Custom Loop Help - Overclock.net - An Overclocking Community
Custom Loop Help
post #1 of 8 (permalink) Old 04-25-2019, 03:27 PM - Thread Starter
Rep: 1 (Unique: 1)
Custom Loop Help
Planning on building a soft-tube custom loop (not soon, mabye after zen 7nm), for a fun basis, and not because I need more cooling, this is what I have so far. My goal is to have efficent price/performance, aswell as aethetics
Case:
Meshify C
CPU etc will be added lator, planning on either AM4 or LGA1151, GPU will be someting midrange (~300-400$)
1x Barrow WB (aurora or something like that) - 27$
1x 280mm HardwareLabs Nemisis GTS 280 X-flow (less restriction + better runs) - 63$
1x EKWB DDC 3.1 100ml Pump/res (DDC is more compact, and is cheaper than D5, *** are pumps so expensive) - 110$
1x Mayhems Blitz Pro (to clean rad stuff etc b4 b/c I want to use pastel and don't want to gunk it up) - 24$
2x 1L Mayhems Pastel White (looks nice, do I need 2L for just a 280mm+cpu+gpu+100ml res?) - 13.25 ea.
5ft Mayhems soft tubing (cheap, what else to say) 2.5$ total
12x Barrow Fittings (some extras, and cheap too) 2.25 ea.
1x Phanteks T-splitter (for drain) 8$
1x Barrow Drain (cheapest I could find) 11$
2x XSPC Male-Male 10mm (for drain, don't want to use a bunch of fittings) 2.5ea
1x XSPC plug (for drain) 2$
2x Phantkes 140mm fans (bought)
any noticeable errors, and any cheaper parts you'd reccommend? Also, is there any pastel alternatives which would be better than mayhems paste?
and what other pump options are that besides DDC, D5, EK's SPC (looks really weak compared to even the slowed DDC 3.1), alphacool's custom pump (is it good?), and swiftech's offering (is it good?)
Please tell me if there are any issues.
firewrath9 is offline
post #2 of 8 (permalink) Old 04-25-2019, 03:36 PM - Thread Starter
Rep: 1 (Unique: 1)
Actually I was looking around and found this:
http://www.performance-pcs.com/barro...e.html#Details
I'm not a fan of molex, so if i replace the molex with a SATA (solder the 12v and the ground toghther) it should be fine, right? (or make a sata to molex cable(i have some sata female and male connectors, and some molex female and male conectors)
and use a male to male G1/4 to attach that to this:
http://www.performance-pcs.com/barro...Specifications
I should be good right?
post #3 of 8 (permalink) Old 04-26-2019, 05:59 AM
OneFunGenesis's Avatar
Rep: 13 (Unique: 12)
Yea. So, looking at this I like everything except some of the prices on the fittings are too low (unless you are using barb and not compression fittings, but then I don't see hose clamps which is just good practice). Also, you should look to add another 120mm of rad space if you are cooling both the GPU and CPU. Broscience suggests 120mm of rad space per each component cooled plus 120mm of overhead. If just cooling the CPU, you should be fine as long as you aren't running threadripper.
I am not sure your source for parts, but ModMyMods has a lot of barrow products and are run be friends of mine and some of the coolest people you'll ever meet. Just a shameless plug for them.
OneFunGenesis is offline
post #4 of 8 (permalink) Old 04-26-2019, 06:08 AM - Thread Starter
Rep: 1 (Unique: 1)
Those are Compression fittings, all of these are from PerformancePCs.I'll take a look at ModmyMods. I'll have extra fittings, tubing, and fluid, and I have some nice 120mm fans, so if I get bad temps, I'll add a TX120 rad to the back.
Thanks!
Looking at ModMyMods, The only pumps they seem to have are alphacool and regular D5s/DDCs, but D5s/DDC are quite expensive there (70-100$),and I'm using Mayhems Pastel, and alphacool says that using pastel violates warranty.
post #5 of 8 (permalink) Old 04-26-2019, 06:15 AM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
Makes you think twice at what fluids to use doesn't it
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #6 of 8 (permalink) Old 04-26-2019, 06:36 AM
Shawnb99's Avatar
Rep: 23 (Unique: 15)
Thanks!
Most if not all will say using other fluid then their own voids the warranty. That has little meaning, it’s mostly to get you to buy their fluids.
Does it say why Pastel voids the warranty but other dyed fluid doesn’t?
The number 1 piece of advice I can give us don’t cheap out, specially when it comes to fittings or the pump. You’ll regret it later.
Also look at adding a flow meter and temp sensor to your loop. Kinda hard to judge how effective it is if you can’t tell the flow rate and temp of the water.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #7 of 8 (permalink) Old 04-26-2019, 06:47 AM
I have had Barrow fittings in my rig for 3 years. Love them. Not a single issue. I live 20 mins from ModMyMods so I just walk in and shop lol. As to the whole Pastel and warranty thing...Mayhems (Mick) has been kinda going back and forth with them about how there is nothing wrong with Pastel that would void any warranty.
I have also been running pastel for 3 years with no adverse affects. I believe for compressions, you are about $1 too low maybe? Of the cost came down since I looked 3 months ago lol
post #8 of 8 (permalink) Old 04-26-2019, 01:50 PM - Thread Starter
Rep: 1 (Unique: 1)
http://www.performance-pcs.com/fitti...al-Information
its barrowch, which is basically barrow.
Tags
custom loop , soft tubing , Watercooling
