running a custom loop 24/7? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 61 (permalink) Old 04-27-2019, 07:10 PM
ttnuagmada's Avatar
Rep: 15 (Unique: 15)
D5 is a pretty simple design, I would imagine one would run pretty much indefinitely as long as you don't run it dry.
ttnuagmada is offline
post #12 of 61 (permalink) Old 04-30-2019, 08:30 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Laing D5 and DDC pumps run well past their rated hours of life....only issue with DDC is cooked mainly at the bottom with the PCB, so 18 watts units can get hotter than a 10-12 watt unit, which those barely get hot. D5 is cooled from the coolant, as it has the metal inner that contacts the coolant. I wouldn’t trust any other pump other than a D5 or DDC for longevity at this point. Lots of Chinese clones out there, but I don’t trust them.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #13 of 61 (permalink) Old 04-30-2019, 10:26 PM
( ━☞´◔‿ゝ◔`)━ ☞
Kokin's Avatar
Rep: 427 (Unique: 365)
I've been using my DDC (MCP35X) for 5-6 years although at about 60% of max speed and has always had air running through its heatsink. It runs 24/7 for majority of the year except for when I'm out on vacation or business travel. As others have mentioned, as long as you stick with a genuine D5 or DDC pump, it will last through the rated lifetime.
Black Heart
(22 items)
AMD Ryzen 9 3900X 12c/24t
Asus ROG Crosshair VIII Impact X570
EVGA GTX 1080Ti FTW3 11GB
G.Skill TridentZ DDR4 2x16GB 3200MHz 14-14-14-34 1.35V
Inland Premium 2x2TB PCIe 3.0 NVMe SSD in Raid0
Crucial MX500 2TB Sata SSD
Seasonic Prime 600W Titanium Fanless SSR-600TL
EK-Supremacy EVO RGB - Acetal+Nickel
EK-FC1080 GTX Ti FTW3 - Nickel
Phanteks Glacier R160 Reservoir
Swiftech MCP35X
Hardware Labs Black Ice Nemesis 280GTS White
Hardware Labs Black Ice Nemesis 240GTS White
Noctua NF-A12x25 PWM (4x rad intakes, 1x case exhaust)
Case Labs Mercury S3
Operating System
Windows 10 Pro
Alienware AW3418DW 34" Ultrawide IPS 3440x1440 120Hz G-Sync
Qnix QX2710 PLS 2560x1440 120Hz
Keyboard
WASD CODE V2 87-Key [MX Green + /dev/tty Keycaps]
Mouse
Logitech G Pro Wireless
Audio
Sennheiser HD 6XX
Audio
Micca OriGen G2 USB DAC/Amp
Kokin is offline
post #14 of 61 (permalink) Old 05-01-2019, 12:29 AM
RIP OCN
Rep: 28 (Unique: 21)
Quote: Originally Posted by Gunderman456 View Post
However, if a pump fails on idle the computer should not overheat to the point of component failure. If for some reason it does hopefully the mobo/CPU will just shut off the computer anyway.
You can connect the rpm report cable of some pumps to the cpu fan header on the motherboard and change settings in bios to shutdown the computer if the cpu fan rpm drops below a certain threshold. I had mine set up like that for a long time and never had any issues. If my pumps stopped the system would gracefully shutdown. Having two pumps also helps with that issue, it's unlikely both pumps will fail at the same time.
anti-clockwize is offline
post #15 of 61 (permalink) Old 05-01-2019, 08:11 AM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
Good to know that thanks. I don't think my pump has that cable. Depending on your build also, I imagine that cable is very long as well since for instance my solo pump sits at the bottom of the case.
Should PC hardware companies regain their senses, I can't wait to build a new system and see and experience, in detail, where hardware is at.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #16 of 61 (permalink) Old 05-01-2019, 10:33 AM
Rep: 0
I tend to disagree.
Installed yesterday my first D5 pump Watercool D5 Vario, but before i was using a EHEIM 1046, 24/7 (220V) directly connected to electricity, for more than 12 years even with PC OFF.
Please don`t put a D5 on same level of reliability as a EHEIM pump.
Mordorr is offline
post #17 of 61 (permalink) Old 05-01-2019, 05:30 PM
Retired Staff
animal0307's Avatar
Rep: 116 (Unique: 103)
Quote: Originally Posted by Mordorr View Post
I tend to disagree.
