EK Supremecy Evo Poor Contact With CPU? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 26 (permalink) Old 05-22-2019, 04:44 PM
Pinnacle Fit's Avatar
Rep: 23 (Unique: 17)
Quote: Originally Posted by BradleyW View Post
Oh I see. I was advised on page 1 to change to the thinnest Jet Plate to allow for better physical contact between the block and IHS. The user suggested that a thinner plate would add more flex to the block to compensate for any high points on the CPU's IHS.
Based on the information you've given me, I'll stick with the 115x Jet Plate.
Will I benefit from using the Goofy position on my 9900K or is it not worth it?
Last but not least, can adding dye to a loop reduce thermal performance?
Thank you.
Just my opinion - if you’re going to commit to any warranty voiding action like lapping, you might as well go all the way and delid. I just did yesterday. Provided you don’t use the razor blade and you get the apparatus, it’s pretty hard to screw up.
Sent from my iPhone using Tapatalk
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
Gigabyte Z390 Aorus Master
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
post #22 of 26 (permalink) Old 05-22-2019, 04:51 PM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
I thought about lapping the block seen as I've had it for years, so no warranty. I'm going to hold off on IHS removal. I appreciate the benefit... and the equipment that's available today to achieve removal, but it's a risk I won't be taking for the foreseeable. I appreciate your advice though.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #23 of 26 (permalink) Old 05-22-2019, 04:58 PM
I understand, and respect that. If you change your mind, there’s plenty of support out there.
GTX 1080Ti FE
post #24 of 26 (permalink) Old 05-22-2019, 05:02 PM - Thread Starter
Programmer
BradleyW's Avatar
Thank you.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
post #25 of 26 (permalink) Old 05-23-2019, 04:45 AM
Vlada011's Avatar
Rep: 39 (Unique: 29)
Your block is fine and your CPU contact is fine.
Mine is very similar. Idle temps depend of ambient temps, if outside is 15-17C idle Temp of CPU is 25-26C.
That mean contact is normal. Thermal paste don' need to spread in all corners of CPU and to cover 100% of CPU if you put thermal paste in middle.
You can spread with plastic part all over CPU if you want.
Vlada011 is offline
post #26 of 26 (permalink) Old 05-23-2019, 08:53 PM
Ashcroft's Avatar
Rep: 88 (Unique: 70)
Quote: Originally Posted by ThrashZone View Post
Hi,
Unlike 7900x or probably 9900x the 9900k is more vertical than horizontal die so the evo would probably perform better in the default or upside down position which ever pipes better
Horizontal/ goofy worked pretty good on a 7900x though.
They said that regular or upside down was identical.
But now that I think of it...if the TIM worked as intended, there should be an even distributed conduction of heat from die to IHS, so the orientation of the block should theoretically be irrelevant.
I have to reread the article but it would stand to reason that a delidded cpu using liquid metal between die and ihs should have near 100% heat conduction, so the block orientation shouldn’t be relevant.
Maybe I’m assuming too much.
It does have 100% heat conduction. All the heat produced is carried away.
What we are interested in is the difference in temp required to do that. Physics demands there be a difference in temp for heat to flow, but better conductors allow closer to zero temp difference.
A heat sink made of silver may require a 5c Delta to remove 100 Watts while an aluminium one needs 10c for the same 100 Watts.
Ashcroft is offline
