EK Supremecy Evo Poor Contact With CPU? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 26 (permalink) Old 04-24-2019, 06:59 AM
Overclocker in training
ThrashZone's Avatar
Rep: 119 (Unique: 79)
Quote: Originally Posted by BradleyW View Post
The contact doesn't seem right to me. No paste on the right side. The CPU I'm mounting it on is the 9900K.
Should I attempt to lap the surface? (Never lapped before).
The mounting pins also look like they are pointing off in different directions, unless it is trick of the eye?
Surface of the CPU block has lots of light swirl marks under a strong light.
See images, thank you.
Hi,
No 7700 mentioned I can see
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #12 of 26 (permalink) Old 04-24-2019, 07:29 AM
skupples's Avatar
Rep: 630 (Unique: 342)
I thought both 97 n 99 were glued n timed woops.
skupples is online now
post #13 of 26 (permalink) Old 04-24-2019, 07:36 AM
ThrashZone's Avatar
Hi,
Nope 99..k & x series are both back to solder
So unless the missing op has bucks to burn lapping or delid is not recommended.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #14 of 26 (permalink) Old 04-24-2019, 08:09 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Is this CPU running too hot or higher than 10c delta across all cores? Doesn’t see any mention of what it running at....so might be non issue currently.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #15 of 26 (permalink) Old 05-03-2019, 11:56 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
Did you figure this one out yet as to why contact wasn't even?
EKWB Forum Rep
EKJake is offline
post #16 of 26 (permalink) Old 05-22-2019, 06:28 AM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1560 (Unique: 1018)
I tried the all-round-performance Jet Plate which was very thin. It helped a bit with the contact, but no real performance difference.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #17 of 26 (permalink) Old 05-22-2019, 06:57 AM
Pinnacle Fit's Avatar
Rep: 23 (Unique: 17)
I’m confused-are you asking if there’s poor contact because the CPU runs hot? Because that’s the way the 9900k is, especially because it draws so much power.
There’s plenty of YouTube videos where they were reaching 80 or higher even with a water block.
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is online now
post #18 of 26 (permalink) Old 05-22-2019, 03:46 PM - Thread Starter
Programmer
BradleyW's Avatar
I'm asking about the poor physical contact between the block and IHS purely from my TIM and mount inspection (as seen in OP).
Although switching from the 115x Jet Plate to the general purpose Jet Plate as given slightly better contact, I'm worried that using the wrong Jet Plate will degrade performance. I'm not sure how a Jet Plate does effect performance or if one is even needed.
EK say to use 115x for 115x CPU's, but I hear the 9900K is concave compared to previous 115x CPU's which are convex.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #19 of 26 (permalink) Old 05-22-2019, 04:22 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 417 (Unique: 280)
The jet plate would have absolutely no bearing on mounting pressure or contact. It changes only the liquid flow internally.
ciarlatano is online now
post #20 of 26 (permalink) Old 05-22-2019, 04:33 PM - Thread Starter
Programmer
BradleyW's Avatar
Oh I see. I was advised on page 1 to change to the thinnest Jet Plate to allow for better physical contact between the block and IHS. The user suggested that a thinner plate would add more flex to the block to compensate for any high points on the CPU's IHS.
Based on the information you've given me, I'll stick with the 115x Jet Plate.
Will I benefit from using the Goofy position on my 9900K or is it not worth it?
Last but not least, can adding dye to a loop reduce thermal performance?
Thank you.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
