Is this corrosion? - Overclock.net - An Overclocking Community
Is this corrosion?
post #1 of 27 (permalink) Old 04-21-2019, 10:59 AM - Thread Starter
CrysisEnthusiast's Avatar
Rep: 0
Is this corrosion?
Hello!
I'm wondering if you guys think this is corrosion or is it just copper oxidation? Don't mind the dust in certain areas.
Current Rig
(21 items)
Intel Core i7 3930K
ASUS ROG Rampage IV Extreme
Gigabyte Geforce GTX 980 Ti
16GB (4x4GB) Corsair Dominator GT Quad Channel @2133Mhz
Samsung 840 Pro 256GB (OS)
Intel 530 180GB
Intel 510 120GB
Seagate SSHD 1TB
Enermax Platimax 1200W
Koolance CPU-380I Block
2 x Alphacool White UT60 360mm Radiators
EK-FC Titan X Water Block
Bitspower Crystal Link tubing
Caselabs Mercury S8 White
Operating System
Windows 10 64-bit
ASUS PB278Q
Keyboard
Logitech G910 RGB
Mouse
ASUS ROG Eagle Eye
Mouse
ASUS ROG
Audio
Audio Technica ATH-M50
Audio
Bayerdynamic DT 770 Pro 250ohm
CrysisEnthusiast is offline
post #2 of 27 (permalink) Old 04-21-2019, 11:32 AM
gothicVI's Avatar
Rep: 0
Looks fine IMHO.
Rads are usually not coated or painted inside in order to not loose out on efficiency.
Gesendet von meinem Moto G (5) Plus mit Tapatalk
gothicVI is offline
post #3 of 27 (permalink) Old 04-21-2019, 11:38 AM
PC Evangelist
ZealotKi11er's Avatar
Rep: 1806 (Unique: 1179)
All is good.
Yamato
(10 items)
Ishimura
AMD Ryzen 7 3700X
ASUS TUF Gaming X570-Plus (Wi-Fi)
AMD Radeon RX 5700 XT
G.SKILL Trident Z RGB (2x8GB) DDR4 3200MHz CL14
Samsung SM961 512GB
HGST DeskStar NAS 6TB
EVGA SuperNOVA 750 P2
Gamdias Chione M1A-280R
Fractal Design Meshify C TG
Operating System
Microsoft Windows 10 Pro 64 Bit
Intel Core i7-3770K @ 4.8GHz
ASRock Z77E-ITX
AMD Radeon Vega Frontier Edition
AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
SanDisk Ultra II 960GB
Toshiba X300 5TB
EVGA SuperNOVA 750 G3
Corsair H100i GTX
Fractal Design Define Nano S
Operating System
LG OLED55C7P
Keyboard
Cooler Master MasterKeys MK750
Mouse
Finalmouse Air58 Ninja
ZealotKi11er is offline
post #4 of 27 (permalink) Old 04-21-2019, 11:44 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
That’s just unpainted areas of the fins...normal
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #5 of 27 (permalink) Old 04-21-2019, 02:05 PM - Thread Starter
Rep: 0
Quote: Originally Posted by ZealotKi11er View Post
All is good.
Quote: Originally Posted by gothicVI View Post
Looks fine IMHO.
Great to know. Thanks for the replies
Current Rig
(21 items)
Intel Core i7 3930K
Intel 530 180GB
Intel 510 120GB
Seagate SSHD 1TB
Operating System
Windows 10 64-bit
ASUS PB278Q
Keyboard
Logitech G910 RGB
Mouse
ASUS ROG Eagle Eye
Mouse
ASUS ROG
Audio
Audio
post #6 of 27 (permalink) Old 04-21-2019, 02:52 PM
white owl's Avatar
Rep: 136 (Unique: 103)
Copper doesn't corrode without using some pretty potent stuff. Steel corrodes.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #7 of 27 (permalink) Old 04-23-2019, 07:12 AM
Pinnacle Fit's Avatar
Rep: 24 (Unique: 18)
That’s not corrosion.
This is corrosion: nickel plating corroded to reveal copper underneath. I found that nickel coating on some of my stop plugs elsewhere.
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
post #8 of 27 (permalink) Old 04-23-2019, 08:12 AM
NewUser16's Avatar
Rep: 56 (Unique: 37)
That's nasty, welcome to cheap EK nickle plating Just curious what liquid have you used, there is a reason I'm asking if you don't mind and how long have you run that before it happen
NewUser16 is offline
post #9 of 27 (permalink) Old 04-23-2019, 08:27 AM
Packet Pusher
Renegade5399's Avatar
Rep: 230 (Unique: 145)
Dang Pinnacle!
This is why I only use coolants and/or additives for automobiles. In almost 20 years I have not had plating come off or a loop corrode even with dissimilar metals.
My Sauce Is Much 13373|2 Than Yours
What's in your hardware wallet?
[Gigabyte Aorus 1080 Ti Owner's Club]
Project Blackout
(24 items)
i9 7900X Delidded
ASUS TUF X299 Mark 1
EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING
G.SKILL Trident Z Royal Series 16GB - Samsung B-die DDR4 4000
G.SKILL TridentZ RGB Series 16GB - Samsung B-die DDR4 4000
4x 1TB Western Digital Black
2x 480GB Kingston HyperX Savage SSD
2x ADATA Ultimate SU800 1TB 3D NAND
Intel 660p Series M.2 2280 1TB PCI-Express 3.0 x4
INTEL® RAID ADAPTER RSP3DD080F
2x 2TB Western Digital Green
CORSAIR HX Series HX1000
Custom Water Cooling Setup
Bitspower MonoBlock ASX299TUF RGB-Nickel
Thermaltake Core X71 Tempered Glass Edition Black
Operating System
Winders 10 Pro 64bit
Pixio PX276h 27"
Acer GN276HL 27"
HP EliteDisplay E222 22"
Keyboard
Corsair K95 RGB PLATINUM - Cherry MX Speed - Gunmetal
Mouse
HP Omen Reactor
Mousepad
Corsair Gaming MM800 RGB Polaris
Audio
Sades SA926 Gaming Headset
Renegade5399 is offline
post #10 of 27 (permalink) Old 04-23-2019, 08:28 AM
ezveedub's Avatar
Quote: Originally Posted by Renegade5399 View Post
Dang Pinnacle!
Seen it happen with auto coolant as well....
i9 9900K
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
