Some D5 Pumps are different than Original Laing - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 05-03-2019, 09:29 PM - Thread Starter
Vlada011's Avatar
Rep: 39 (Unique: 29)
On this video guy nicely explain why some version of D5 mostly new PWM version example EKWB D5 G2 but I heard and about XSPC version with SATA connector etc have some small metal parts on impellers and they cause vibration on tops where previous older and more similar to original Laing D5 work normal.
Guy didn't had other solution than to drill little D5 Distro for EKWB D5 G2 with all others pump from his stock worked normal.
Probably metal parts cause to impeller need more space and more touch channel on top.
Because of that EK probably start to give Soft Rubber with D5 Revo tops and advice me to tight less D5 G2 PWM in top.
You can say what you want, only PC stores sell Laing D5 under different names for 70-90$, others still with Laing name same pumps without PWM sell for 200-250$.
If I need to buy D5 now I would find smallest seller who sell much less stuff than bigger and famous seller with oldest stock of MCP655 with speed controller.
Than I would be sure that pump don't survive changes at least 5 years.
When factories decide to change one, only single one capacitor, controller, wire to be thicker or thinner, to add or remove parts in impeller or body that was not more of Laing D5 and pump would need same time to earn glory of pump with first design.
I think he talk about these small metals inside... they are different or not exist at all on original pump.
If someone say to someone "Buy any D5 they are same original Laing D5 only PWM, only this, only that...
I will jump from his monitor and eat his fingers and he will click and kill enemies with mid leg.
Vlada011 is offline
post #2 of 43 (permalink) Old 05-04-2019, 04:00 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
The metal inserts are balance weights. AFAIK, the impellers have always had them. The EK D5 in the video may have been defective, as I had an EK D5 that came in an EK DBAY reservoir that rattled and vibrated new once it was filled. EK replaced it and it wasn’t a newer D5....this was back in 2017
Sent from my iPhone using Tapatalk Pro
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #3 of 43 (permalink) Old 05-04-2019, 04:23 AM
Rep: 6 (Unique: 6)
I don't understand English so please which are the safe buy pumps?
lb_felipe is offline
post #4 of 43 (permalink) Old 05-04-2019, 05:56 AM
Rep: 0
I made lot of research about D5 pumps....ear some problems with EK variants...
Last week i buy a Watercool D5 Vario. Don`t trust PMW stuff.
I hope i did a good option. I saw that video and also read somewhere else about issues with propeller touching reservoirs.....very bad.
Defenily VP755 is to avoid.
Mordorr is offline
post #5 of 43 (permalink) Old 05-04-2019, 06:40 AM
Rep: 6 (Unique: 6)
Which among these did you buy?
1- http://shop.watercool.de/epages/Wate...Products/30047
2- http://shop.watercool.de/epages/Wate...Products/30049
post #6 of 43 (permalink) Old 05-04-2019, 09:57 AM
Rep: 0
Quote: Originally Posted by lb_felipe View Post
A segunda. The second one.
Mordorr is offline
post #7 of 43 (permalink) Old 05-04-2019, 10:39 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 440 (Unique: 293)
Why are you showing pics of an E3 200-240V pump made for potable water applications as reference rather than a D5? Maybe you should just buy an E3, plug it into the wall, and drop your D5 conspiracy investigation that has yielded no actual facts.
ciarlatano is offline
post #8 of 43 (permalink) Old 05-04-2019, 12:22 PM
toolmaker03's Avatar
Rep: 102 (Unique: 76)
it does not take much research to prove that the new EK D5 G2 PWM water pump, is not a reference pump. I noticed this when it was first released, and warned others about buying this product because the electronics have not been proven to last.
their are several PWM versions of the D5 pump that I will not buy, because the electronics have not been around long enough to prove that they will last, or the pump has already been proven to be faulty.
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #9 of 43 (permalink) Old 05-04-2019, 01:19 PM
Rep: 0
I did not buy PWM, because i have a "feeling" i could have problems controlling it, even with a Asus Crosshero VII that i own..but this is another story.
toolmaker03:
Watercol D5 Vario is a good option in your opinion? I only have mine at a few days, but has far i can experience, no problems so far (in such a short time).
EDIT:
https://www.overclock.net/forum/61-w...egular-d5.html
Mordorr is offline
post #10 of 43 (permalink) Old 05-04-2019, 01:35 PM
ciarlatano's Avatar
The fact that PWM versions have added electronics is well known. All fo them, not just EK. But, were you following the D5 conspiracy through the seemingly endless threads he has posted it in, it is not PWM pumps or the electronics that are in question.
