running a custom loop 24/7? - Overclock.net - An Overclocking Community
post #1 of 61 (permalink) Old 04-26-2019, 04:58 PM - Thread Starter
flyinion's Avatar
Rep: 4 (Unique: 4)
Going to be doing my first build with watercooling soon. I plan to do a custom loop with soft tubing to start. Likely using an Alphacool D5 pump (VP655). I haven't seen much on the subject of run times. Is it safe to assume the pumps last for years as long as not at 100% speed and routine maintenance and I could leave the system on 24/7 safely like I do now? Or would I want to start shutting it off when not in use? I do and would continue to shut it off if I was going on vacation or something for an extended time away from it. Just not clear on any reliability issues with 24/7 running.
Ryzen 7 3700X
ASUS Crosshair VIII Hero
EVGA RTX 2080 Super FTW3 Hydro Copper
GSkill Trident Neo
Samsung 970 Evo Plus
Samsung 860 Evo
Seasonic Prime Ultra
Aquacomputer Cuplex Kryos NEXT AM4 Acetal/Copper
Alphacool ST30 360mm Rad V.2
Alphacool Eisbecher D5 150mm Res
Aquacomputer D5 PWM
Barrow G1/4 fittings
Phanteks Enthoo Luxe 2
Operating System
Win10 Pro 64bit
Asus PG279Q
Dell U2414H
Keyboard
Steelseries M750 TKL
Keyboard
Ducky Shine 5 MX Brown
Mouse
Steelseries Rival 700
Mousepad
Steelseries QCK Limited
Audio
Steelseries Arctis Pro + GameDAC
Audio
Schiit Magni 2 Uber
Audio
Schiit Modi 2 Uber
Other
Saitek X52
flyinion is offline
post #2 of 61 (permalink) Old 04-26-2019, 05:08 PM
Shawnb99's Avatar
Rep: 59 (Unique: 40)
Should be no issues running it 100% 24/7 that’s what they are made to do.
I don’t have experience with that model but it shouldn’t be an issue.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #3 of 61 (permalink) Old 04-26-2019, 06:05 PM - Thread Starter
flyinion's Avatar
Rep: 4 (Unique: 4)
Thanks, I kinda figured that was the case but wasn't sure. I couldn't seem to find anything on expected pump life either so I figured I'd ask (not planning to do dual pump or anything). I know at least on my current system with a Noctua D14 cooler even if the fans bite it the passive dual radiator would still keep it alive until I found it, but that wouldn't work with water of course.
Ryzen 7 3700X
GSkill Trident Neo
Samsung 860 Evo
Aquacomputer D5 PWM
Operating System
Win10 Pro 64bit
Asus PG279Q
Dell U2414H
Keyboard
Keyboard
Mouse
Mousepad
Audio
Audio
Schiit Magni 2 Uber
Audio
Schiit Modi 2 Uber
Other
Saitek X52
flyinion is offline
post #4 of 61 (permalink) Old 04-26-2019, 06:19 PM
Invalid Media
J7SC's Avatar
Rep: 75 (Unique: 31)
I have been running five MPC655 pumps (same innards as the Alphacool one) in two builds for about five years straight, with only shutdowns during holidays etc...finally re-configured everything just a few months back after cleaning. Biggest issue is doing a clean initial build (plenty of flushing, including final flushes with distilled water) watching out for 'mixed metals' in the loop, and running the right coolant mix with antimicrobial additives etc.
Regarding 'fail-over', as rare as a failure may be with these setups, you can always put two pumps in a serial arrangement...
J7SC is offline
post #5 of 61 (permalink) Old 04-26-2019, 06:34 PM - Thread Starter
flyinion's Avatar
Rep: 4 (Unique: 4)
Awesome thanks for the info. I'm probably sticking to one for now since I don't think the h500m case I'll be using could aesthetically fit two and all the other stuff.
Sent from my iPad using Tapatalk
Ryzen 7 3700X
GSkill Trident Neo
Samsung 860 Evo
Aquacomputer D5 PWM
Operating System
Win10 Pro 64bit
Asus PG279Q
Dell U2414H
Keyboard
Keyboard
Mouse
Mousepad
Audio
Audio
Schiit Magni 2 Uber
Audio
Schiit Modi 2 Uber
Other
Saitek X52
flyinion is offline
post #6 of 61 (permalink) Old 04-26-2019, 06:37 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
I like shutting my computer off when not in use. It all depends on your preference. If a leak happens you may spot it and shut the computer off. If a pump fails you can catch it quick enough. You also save on electricity.
