Some D5 Pumps are different than Original Laing - Page 3 - Overclock.net - An Overclocking Community
post #21 of 43 (permalink) Old 05-06-2019, 03:44 AM
Rep: 0
This forum is weird with photos....give me more time and i will try to put them here again..since im working now.
Sorry the OFF.
P.S. I think now its ok!
Mordorr is offline
post #22 of 43 (permalink) Old 05-06-2019, 03:49 AM
News Fiend
ryan92084's Avatar
Just balance weights. You can find several images across the net where they are in the impeller. In the video he notes that the difference is the ek's sticks up so it was just a bad balance job imo. Not enough to interfere with the tolerances of the stock top but enough to rub against the tighter tolerances of the custom job.
I doubt EK does their own balancing so I wouldn't even put the blame in their court. It would have been a more interesting story if they had put the pump in for a replacement and the next one had the same issue then you could say they might be sourcing second rate impellers. As is I'd file this in the "something to be aware of" category.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #23 of 43 (permalink) Old 05-06-2019, 09:56 AM
Rep: 0
OFFTOPIC:
Can someone tell me how to put here photos? Everting i try fails miserably...
Mordorr is offline
post #24 of 43 (permalink) Old 05-06-2019, 10:12 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Quote: Originally Posted by Mordorr View Post
OFFTOPIC:
Usually you drag pics from your PC into the post and it should upload it. I’m using TapaTalk app on phone and I can add pics as well.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #25 of 43 (permalink) Old 05-06-2019, 10:52 AM
Rep: 0
My System:
P.S Thank you
Mordorr is offline
post #26 of 43 (permalink) Old 05-07-2019, 06:17 PM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
As has been mentioned earlier the metal dots on the impeller are balance weights, just like the small lead weights that are placed on car wheels to balance them. They have always been a fundamental part of the design even before the D5 existed, in the d4 generation pumps. Every impeller has them in different places and number, installed by Xylem.
Without being able to examine the pump it's impossible to know what the problem actually is.
If old mate in the video has never seen balance weights before and could not tell that all the pumps in front of him have them then I can't say that gives me much confidence in any analysis he might provide.
Ashcroft is offline
post #27 of 43 (permalink) Old 05-07-2019, 06:58 PM
ezveedub's Avatar
What I found odd is that he could have swapped the impeller with any of the D5 pumps he had to test it for imbalance/vibration. If the pump no longer made the noise then I would assume the impeller was out of balance. But I think he's making these reservoirs without any specs from Laing/Xylem/Lowara and probably had the machine clearance too tight.
i9 9900K
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #28 of 43 (permalink) Old 05-07-2019, 07:15 PM
Ashcroft's Avatar
Its almost definitely a tolerance problem. I'm sure if the pump was placed in a factory Laing/Xylem housing it would have no problem. There is some variation in all manufacturing.
Pump volutes may seem pretty simple, just in at the centre and out at the edge, but Laing no doubt spent a lot of money and development time to produce the factory top.
Unlike most pumps that have a shaft to steady the impeller, the hemispherical pump impellers float with no contact with the pump body. So only the magnetic field and the dynamics of the fluid flow keep the impeller steady. That makes it a system that is extra sensitive to changes in the volute shape.
As far as the electronics of the pump goes, all D5 pumps are PWM speed controlled. Its just not the Intel standard of PWM.
The Vario model just uses a dial to adjust the inbuilt PWM.
Ashcroft is offline
post #29 of 43 (permalink) Old 05-08-2019, 03:09 AM
Rep: 0
As far i can tell, (only few hours before install my system) my propeller didn`t touch any part of the pump except the center ball in the middle...
Im sure with Heatkiller case, they made a good measure of tolerances and propeller don`t touch the case where is installed...
So far no issues......(Waterclooler D5 Vario).
Mordorr is offline
post #30 of 43 (permalink) Old 05-08-2019, 02:43 PM
Rep: 6 (Unique: 6)
My System:
P.S Thank you
You are welcome.
Nice build, and nice jurassic Corsair Power Supply (I'm sure it still is a great quiet power supply even nowadays!).
Some doubts:
Which to choose (aiming quietness)?
Aqua Computer D5 pump motor with PWM input and speed signal or Watercool WCP D5-PWM (I really wish PWM)?
Bitspower Dual D5 MOD TOP EXTREME (Acrylic Version) or EKWB EK-XTOP Revo Dual D5 Serial?
If I choose the Bitspower's, what fitting shall I use since its threads are G3/8 instead the standard G1/4 (for hose)?
lb_felipe is offline
