Radiator surface enough ? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 04-20-2019, 12:06 PM - Thread Starter
TeslaHUN's Avatar
Rep: 23 (Unique: 21)
Since no reply in watercoooling club thread ,im asking here :
I have a Phanteks P600s case with 2x Phanteks 140SP fan on min rpm(400) on front intake , and one 140SP on back as exhaust . CPU([email protected],1) + VGA(1080TI @1987mhz) on water , radiator is external Mo-Ra3 420 with 9x Noctua NF A14pwm fan (300 rpm).
Dual D5 pump in series.
I also have a 420*45mm Alphacool rad somewhere collecting dust Shall i add that 420 rad in front of my P600s case ,or i wont get any benefit from it ? Or even make things worse ? ( I think 140sp fans on low rpm dont have the power to pull air through/flow across dustfilter+45mm thick rad ,trapping the heat inside the case )
So Mo-Ra alone or add the +420 rad ? Thanks
TeslaHUN is offline
post #2 of 7 (permalink) Old 04-20-2019, 12:10 PM
elkwood's Avatar
Rep: 11 (Unique: 6)
Yea i think that is plenty of cooling for your setup.If u need more cooling u can
just turn up your fan speed a bit. I never seen that Rad before. Its pretty bad ass !!
elkwood is offline
post #3 of 7 (permalink) Old 04-23-2019, 11:12 AM
Abaidor's Avatar
Rep: 3 (Unique: 3)
I also use a MO-RA 420 Pro an although I keep toying with the idea of adding a second one to the loop, it works so well as it is (cooling an 7940X @ 4.8Ghz all cores + 1080Ti Highly OCed) that it only comes down to doing it for the sake of doing it...lol
I will get a second MO-RA sometime in the future but besides the RAD I will need an extra pump and res (running 2X D5s now) + 9 more fans for it so the cost rises quite a lot for not much to be gained performance wise. One thing is for sure though, If I add a second RAD, during the summer I will have no need to spin my 9X Corsair ML140Pros higher than 500rpm anymore..
So the benefit will be total silence and a lot less dust. The second unit should be running passively (fans off) except when gaming or doing CPU intensive work (i.e. rendering).
Now in your case, I would add the RAD and test it but bear in mind that you might need to increase pump speed to maintain your flow rate.
X299 - i9 7940X
(24 items)
i9-7940X
Asus Rampage VI Extreme
Asus Strix GTX 1080Ti OC
64GB Trident Z RGB
Samsung M.2 960Pro 512GB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Phanteks Asus Strix 1080Ti GPU Block
EK-XTOP Revo Dual D5 PWM
Bitspower Fittings
Heatkiller 200mm Reservoir
9X Corsair ML140 Pro Fans
Coolermaster Cosmos 2
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Logitech MX Master 2S
Mouse
Abaidor is offline
post #4 of 7 (permalink) Old 04-23-2019, 11:22 AM
NewUser16's Avatar
Rep: 56 (Unique: 37)
More rad surface = less fan and even pumps speed and noise. Sometime the flow rate won't make huge difference in temps but adds more noise to it so more radiators will always run your system quieter and might be even cooler. You can tweak your pumps and fans to run at optimum speeds to archive silent's, yet good performance
NewUser16 is offline
post #5 of 7 (permalink) Old 04-23-2019, 12:11 PM
Abaidor's Avatar
Rep: 3 (Unique: 3)
Because I have placed my RAD above my PC on a shelf on the wall the pumps need to work harder that is why I went with 2X D5s (Dual EK volute) so that I can run them at 40-50%. One pump would need to run higher causing some noise vibration. I want complete silence and above 50% the pumps become the noisiest part in my build (not noisy but I can hear them). When I game it does not matter even if they go 70% since game sounds are louder. But while working I have them at 40%.
I intend to test a second MO-RA in the loop in the future but this experiment would cost over 600 Euros for rad (stainless steel pro) + D5 + an extra Heatkiller Tube for the second rad + 9 X 140mm Fans so I do not know if it is worth it just for not running fans at higher speed in the summer only when gaming (still quieter than game sounds).
The problem is that I have now become so accustomed to extreme silence with this build when I am working (fans at 450rpm) that "normal" sound levels are bothering me more than the average person.. Where I live is also very quiet...nature sounds mostly.
X299 - i9 7940X
(24 items)
i9-7940X
64GB Trident Z RGB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Bitspower Fittings
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Mouse
Abaidor is offline
post #6 of 7 (permalink) Old 04-23-2019, 12:17 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
2 x 120mm rad surface for each component.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #7 of 7 (permalink) Old 04-26-2019, 10:18 AM - Thread Starter
TeslaHUN's Avatar
Thanks all for advices .
I decided to sell my 420 rad and use the mora420 only . If my temps go higher at summer , i just add an extra 20cm fan on other side of the rad for push/pull.
TeslaHUN is offline
