
i7x7820
32gb Corsair 3200
Strix 2070 OC
intel 760p Nvme
I am using a Phanteks Glacier R220 with a swiftech MCP50x and the glacier C350i CPU block. All the fans are Phanteks MP 140's. I would like to do a 420 GTS in push/pull so that I can use my Phanteks halos. However its seems like i've read conflicting reports on the rad and push vs push/pull. If I go with the GTX I will not be able to do push/pull or use my halos, but I believe I would be able to get a better overclock. Currently I'm using a Noctua D15s with a 4.8ghz overclock. Can someone tell me if the GTS 420 would be enough to do a decent OC or do I just need to get the GTX and lose out on push/pull and the halos but possibly have much better OC potential. This is a CPU only WC as I have the cablemod vertical GPU mod and I like the way it looks with the Strix card. My CPU is not delidded yet but will be once I decide on the radiator.
Thamuza is offline
post #2 of 17 (permalink) Old 04-18-2019, 05:31 PM
Not a Fan
GnarlyCharlie's Avatar
Rep: 162 (Unique: 126)
I think a 420 GTS in P/P or a GTX in push only would both be fine for just a CPU. I have a GTX 420 P/P and 280 GTX P/P and run both an OCd 7920X and a Titan Xp in fine shape using same CPU block in an Enthoo Pro.
If winning were easy, losers would do it.
It's got Async Compute, it's got what plants crave!
War Pig
(12 items)
Death Bomb
(9 items)
X-Rig
(15 items)
i9-7980XE
Rampage VI Extreme Omega
2080Ti FE
G.Skill F4-3600C16Q2-64GTZSW
Samsung 970 Pro X4
Optical Drive
Pioneer BDR-209BDK
EVGA SuperNova 1300 G2
HW Labs Black Ice GTX 420-480-2X240
EK Supremacy Evo CPU Heatkiller IV GPU
2X PPCs Bitspower D5
Corsair 900D
Operating System
Windows 10 Pro 64 Bit
I7-7700K De-lidded @ 5GHz
Asus Strix Z270i
Nvidia Titan Xp
G. Skill F4-3600C15D-16GTZ
2X Samsung 960 Pro 512GB M.2
SeaSonic X750
EK Supremacy EVO CPU. Titan Xp Full Cover w/Backplate, X-TOP Revo D5 PWM Pump, Res X3 110mm Res, HW Labs GTS 280 and GTS 240, Primochill Tubing & Revolver fittings
Fractal Nano S
Operating System
I7-5960X
Asus Rampage V Extreme 1502
EVGA Titan X
EVGA Titan X
G.Skill F4-3000C15Q-32GRK
Samsung SM951 M.2
Samsung 850 Pro 512GB
Optical Drive
Pioneer BDR-2209
EVGA 220-P2-1200-X1
EKWB Blocks, Fans, and Pumps, Rads
Corsair 550D
Operating System
Windows 10 Pro Retail
BenQ BL3201PH
Keyboard
Max Keyboard Nighthawk X8
Mouse
Roccat Kone Pure Optical
GnarlyCharlie is offline
post #3 of 17 (permalink) Old 04-18-2019, 07:02 PM - Thread Starter
Rep: 0
I guess in that case I will go with the 420GTS in p/p as it will allow me to keep my halos..im hoping to get a 5ghz OC once I'm delidded and watercooled
Thamuza is offline
post #4 of 17 (permalink) Old 04-18-2019, 11:32 PM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
The difference between the GTX and GTS is only 1C at high fan speeds. At low speeds, the performance is the same.
Push pull is not necessary needed but it's doesn't hurt to use it of course.
At 420 for a CPU will get you sweet temps, even at low speeds so you'll get a nice setup :-)
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #5 of 17 (permalink) Old 04-18-2019, 11:49 PM - Thread Starter
Rep: 0
Thanks for the input.. I think I may stray from the all phanteks build, at least on the cpu block. I have been looking at some of the aquacomputer cpu blocks and I like the cuplex kryos and it has great reviews and only cost about 25$ more than the phanteks cpu block.
Thamuza is offline
post #6 of 17 (permalink) Old 04-19-2019, 05:10 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
First, I don't believe the MCP50X will work with the Glacier R220 unless you are using the pump free standing. The MCP50X is not compatible with standard DDC tops.
Second, you have a couple of standard misconceptions going on in your thought process - namely that "bigger must be better" and that "push/pull must be better than push only". If you do a quick review here https://www.xtremerigs.net/2015/02/1...-round-2015/5/ , you will find this is not always the case. The GTS and GTX were made for different applications and usage, and both excel at their intended usage. The GTS was designed for quiet rigs and will outperform a GTX (which is designed for high fan speed usage) up to ~1350 rpm. It will have a nominal difference in performance to ~1750 rpm. Until you get into fan speeds that will make your ears bleed, the GTX doesn't separate itself from the GTS. So, unless you are want is to build something that sounds like a vacuum cleaner, the GTS is going to be the better performer.
You will also notice that P/P has essentially no performance impact on the GTS. So, you aren't going to gain anything by going P/P, and it will be louder at the same performance levels. However, with a 420mm on a CPU, you will likely never have to break 1000 rpm, so it won't be much of a concern.
Personally, I think the GTS is a far better choice for your application - better performance, less noise, and retains the ability to use the Halos.
ciarlatano is offline
post #7 of 17 (permalink) Old 04-19-2019, 10:35 AM - Thread Starter
Rep: 0
That was one of the things that I wasn't so clear on.. I must have looked over that artical 20 times.. And that's where I wasn't sure if the gts would be fine in push or better in p/p. There is a review on Amazon a guy used the mcp50x pump only for the r220 and he had some caveats about it.. Which is what I was gonna do...i want it to be simple and elegant.. Lol.. So using the gts in push only with the 140mps and the halos will be just what Im looking for.. That aquacomputer vision is sooooo nice.. But I'm also considering doing the Aida 64 cell phone mod.. So I could technically keep it all phanteks.. But the aquacomputer cpu blocks seem to be higher quality.
https://m.youtube.com/watch?v=l6QG3tRKwPc
Thamuza is offline
post #8 of 17 (permalink) Old 04-19-2019, 10:44 AM
Pinnacle Fit's Avatar
Rep: 24 (Unique: 18)
I personally think a 420 might be overkill for just a cpu loop, unless you’re looking to expand later.
Sent from my iPhone using Tapatalk
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
Gigabyte Z390 Aorus Master
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
post #9 of 17 (permalink) Old 04-19-2019, 11:36 AM
ciarlatano's Avatar
Overkill, yes. But, as you say, it gives the option for expansion and the increased rad size will allow for very low fan speeds so it will be extremely quiet.
post #10 of 17 (permalink) Old 04-19-2019, 11:42 AM
Hardware Princess
Hydroplane's Avatar
Rep: 38 (Unique: 30)
I own the GTX and am very happy with it
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
