Mayhems Blitz failed - loads of junk in my loop - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 04-26-2019, 06:36 AM - Thread Starter
Goooober's Avatar
Rep: 0
When i got my two new Hardware Labs radiators i spent ages flushing them out with water and vinegar - i must have filled and emptied them 20 times. I was still getting small flecks of black coming out so i bought Mayhems Blitz part 1. I followed the instructions to a tee and flushed the rads after a good 10 times or so.
I just finished draining the loop after it had been up and running about a week and found LOADS of black flecks in the fluid.
I just removed the GPU block and it really looks to me like the micro fins are already getting blocked up. I assume the CPU block will be the same. I've tried to take pictures but my camera is just too crappy to really show it.
I'm more concerned about my pump, specifically how to clean it and how to spot any damage.
This whole thing has been such an ordeal i wish i'd never bothered.
Goooober is offline
post #2 of 18 (permalink) Old 04-26-2019, 06:40 AM
Shawnb99's Avatar
Rep: 14 (Unique: 10)
Did you run part 2 as well?
What Radiators?
My Rig
(21 items)
Intel Core i9-9900K
ASUS Maximus XI Formula
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
Samsung 860 EVO 1TB
Samsung 850 EVO 1TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
Swiftech MCP35X2 with MCP35X2 Heat Sink
2 x Hardware Labs Black Ice Nemesis 360GTR
2 x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9 x Noctua NF-S12A PWM
2 x Noctua NA-A15 PWM
24 x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Shawnb99 is offline
post #3 of 18 (permalink) Old 04-26-2019, 06:42 AM
Overclocker in training
ThrashZone's Avatar
Rep: 47 (Unique: 37)
Hi,
Weird both my gtx rads were pretty darn clean although I didn't use vinegar
Might want to add an inline filter off the pump's outlet or cpu inlet...
Vaper
(4 items)
i9-99400x With evo and koolance vrm water blocks
ASUS x299 TUF Mark 2
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
Audio
Insignia 2.0 soundbar HSB318
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
EVGA 1000w P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
Audio
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is online now
post #4 of 18 (permalink) Old 04-26-2019, 06:43 AM
skupples's Avatar
Rep: 525 (Unique: 296)
skupples is offline
post #5 of 18 (permalink) Old 04-26-2019, 06:43 AM - Thread Starter
Goooober's Avatar
Rep: 0
What Radiators?
Only part 1. I was under the impression part 2 was not need on brand new parts. Rads are hardware labs.
Goooober is offline
post #6 of 18 (permalink) Old 04-26-2019, 06:45 AM
skupples's Avatar
time to take two steps back then.
Mayhem's doesn't just simply fail
skupples is offline
post #7 of 18 (permalink) Old 04-26-2019, 06:49 AM
NewUser16's Avatar
Rep: 36 (Unique: 23)
Perhaps, maybe the flakes are from fittings or other components of your loop. About year or so ago I have reassembled one of my system with 4x 480 Black Ice Nemesis and they were clean already as I have used them for few years. My plan got delayed by weeks so when I got back to it afterwards I thought I would flash my rads again, they where spotless clean.
After running my system for a while I could see small black flakes in reservoir tube I was puzzled but after remembering I added few new Bitspower fittings and other Aquacomputer components in which some of their finish have got lose, it's to be expected (around threads), no big deal I flashed my system with Blitz #2 and my system was clean again.
NewUser16 is offline
post #8 of 18 (permalink) Old 04-26-2019, 07:17 AM
Ashcroft's Avatar
Rep: 80 (Unique: 63)
What sort of pump are you talking about?
If it's a D5 or DDC there is nothing to worry about as far as damage. The bearing design and the nature of centrifugal pumps keeps the very small contact area free of foreign bodies.
To clean just rinse it out and maybe wipe the impeller and bowl. They are easy to clean.
Ashcroft is offline
post #9 of 18 (permalink) Old 04-26-2019, 07:26 AM
NewUser16's Avatar
In watercooling there are things to consider: maintenance as annual routine and unexpected occurrences which can lead to disassembly of your system over again if perhaps you need to troubleshoot. Watercooling is great for many reasons but it can have its downfalls, they don't have to be dramatic if you set your mind into positive mode...things happens.
There was a time I have troubleshoot one of my system for over 16-17 months, talking frustrated and discouragement, its all about positive attitude
post #10 of 18 (permalink) Old 04-26-2019, 07:36 AM - Thread Starter
Goooober's Avatar
Rep: 0
It's a D5 PWM pump from EK.
I dont know how to clean the micro fins on my blocks. They're so narrow i'm struggling to get the toothbrush bristles to get in between them.
Also, the jet plate on the GPU block (bykski) seems to be non-removable so i cant underneath it to clean.
Goooober is offline
