bubble trap/tank water level lowering - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 04-20-2019, 03:02 AM - Thread Starter
yevonxxx's Avatar
Rep: 0
hi,
recentrly i've changed my rad to an other one identical,is a big big one so it take i guess days before all air bubbles leave the loop,
anyway i'm wondering if i have invisible leaks because everyday i just have to add some water,but inspecting the loop i don't see any obvious water dropping or leaking,
all seems fine..water disappearing apart.
what could it be?
how normally your water level go down?
thank you.
Bianco&Nero
(0 items)
yevonxxx is offline
post #2 of 11 (permalink) Old 04-22-2019, 04:35 AM
News Fiend
ryan92084's Avatar
If you've rotated your case every which way to get the largest bubbles out your res level shouldn't be falling all that quickly. You can try the old paper towel test of tightly wrapping each fitting in a sheet and let the loop running for several hours. If any moisture is leaking out the towels will change texture/stain/stay moist instead of the moisture just evaporating.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #3 of 11 (permalink) Old 04-22-2019, 06:47 AM
NewUser16's Avatar
Rep: 36 (Unique: 23)
Speaking from my own experience and I have a big dual loops it takes me about 2-3 months to completely bleed it, yes it can take that long depending on type of your rads, blocks and loops complexity. Most likely you have more bubbles in the rad then you think and slowly the air finds its way out leaving your fluid level lower. Give another week or so to bleed then you should have better idea
NewUser16 is offline
post #4 of 11 (permalink) Old 04-22-2019, 06:50 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
normal water drop, with clear soft tubing, about 1" every 3 months at the worst. my personal rig with norprene tubing has a 1/2" drop every year. so with this information, if the system is between these two amounts, than it is acting normally.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #5 of 11 (permalink) Old 04-22-2019, 07:03 AM
Overclocker in training
ThrashZone's Avatar
Rep: 47 (Unique: 37)
Hi,
What type of fluid exactly ?
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #6 of 11 (permalink) Old 04-23-2019, 09:59 AM - Thread Starter
yevonxxx's Avatar
Rep: 0
hi all an ty for replies.
liquid is simply distilled water with just a coffe cup of CITROSIL in it(liquid total volume is like 3 liters),
rad is a giant full copper car rad(check my signature),so probably it is the source of all this air,
anyway problem seems to be reduced a lot,BUT,everytime i shutdown pc and turn it on say the morning after i see some bubble moving immidiately into the bubble trap,
so i start supposing a vacuum leak somewhere,could try to tighten everything a bit more,but it's a pain in the ass considering i should remove all tubing,tighten all fittings in place,
reset tubing in place and retightening compression fitting,plus all over again the air bubble saga. :/ pffffffff
Bianco&Nero
(0 items)
yevonxxx is offline
post #7 of 11 (permalink) Old 04-23-2019, 11:03 AM
skupples's Avatar
Rep: 525 (Unique: 296)
I don't think its a ghost leak, I think you're just experiencing what many of us experience - an incredibly long period of time before all air is truly out of the system.
The bigger the beast, the harder it is to get all that air out. Also, unless you pump speeds are way low some air gets pulled back into the system each time air dumps into the reservoir.
I'm like 3 weeks out from my last drain & I'm still shaking bubbles out daily.
also - I'd highly recommend adding some anti-corrosion properties to your water. I see what you're using is anti-biotic, but at what cost i wonder? I'd monitor Ph, and 100% get anti-corrosion in there.
I've also noticed over the years that letting the system/pump sit off for a few minutes here & there helps get some of those pesky bubbles knocked free.
skupples is online now
post #8 of 11 (permalink) Old 04-23-2019, 12:04 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 587 (Unique: 489)
Yeah, big rad will take some time to bleed but as a precaution use some paper towels to test for leaks.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Bit'O'Heaven
(16 items)
Cigar ATX PC
(14 items)
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ 1160GHz Core/1350GHz Mem
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Open Water Loop
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Nixeus EDG 27" Freesync 1440p 144Hz
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Microsoft Sidewinder X5
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Intel Core i5-3570K @ 4.5GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990
G.SKILL Ripjaws X DDR3 8GB 1600MHz
Crucial SSD 128GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Corsair Vengeance MM200
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
AMD Athlon II X4 640
ASRock N68C-GS
NVIDIA 6600GT
G. Skill Ripjaws DDR3 1600MHz
WD Caviar Blue 500GB 16MB Cache 7200RPM
Optical Drive
LG Optical Drive
Thermaltake TR2 600W
Thermaltake Max Orb
Cigar Boxes
Operating System
Windows 7
Viewsonic 19” Flatscreen CRT
Keyboard
Gigabyte GK-K6800 103
Mouse
Zalman ZM-M300
Mouse
Gunderman456 is offline
post #9 of 11 (permalink) Old 04-23-2019, 12:11 PM
skupples's Avatar
yes, 100% - always hotwire your power supply & leak test before anything else.
I've gotta weird pressure issue where my system likes to suck in air from the BP Bleed valve on my top radiator (that returns to reservoir) however, it only happens when there's air in the system to cause said vacuum/pressure in the first place.
post #10 of 11 (permalink) Old 04-24-2019, 01:55 AM - Thread Starter
yevonxxx's Avatar
Rep: 0
yes,i've just found(yesterday)that CITROSIL is pratically chlorure benzalkonium and is really recommended to NOT use it together with nickel plate things in a loop,and this explain corrosion i've noticed from last loop maintenance.
so at least i've decidec to switch to blu car radiator liquid based on ethylene glycol,we'll see.
Bianco&Nero
(0 items)
yevonxxx is offline
