EK Supremecy Evo Poor Contact With CPU? - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 04-22-2019, 07:28 PM - Thread Starter
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
The contact doesn't seem right to me. No paste on the right side. The CPU I'm mounting it on is the 9900K.
Should I attempt to lap the surface? (Never lapped before).
The mounting pins also look like they are pointing off in different directions, unless it is trick of the eye?
Surface of the CPU block has lots of light swirl marks under a strong light.
See images, thank you.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #2 of 26 (permalink) Old 04-22-2019, 09:01 PM
Overclocker in training
ThrashZone's Avatar
Rep: 132 (Unique: 85)
Hi,
Might want to spin test the cpu it might have a hump on it.
You might also try the ek evo with the thinnest razor blade jet plate or without one period might give it more flex to get around the chips hump.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 26 (permalink) Old 04-23-2019, 02:06 AM
Vlada011's Avatar
Rep: 39 (Unique: 29)
It's not to bad.
Vlada011 is offline
post #4 of 26 (permalink) Old 04-23-2019, 08:50 AM
Pinnacle Fit's Avatar
Rep: 23 (Unique: 17)
You can try lapping, but try first using a ‘goofy’ orientation ‘90 degree’ orientation of the block. Xtremerigs https://www.xtremerigs.net/2014/08/2...on-definition/
https://www.xtremerigs.net/2018/10/1...intel-and-amd/
Sent from my iPhone using Tapatalk
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
Gigabyte Z390 Aorus Master
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
post #5 of 26 (permalink) Old 04-23-2019, 10:12 AM
ThrashZone's Avatar
Hi,
Unlike 7900x or probably 9900x the 9900k is more vertical than horizontal die so the evo would probably perform better in the default or upside down position which ever pipes better
Horizontal/ goofy worked pretty good on a 7900x though.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #6 of 26 (permalink) Old 04-23-2019, 10:21 AM
Quote: Originally Posted by ThrashZone View Post
Hi,
They said that regular or upside down was identical.
But now that I think of it...if the TIM worked as intended, there should be an even distributed conduction of heat from die to IHS, so the orientation of the block should theoretically be irrelevant.
I have to reread the article but it would stand to reason that a delidded cpu using liquid metal between die and ihs should have near 100% heat conduction, so the block orientation shouldn’t be relevant.
Maybe I’m assuming too much.
GTX 1080Ti FE
post #7 of 26 (permalink) Old 04-23-2019, 11:56 AM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
the swirls definitely don't matter.
n if you're gonna mess with lapping, you might as well just get a delid kit + pre-lapped all copper IHS.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is online now
post #8 of 26 (permalink) Old 04-23-2019, 05:36 PM
This
GTX 1080Ti FE
post #9 of 26 (permalink) Old 04-23-2019, 08:27 PM
ThrashZone's Avatar
Hi,
Problem might be op doesn't want to delid his 9900k soldered chip
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 26 (permalink) Old 04-23-2019, 08:42 PM
Hi,
Then I misread it...I thought he said 7700k rather than 9900k. It can still be done but it doesn’t yield much benefit to delid a chip that’s already got STIM, so good call on OP not deluding it.
GTX 1080Ti FE
