running a custom loop 24/7? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 61 (permalink) Old 05-02-2019, 04:22 AM
Rep: 0
Quote: Originally Posted by Asmodian View Post
I have only had excellent experiences with EHEIM pumps. I have had two 1046 models (12V) and recently got a 1262 (120V) which I never turn off, it doesn't even have a switch. They have all been great, quite and super long lasting. I have not had one die yet. Alphacool has some good accessories targeting water cooling PCs with them as well. EHEIM are definitely my favorite water cooling pumps, especially for 24/7 usage. I had a DDC before getting the first 1046 but it broke after 5-6 years (stopped turning on). I wouldn't recommend DDC for 24/7 use, you want a pump that cools itself with the fluid. My first 1046 is almost 10 years old now and still going strong.
The 1262 is a beast, up to 3400 l/h. It is huge and pulls a crazy amounts of power for a PC water cooling pump but it is still amazing.
I always use pure distilled water with a silver coil in it, and a pure copper/brass loop. The silver coils are cheap and do not get used up and distilled water is cheaper, easier, and works better than anything else, also spills are a non-issue. I have never had any problems and I don't do regular maintenance outside of changing parts (which has never been longer than two years).
Agree. EHEIM are a beasts on reliability....more than 10 years working non stop, and before D5 became a thing
I only change now because 1046 was very weak to do the job, and i confess that my D5 Vario on stage 1 is mucchhhhhhh powerfull.
I use car liquid (G12) + destilled water and 1 drop Fairy
No corrosion or strange objects.....
Mordorr is offline
post #22 of 61 (permalink) Old 05-02-2019, 05:25 AM
News Fiend
ryan92084's Avatar
Quote: Originally Posted by Mordorr View Post
I tend to disagree.
Installed yesterday my first D5 pump Watercool D5 Vario, but before i was using a EHEIM 1046, 24/7 (220V) directly connected to electricity, for more than 12 years even with PC OFF.
Please don`t put a D5 on same level of reliability as a EHEIM pump.
Anecdotes are fun . I ran a ddc for 11 years 24/7 in an heat saturated only flushed once loop and it even sat stagnant in storage for a year so it was around for 12 years total. The thing is so old I bought it from Petra's with a Petra's top. Retired it after this recent rebuild out of caution rather than performance issues.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #23 of 61 (permalink) Old 05-02-2019, 05:50 AM
Rep: 0
I must check my paper buy from my EHIEM....maybe i did buy it on 2005....15 years.
Mordorr is offline
post #24 of 61 (permalink) Old 05-02-2019, 06:30 AM
Cloudforever's Avatar
Rep: 60 (Unique: 46)
hopefully this'll help you with your journey -
ive been running my first loop for I think 1 year now, I put distilled water in it, copper loop and it's still super clean. doesnt really get too hot and runs on pump level 3 of 5 (using a XSPC Photon 240 V2 D5 )
Cleanest way to go and least amount of maintenance lol.
i used the drinking water you can buy at the store , i think a liter was 1$ and used about 3 liters total?
what i'd do, just make sure everything is tight and double / triple check.
I thought everything was tight besides the internal tube in the Photon which caused a super small drip leak and I had to end up taking the whole thing apart just to fix it lol.
run it for a few hours and just let it sit and watch for any impurities going into the reservoir before you put it back in your desk, i had mine on the kitchen table by the sink.
Cloudforever is offline
post #25 of 61 (permalink) Old 05-02-2019, 06:34 AM
Shawnb99's Avatar
Rep: 55 (Unique: 36)
ive been running my first loop for I think 1 year now, I put distilled water in it, copper loop and it's still super clean. doesnt really get too hot and runs on pump level 3 of 5 (using a XSPC Photon 240 V2 )
You’ll need more then just distilled water. Need a inhibitor and some biocide in it.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #26 of 61 (permalink) Old 05-02-2019, 06:38 AM
well yeah, i mean, the liquid itself just water. i do not have biocides in my water, only the silver fittings hooked up to my radiator
post #27 of 61 (permalink) Old 05-02-2019, 07:13 AM
@ OP -
I do want to show you this too - dont mix different metals in your loop, otherwise this'll cause this issue:
https://www.overclock.net/forum/61-w...corrosion.html
post #28 of 61 (permalink) Old 05-02-2019, 09:10 AM
Overclocker in training
ThrashZone's Avatar
Rep: 169 (Unique: 102)
Hi,
I thought even silver and nickel plating could clash.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #29 of 61 (permalink) Old 05-02-2019, 09:21 AM
doritos93's Avatar
Rep: 119 (Unique: 84)
24/7 usually means 24/7 - 365.. big difference between that and what some are reporting to be 24/7
I had 2 XSPC 5.25 bay reservoirs in a machine that was really on 24/7 no exceptions and they both died in two years, almost to the day
MCP655 lasted a little longer but was still less than 5 years
So YMMV because only you know how long the pump will really be on
doritos93 is offline
post #30 of 61 (permalink) Old 05-02-2019, 10:15 AM
Rep: 0
Yie....maybe i should say always on, 365 days...
To the user reporting only using water: Soon or later your system, WB, will create galvanization and will be destroyed.
Even use the most pure water, after been purified at atomic level, soon or later it will create impurities and destroy metals....
At least, put a little car liquid. I use G12 from my VAG car mixed with destilled water and no issues.
Serious.....change that.
Mordorr is offline
