Water cooling kit/AIO for TR4 Threadripper - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 05-04-2019, 11:17 AM - Thread Starter
8564dan's Avatar
Rep: 22 (Unique: 21)
Hi everyone,
I'm putting a build together for a 1900x or 1950x.
I was originally going for air cooling but the Dark Rock Pro and Noctua - NH-U14S TR4-SP3 may not give me enough clearance on the top pci-e slot.
I'm looking at other cooling methods and was thinking about the Corsair H150i etc... but then I've seen and been told basically to avoid CLC's.
So, I'm now looking at water cooling kits such as this one but I can't find any that are compatible with the TR4 socket.
Do these exist for this socket? Or would this be a full custom job? I don't really want to or have the budget to do a full custom job right now - I'm a massive beginner with water cooling.
The case I'm currently going with is the Corsair 750D Airflow edition - as I said, it was going to be an airflow build but now I'm not sure. I've seen this case is also good for water cooling so I'm thinking I'll stick with it?
I love the look of this route though.
Thanks in advance!
EDIT Just found this by Swiftech and it looks great - also compatible with TR4. I've just realised that there are AIO and DIY coolant kits by EK and Swiftech. Think I definitely want to go this route - the AIO kits look amazing and I wonder why anyone would go with a CLC instead.
If anyone could offer any advice on any Swiftech or EK AIO's (preferably RGB but that's optional) then I'd love to know more.
My Rig
(14 items)
Intel Xeon 5670 @ 4.2GHz
Asus P6tD Deluxe
GTX 1080 TI
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Coolermaster HAF 932
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #2 of 7 (permalink) Old 05-04-2019, 01:32 PM
Rep: 0
I would go for a full custom set up.
On my 2700X, i did install a Heatkiller IV Niquel and it rocks.
Mordorr is offline
post #3 of 7 (permalink) Old 05-04-2019, 06:06 PM
MacMus's Avatar
Rep: 1 (Unique: 1)
Only custom loop!
Any TR4 is a best to cool...
MacMus is offline
post #4 of 7 (permalink) Old 05-04-2019, 07:10 PM
Never Finished
airisom2's Avatar
Rep: 277 (Unique: 214)
Ek mlc tr4 is an aio option as well.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #5 of 7 (permalink) Old 05-05-2019, 08:42 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 441 (Unique: 294)
I've used a quite a few Swiftech H series and EK Phoenix, but never on TR4. That said, I prefer the Swiftech as the pump is a bit stronger (and quieter), the rad has better dissipation at lower fan speeds (i.e. better cooling with lower noise), it is much more expansion friendly (from the sense of refill and bleed) and it has better pricing. But.....the new X3 RGB fans really weigh down the performance of the unit. It's still quieter than the EK at like performance, but a change to a good set of top tier fans makes a pretty dramatic difference. So, once you do the fan upgrade, pricing winds up about the same.
ciarlatano is offline
post #6 of 7 (permalink) Old 05-06-2019, 06:36 AM
poah's Avatar
Rep: 7 (Unique: 6)
Hi everyone,
because it doesn't actually make any difference. I wouldn't go with swiftech (reliability issues) the EK (too expensive) over doing my own loop if I was going WC and not using an AIO.
poah is offline
post #7 of 7 (permalink) Old 05-10-2019, 02:10 AM
andrewmp6's Avatar
Rep: 15 (Unique: 14)
Air cooler deepcool fryzen cools good enough and won't cover any pci slots or ram.If your water cooling then use heatkiller,xspc or phanteks tr4 blocks those the best cooling ones.
andrewmp6 is offline