That pump isn't a standard PC water cooling pump. There are tons on pumps in the aquarium world but the D5 and DDC lines have been adopted by PC enthusiasts and there are after market parts tailored to PC cooling. When you artificially limit your scope to PC specific water pumps the D5 and DDC's are the way to go.
animal0307 is offline
post #18 of 61 (permalink) Old 05-01-2019, 05:46 PM
Food Editor
skupples's Avatar
Rep: 719 (Unique: 378)
no issues,
I'm sure its already been said, but for long term use i'd highly recommend Mayhem's biocide+ and inhibitor+ drops(both bottles), then follow the directions. It's the cheapest and cleanest solution for long term use. If you don't take that advice, than at least use Mayhem's X1 clear/UV line. (the other top shelf guys just rebottle his stuff these days)
if you really wanna take it to the next level for longevity & system health, so your blocks come out YEARS later looking brand new - get his blitz kit (both parts 1 & 2, like the drops mentioned above) & follow the directions, with a liberal rinse cycle.
Buy distilled by the 6 gallon pack, they'll be ~$5-$10 a pack, depending on your location.
don't over analyse things, or mince over the 1-2%s.
Also if you don't care about looks, you can save an ishton of money buy going barbs & worm clamps (the most secure solution, specially for soft tubing & long term use), thus giving you more money for a better pump, or PC components. Only you and some other bruhs online are gonna see it, n your girl really isn't gonna care if you have barbs, compressions, LEDs that bump to the beat, etc... (LEDs are distracting overpriced fad to bring in new customers!!!)
last bit of advice, Aquaero 6 is the best investment ever, n don't even get the one with the screen, just get the board, so you can stash it wherever best fits a central location for wiring.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #19 of 61 (permalink) Old 05-01-2019, 07:20 PM
Robotic Chemist
Asmodian's Avatar
Rep: 199 (Unique: 133)
I tend to disagree.
I have only had excellent experiences with EHEIM pumps. I have had two 1046 models (12V) and recently got a 1262 (120V) which I never turn off, it doesn't even have a switch. They have all been great, quite and super long lasting. I have not had one die yet. Alphacool has some good accessories targeting water cooling PCs with them as well. EHEIM are definitely my favorite water cooling pumps, especially for 24/7 usage. I had a DDC before getting the first 1046 but it broke after 5-6 years (stopped turning on). I wouldn't recommend DDC for 24/7 use, you want a pump that cools itself with the fluid. My first 1046 is almost 10 years old now and still going strong.
The 1262 is a beast, up to 3400 l/h. It is huge and pulls a crazy amounts of power for a PC water cooling pump but it is still amazing.
I always use pure distilled water with a silver coil in it, and a pure copper/brass loop. The silver coils are cheap and do not get used up and distilled water is cheaper, easier, and works better than anything else, also spills are a non-issue. I have never had any problems and I don't do regular maintenance outside of changing parts (which has never been longer than two years).
"Soldering resistors onto your video card to bypass the manufacturers over current protection kind-of sort-of absolute-definitely voids your warranty"
Desktop
(17 items)
Intel i9-7900X @ 4.7GHz
Asus Rampage VI Apex
2080 Ti
32GB DDR4 4000
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
EK Monoblock + GPU
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Logitech G903 Lightspeed
Mousepad
Logitech G PowerPlay
Audio
Arctis Pro Wireless
Other
Mellanox ConnectX-3 MCX354A-FCCT 40 GbE
Asmodian is online now
post #20 of 61 (permalink) Old 05-01-2019, 10:37 PM
xxicrimsonixx's Avatar
Rep: 477 (Unique: 423)
Definitely D5 pump. Been using mine almost every day for the last 6-7 years and it is still going strong. They are champions. They are often re-branded, so whichever brand of them you get, just find the cheapest with best warranty. They all have the same manufacturer.
Steam/Origin ID: xxicrimsonixx
i7 4930K
ASRock Fatal1ty X79 Professional
Gigabyte Aorus 1080ti SLI
16GB G. Skill Ripjaws Z
2x 250GB Samsung 840 Series SSD RAID 1
2x 3TB Seagate Barracuda 7200.14 RAID 1
Optical Drive
Samsung Burner w/ Lightscribe
Cooler Master Silent Pro 1200W Gold
Custom Watercooling
Cooler Master HAF 922 w/ Dust Filters
Operating System
Windows 10 Professional 64-bit
55" 4K Samsung Curved TV
Keyboard
Roccat Sova Mechanical
Mouse
Roccat Kone XTD
Audio
Glow Amp One > HD650
Audio
Yamaha Receiver + 5.1
Other
Xbox One Wireless Controller
xxicrimsonixx is offline
