How loud is your D5 pump? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 04-21-2019, 02:36 AM - Thread Starter
Goooober's Avatar
Rep: 0
I was watching a Singularity Computers video and he mentioned that he leaves hid pumps running at 100% at all times because of how quiet they are.
I've just completed my first ever loop and my D5 PWM (EK 140 pump/res combo) is anything but quiet at 100%. Even 50% is audible to me. I'm wondering what other people have experienced with their D5s?
Regarding the noise i do have one concern. When filling the loop i didn't realise that when turning my PSU off the pump didn't stop instantly and I think it sucked in air for a second or two. I'm aware that pumps should never be run dry and i'm wondering how to tell if a pump has suffered damaged?
My last noob question is about powering the D5. My EK one has a molex and a 4pin, should both be used together or is it meant to be one or the other? I'm currently running it with both connected and i can still make use of the PWM.
Thanks
Goooober is offline
post #2 of 11 (permalink) Old 04-21-2019, 05:12 AM
Hardware Princess
Hydroplane's Avatar
Rep: 22 (Unique: 20)
My D5 (also the EK 140 pump/res combo) on the 7980XE rig is totally silent. I leave it at 100% and can only hear it if I turn all my fans off and have the case side off. I have it soft mounted, so maybe that is why it is quieter.
Running air through a pump for a few seconds won't hurt it
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.46v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
Samsung 970 Evo Plus 250gb
EVGA 1300 G2
Dehumidifier
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
Trident Z 32GB (4x8GB) 3200C14 @ 3800C16 1.50V
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #3 of 11 (permalink) Old 04-21-2019, 05:30 AM
Cloudforever's Avatar
Rep: 60 (Unique: 46)
mine has been completely silent.
Mine was with an XSPC photon 240 v2 ( sata connection)
even on low fan speeds i absolutely cannot hear the thing
Cloudforever is offline
post #4 of 11 (permalink) Old 04-21-2019, 05:45 AM
NewUser16's Avatar
Rep: 37 (Unique: 24)
Depending on your loop's complexity. If it's free from any restrictions, D5 is very silent but as you add fittings and other components D5 has to overcome the pressure and staring to make level of noise. Mine has to go through ton of fittings and flow sensors blocks and I also have huge case so I hear some noise but not much, you can tweak the pump to your liking via voltage control.
Mine its It's fairly quiet at 2200RPM and slightly lover and higher but at lower then 1900RPM and above 3000 RPM is pretty loud. It's the complexity of your loop that dictates how quiet or loud your D5 will be but generally D5 is very quiet pump.
NewUser16 is offline
post #5 of 11 (permalink) Old 04-21-2019, 05:52 AM
Overclocker in training
ThrashZone's Avatar
Rep: 54 (Unique: 44)
Hi,
Yep if a d5 is making noise most like cause is mounting without rubber or plastic washers or feet
Or something is clogged cpu block.... this is the only time I've ever heard one of my d5 which both systems have two ek d5 pwm pumps in them neither make any noise.
As far as the two wires molex is how the pump gets power
pwm plug gives you the ability to see rmp feedback and adjust rpm rate so yeah stick with using both
Not using the pwm will make the d5 run at 100% all the time usually only good for filling the loop.
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #6 of 11 (permalink) Old 04-21-2019, 11:46 AM
ezveedub's Avatar
Rep: 142 (Unique: 100)
D5 pumps aren’t loud by any means unless something is jammed in it or the impeller is out of balance. You can hear the pump running, but nothing loud by any means. You’ll get more noise from a DDC pump than a D5 all day long.
Sent from my iPhone using Tapatalk Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
Intel i7 7700K
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
EVGA RTX2080 Ultra Gaming XC
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
ezveedub is offline
post #7 of 11 (permalink) Old 05-06-2019, 01:06 PM
smamo's Avatar
Rep: 0
I'm in the same boat as you. My D5 is pretty loud at 100%, and still very audible at 50%. It's not until I get down to around 35% that it gets almost silent. This isn't a problem for me because it does its job well at low PWM settings. It stays below 50% most of the time even during gaming. I only turn it up to get air out of my loop.
I don't think that my loop is particularly restrictive but maybe it is. I've got one universal GPU block, one CPU block, one 420mm radiatior and obviously some fittings. The pump is in a monsoon MMRS reservoir mount.
smamo is offline
post #8 of 11 (permalink) Old 05-06-2019, 01:24 PM
ezveedub's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Actually, unless you have a newer D5 pump, the earlier PWM D5 pumps run at about 50%-60% with no PWM signal (not connected). You have to send 5v to the pin 4 on the PWM connector to get 100% (Usually only done to get the pump running for bleeding air and filling, but I have used 12v with no issue, lol) I have three D5s like this and one newer ones that runs 100% with no PWM signal.
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
Intel i7 7700K
Z270X-Gaming 9
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
ezveedub is offline
post #9 of 11 (permalink) Old 05-06-2019, 01:39 PM
Tech Enthusiast
deafboy's Avatar
Rep: 431 (Unique: 329)
Mine are the loudest thing in my system but still very quiet. Those that say silent must have a seemingly loud office, idk. But they're still the quietest pumps I've ever used in a PC.
If air gets in them then they're annoying but once bled they are pretty good, even better if you decouple them from the chassis
Power via molex the 4 pin is mostly for PWM control and/or RPM monitoring (depends what you have)
IN HONOR OF SYRILLIAN, R.I.P.
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
2 year anniversary In Remembrance of a Great - RIP Syrillian
Overkill FreeNAS
(11 items)
Play Server
(10 items)
Intel i7 3930k @4.8-5.2
Asus Rampage IV Black Edition
nVidia Titan XP
Corsair Dominator Platinum 32GB
Intel 750 400GB
Intel 750 1.2TB
Corsair AX1200i
2x Swiftech D5 w/ EK Dual Pump Top
XSPC EX480, EX360 & 2x Phobya 1080
EK Supremacy EVO CPU Block
EK Advanced 250mL Res
Lamptron FC-5V2
EK Rampage IV BE Water Block
Copper Tubing w/ push fittings
EK-FC Titan XP Copper/Acetal
Silverstone TJ07, heavily modified
Operating System
Windows 10 Pro
Samsung U28D590D 4K
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Sennheiser HD595 / HD428 / HD280
Audio
Corsair SP2500
Other
Mellanox Connectx-2 10Gb SFP+ NIC
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
12x HGST 4TB CoolSpin
6x WD Red 8TB
SanDisk Ultra II 960TB SSD
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
Intel Xeon L5640
Intel Xeon L5640
Dell R710 Mobo
Hynix 144GB DDR3 ECC PC3L-10600R
Intel X25-M G2 80GB
Redundant 840W PSU
Dell 710 2.5" - Google Search Appliance
Other
Other
Dell Perc H700 Raid Controller
Other
Dell iDRAC6 Enterprise
deafboy is offline
post #10 of 11 (permalink) Old 05-06-2019, 02:36 PM
Rep: 0
Buiy last week Watercool D5 Vario, its at speed 2, no noise or vibrations.
Use flex tube 10mm and only a Heatkiller IV WB, so not much strain here.
Din`t try yet full speed......
Mordorr is offline
