Thoughts on water cooling for the 2080ti? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-25-2019, 12:00 PM - Thread Starter
Chatham's Avatar
Rep: 0
It's a weird one since some fo them already COME with heir own "Watercooler," whole there are also various clear plastic coolers (the name of them escapes me) all over amazon. Which is strange to see, given that I had to send away to China and wait 2 months for my plastic cooler for my Titan V. Are people with 2080tis getting these? it doesn't seem...I mean, given the tI paid almost $4k for the tita, YES, wanted to protect it. But for a card that barely costs over $1k? Don't get mr wrong, still expensive, but isn't better to just take out insurance and root the side rather than buy a $250+ water cooler?
(FYI-THIS BOTHERS ME, THIS IS NOT MY 6TH POSTS HERE, I WAS NEARING 1.3K OVER THE PAST 3 YEARS WHEN I LOST MY EMAIL ADDRESS AND RHUS MY NAME AND PASSWORD AND HAD TO SET UO A NEW ADDY AND PASSWORD).
Chatham is offline
post #2 of 8 (permalink) Old 04-25-2019, 12:34 PM
LTSC Consiglieri
skupples's Avatar
Rep: 647 (Unique: 349)
watercool everything.
n use barbs & worm clamps. (save a thousand $)
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #3 of 8 (permalink) Old 04-25-2019, 02:20 PM
Section31's Avatar
Rep: 14 (Unique: 12)
Depends on you. You wont gain extra performance just cooler keep that in mind.
Compression fittings are similar price to barbs now. Don't cheap out for stuff you will use in the future.
Section31 is offline
post #4 of 8 (permalink) Old 04-25-2019, 03:17 PM
Invalid Media
J7SC's Avatar
Rep: 45 (Unique: 24)
...if any GPU needs it, RTX 2080 TI are the ones for water-cooling (I got two of them, per sig link).
To qualify that statement, you don't actually 'need - need' w-cooling, but they will respond exceptionally well via the temp / power limit / boost-clock algorithms in the bios / driver. Put even simpler, any electronic item that can draw between 300w and 400w (like the 2080 Ti) needs a lot of sustained cooling. That doesn't mean it will blow up without it, but if your budget / patience allows, I would go for w-cooling the 2080 Ti. Even when benching with Port Royal etc, my two cards stay in the mid 30ies C which no matter what is better for them in the long run than constantly running at 50c +.
Just a note of caution though...give the sheers size of the RTX die and various distributed VRAM on those cards, make sure NOT to over-tighten an aftermarket w-block
J7SC is offline
post #5 of 8 (permalink) Old 04-25-2019, 04:09 PM
Section31's Avatar
About the RTX2080TI, I actually kind of regret getting the RTX2080TI as that was what holding me back from getting an caselabs sma8a. I was about to order the sma8a revision in Feb last year and that would have made the cutoff for delivery. Even had caselabs not gone under, I would have gotten the case instead of marginal upgrade in GPU from 1080ti. I am waiting for the high end 7nm Nvidia/Intel GPU's myself.
post #6 of 8 (permalink) Old 04-25-2019, 04:12 PM
Slovak_Killer
dangerSK's Avatar
Rep: 14 (Unique: 11)
Watercool it, why not ? Better temps, bigger OC potential and silent system.
LN2 Beast
(6 items)
The Red Ice
(4 items)
i9 9980XE
Evga X299 Dark
MSI RTX 2080Ti Lightning Z
G-skill 3200 c14 Trident Z
Kingpin F1 Dark
EKWB Loop
Ryzen 3900X
ASUS ROG Crosshair VIII Impact
Galax 1080Ti OC Lab
EKWB CUSTOM LOOP
dangerSK is offline
post #7 of 8 (permalink) Old 04-26-2019, 01:47 AM
Abaidor's Avatar
Rep: 3 (Unique: 3)
I was ready to get the 2080Ti but given the lack of stock initially, the fact I had to get a waterblock (all custom loop here) and the ridiculous pricing (especially at launch for AIBs) made me wait....Yet, I have a huge back log of older titles I WANT to play (i.e. playing DOOM 2016) and a 1080Ti that plays happily at 2090/13000 mem.
I was away from gaming for roughly 10 years so the titles I have work fine at my 4K monitor and by the time I am done with them the new cards will be out. I am not gaming much anyway.
X299 - i9 7940X
(24 items)
i9-7940X
Asus Rampage VI Extreme
Asus Strix GTX 1080Ti OC
64GB Trident Z RGB
Samsung M.2 960Pro 512GB
WD Gold 10TB
WD Red 4TB
WD RED 4TB
WD Green 2TB
WD Green 2TB
WD Green 2TB
Corsair AX1500i
MO-RA 420 Pro
EK RVIE Monoblock
Phanteks Asus Strix 1080Ti GPU Block
EK-XTOP Revo Dual D5 PWM
Bitspower Fittings
Heatkiller 200mm Reservoir
9X Corsair ML140 Pro Fans
Coolermaster Cosmos 2
Operating System
Windows 10 Pro
BenQ SW320 32" 4K
Mouse
Logitech MX Master 2S
Mouse
Abaidor is offline
post #8 of 8 (permalink) Old 05-04-2019, 12:01 AM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
If you still want one, join the CaseLabs FB group. They've helped people track the cases down.
EKWB Forum Rep
EKJake is offline