On 24/7, if a leak happens... However, if a pump fails on idle the computer should not overheat to the point of component failure. If for some reason it does hopefully the mobo/CPU will just shut off the computer anyway.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #7 of 61 (permalink) Old 04-26-2019, 08:35 PM - Thread Starter
flyinion's Avatar
Rep: 4 (Unique: 4)
Thanks for the feedback. Yeah I might transition to putting the system in standby/etc. when not in use. I used to never do it because I wanted quick access and older OS's and mechanical drives/etc used to take "forever" to start up. On top of that I had fan bearings in case fans get dirty/worn and if you shut them off it would be noisy/grindy when first turned on. Now my 4.5 year old 4790K with a SATA based Samsung 850 drive can resume standby in just a few seconds. Not much longer than my monitors take to wake up. I had also always heard it was better for wear & tear to just leave things on instead of constantly hitting them with warming/cooling cycles like that.
Ryzen 7 3700X
GSkill Trident Neo
Samsung 860 Evo
Aquacomputer D5 PWM
Operating System
Win10 Pro 64bit
Asus PG279Q
Dell U2414H
Keyboard
Keyboard
Mouse
Mousepad
Audio
Audio
Schiit Magni 2 Uber
Audio
Schiit Modi 2 Uber
Other
Saitek X52
flyinion is offline
post #8 of 61 (permalink) Old 04-26-2019, 08:54 PM
NewUser16's Avatar
Rep: 56 (Unique: 37)
For the past few years my custom dual loop workstation runs 24/7 with the exception of sleep mode overnight every 2-3 days and even then a lot of times it runs literately 24/7 non stop. I only reboot my system once every 2-3 months and the 4xD5 pumps are about 3-4 years old and no sign of wearing down
NewUser16 is offline
post #9 of 61 (permalink) Old 04-26-2019, 09:13 PM
Retired Staff
animal0307's Avatar
Rep: 116 (Unique: 103)
According to the data sheet, the D5 has an expected life of 50,000hrs @ 60C water temp. Assuming you keep your water temps in check and your water clean, you should get ~5.7 years of 24/7 use.
But as others have mentioned, leaks happen.
I personally have run a Laing DDC 1T for about 4-5 years 24/7, 3 of which I was folding in an ITX loop. Pretty sure my water temps where near or above the recommended water limit. It only recently started to show signs of issues and that was mostly it just getting noisy. I must mention I was using a Swiftech block Apogee Drive II (pump on cpu block). You are not suppose to mount pumps with the impeller facing down , I did, so likely the early demise of my pump if I'm honesty.
My PC was unsupervised for 3 months one summer while I was away from my apartment/school for work. Never had an issue. I Like to live dangerously I suppose
animal0307 is offline
post #10 of 61 (permalink) Old 04-27-2019, 06:50 PM - Thread Starter
flyinion's Avatar
Rep: 4 (Unique: 4)
Thanks again for the replies everyone, as a noob to watercooling I really appreciate it Good to know on the pump life. Maybe eventually I'll have room for a backup pump, but the H500M while roomy overall I think would be a tight fit unless I dumped the drive cage and put it down there, but I'll be putting a 4TB spinner down there in the build so I can't get rid of it. Guess I'll just have to say after a few years if I haven't found something to "upgrade" the pump to just swap it out to something else and replace it or something if I don't have a backup by then. Definitely a bit different than air coolers like my D14 that I've used in 3 builds over 10 years lol (with the original fans even).
Ryzen 7 3700X
GSkill Trident Neo
Samsung 860 Evo
Aquacomputer D5 PWM
Operating System
Win10 Pro 64bit
Asus PG279Q
Dell U2414H
Keyboard
Keyboard
Mouse
Mousepad
Audio
Audio
Schiit Magni 2 Uber
Audio
Schiit Modi 2 Uber
Other
Saitek X52
flyinion is offline
