Some D5 Pumps are different than Original Laing - Page 4 - Overclock.net - An Overclocking Community
post #31 of 43 (permalink) Old 05-08-2019, 02:56 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Quote: Originally Posted by lb_felipe View Post
You are welcome.
Nice build, and nice jurassic Corsair Power Supply (I'm sure it still is a great quiet power supply even nowadays!).
Some doubts:
Which to choose (aiming quietness)?
Aqua Computer D5 pump motor with PWM input and speed signal or Watercool WCP D5-PWM (I really wish PWM)?
Bitspower Dual D5 MOD TOP EXTREME (Acrylic Version) or EKWB EK-XTOP Revo Dual D5 Serial?
If I choose the Bitspower's, what fitting shall I use since its threads are G3/8 instead the standard G1/4 (for hose)?
That Aqua Computer D5 is PWM, 2nd Gen....it’s same as EK D5 G2.
The Bitspower unit would probably use their own G3/8 barb fittings. Not sure any one makes compression G3/8 fittings...or use G3/8 to G1/4 fittings.
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #32 of 43 (permalink) Old 05-08-2019, 03:30 PM
Rep: 1 (Unique: 1)
You are welcome.
Corsair outside, full Seasonic inside
Mordorr is offline
post #33 of 43 (permalink) Old 05-09-2019, 08:04 AM
Rep: 6 (Unique: 6)
From Watercool pump pages:
"The conventional shaft, shaft bearings, and shaft seals have been eliminated. The occurrence of bearing clearance – and the associated increase of noise – is not possible due to the principle involved. Consequently, the pump continues to work quietly throughout its entire service life."
Does this indicate that this motor is not original?
If so, could it mean that even though it sounds bad, the pump is quieter than the original one (or does it have noisy noise problems like EK, XSPC etc)?
This. Corsair chose seasonic as an OEM because it was one of the first brands to focus on noise, if I'm not mistaken.
lb_felipe is offline
post #34 of 43 (permalink) Old 05-09-2019, 08:10 AM
News Fiend
ryan92084's Avatar
snip...
They are just describing what makes the d5 fancy not what they've altered.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #35 of 43 (permalink) Old 05-09-2019, 08:27 AM
ezveedub's Avatar
Is say right on the description it’s a D5 pump...
i9 9900K
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #36 of 43 (permalink) Old 05-09-2019, 09:47 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
Or they chose that Seasonic platform because it was, at it's time, one of the best performing and most durable platforms available for OEM at a reasonable cost. The fan and associated noise were chosen by Corsair in the OEM spec. The Seasonic end of it is silent (excepting possible coil whine) as it has no moving parts.
ciarlatano is offline
post #37 of 43 (permalink) Old 05-09-2019, 10:21 AM
Rep: 1 (Unique: 1)
OFF:
Seasonic IS the best powersuply we can buy.....
ONTOPIC:
he WCP D5 is a DC pump using the spherical motor design as developed by Laing. The only moving part in a spherical motor pump is a spherically shaped rotor/impeller unit, which is seated on an ultra-hard, wear-resistant ceramic ball. The conventional shaft, shaft bearings, and shaft seals have been eliminated. The occurrence of bearing clearance – and the associated increase of noise – is not possible due to the principle involved. Consequently, the pump continues to work quietly throughout its entire service life.
The bearing is self-adjusting. It is lubricated directly by the medium being pumped (wet rotor design). Separate maintenance is not required. All parts in contact with the medium are corrosion resistant.
Under normal conditions, it is impossible for the rotor to become locked due to the spherical motor design. Reliable starting is also ensured even after long periods of shutdown. The permanent magnetic mechanism allows high efficiency output.
Im confuse.....did thy mod my D5 until a point its worse than a original D5 pump??
Mordorr is offline
post #38 of 43 (permalink) Old 05-09-2019, 11:05 AM
ciarlatano's Avatar
OFF:
No, the snippet that is confusing you is actually simply a note of a D5 feature. Nothing in that quote is a change from a standard D5. The D5 Next is a standard D5 with a PWM controller display attached to it. The display does not change the pump in any way.
post #39 of 43 (permalink) Old 05-09-2019, 12:56 PM
Rep: 6 (Unique: 6)
So is what @ezveedub said wrong?
After all, is Aqua Computer D5 pump motor with PWM input and speed signal so bad as EK D5 G2 in terms of noise/vibrations/whine?
Between that (AC) and this (WC), which is quieter/more sound pleasant? Watercool WCP D5-PWM
post #40 of 43 (permalink) Old 05-09-2019, 01:06 PM
ciarlatano's Avatar
What he said @ezveedub said is entirely correct.
And, sorry, I'm not going down the "which is more silent" rabbit hole.
