Specs for Bitspower TouchAqua Radiators? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 05-05-2019, 09:54 PM - Thread Starter
HiTekJeff's Avatar
Rep: 6 (Unique: 5)
I have looked everywhere, even sent an email to their support at Bitspower, but can find details anywhere on their site about what materials this radiator uses. It lists in the specs there a "single copper fin", but says nothing about what material the other fins, ports, etc. are made of. If they were brass/copper, I would think it would be listed as such like on other brands/models. This gives me red flags for concern since I would assume given this it's aluminum based and very cheap. I certainly don't want to mix that with my copper/nickel I have for the other parts as that will cause trouble.
Any thoughts or details on this or the radiator?
HiTekJeff is offline
post #2 of 3 (permalink) Old 05-11-2019, 02:14 AM
Zammin's Avatar
Rep: 29 (Unique: 10)
The touchaqua slim radiators are almost certainly rebranded HW Labs L series slim rads just like the Bitspower Leviathan slim rads. So you could look at the specs on the HW labs website for them. The Touchaqua Tarasque ones, I'm not sure what they are. They look like Alphacool but I can't be sure.
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #3 of 3 (permalink) Old 05-11-2019, 06:14 AM - Thread Starter
HiTekJeff's Avatar
Rep: 6 (Unique: 5)
Actually, I did get a direct answer from Bitspower that I wanted to pass along. Also, I told them I thought this would be helpful for others to post on their web site specs for this radiator.
"BPTA-NLSS360-F2PB is mainly made of copper, no aluminum. Both sides which have the logo is an extra stainless steel plate to the copper radiator. All the loop in the radiator is made of copper. So no worries about any combine aluminum with other copper/nickel on your other parts."
So now we know exactly what materials are used and indeed they are safe to use.
