Is this a "real" D5 pump - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 05-06-2019, 11:14 AM - Thread Starter
Rep: 0
Hello, I'm new to the water cooling community and I'm planning my first build. Recently when browsing for fittings on AliExpress, I found this pump:
http://hishinetech.com/Hishine_en/product.php?id=44
The price is really good and the reviews are very positive. I wrote in a discord community and I was told it's probably not a "real" D5. So what do you think?
Kimura is offline
post #2 of 14 (permalink) Old 05-06-2019, 02:32 PM
Rep: 0
Im newbie in this department....but it goes:
Don`t trust it. Maybe Barrows version is better.......apart this, only trust sellers.
Mordorr is offline
post #3 of 14 (permalink) Old 05-06-2019, 06:28 PM
Zammin's Avatar
Rep: 36 (Unique: 14)
I highly doubt it, it's probably another "D5 compatible" pump. On real D5s the area of the pump around the rotor is silver metal as well, not all black.
EDIT: My bad, apparently real D5's are rated around 1500LPH, not less than 1000LPH.
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #4 of 14 (permalink) Old 05-06-2019, 07:16 PM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
isn't d5 rated at a higher flow?
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #5 of 14 (permalink) Old 05-07-2019, 01:04 AM - Thread Starter
Rep: 0
Okay guys, thanks. But what kind of pump is it? DDC or some other type? I also thought that the flow rate should be higher, but I'm a newbie as well.
I was really thinking to get two of them, because I have an itch to water cool my old rig (5960x and 290x CF) but I don't want to spend a ton of cash cooling old-ish components.
Edit: reason - typo
Kimura is offline
post #6 of 14 (permalink) Old 05-07-2019, 02:12 AM
AMD Overclocker
Alastair's Avatar
Rep: 261 (Unique: 163)
Edit: reason - typo
Would you skimp on your PSU when building your rig? Would you want to buy the dirt cheapest PSU you can find and worry about the day it blows up and takes all your components with it? No? Then why cheap out on your pump. Out of your entire loop I would say the pump is the most important of the lot. It has to be reliable because if the pump goes the rest of the loop cant do its job. Don't cheap out on the pump. Simple as that.
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 4
(26 items)
Rura Penthe
(12 items)
AMD Ryzen 7 3800X
Gigabyte Aorus X570 Pro Wifi
MSI VEGA 64 WAVE
Avexir Core 2 3600MHz 18-20-20-44
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
CoolerMaster V1300 Platinum
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #7 of 14 (permalink) Old 05-07-2019, 02:41 AM
8564dan's Avatar
Rep: 22 (Unique: 21)
I'm new to water cooling and am going with the XSPC D5 Photon Res/Pump combo as it's highly recommended.
I would never try and cheap out on any parts tbh.
My Rig
(14 items)
Intel Xeon 5670 @ 4.2GHz
Asus P6tD Deluxe
GTX 1080 TI
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Coolermaster HAF 932
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
8564dan is offline
post #8 of 14 (permalink) Old 05-07-2019, 03:21 AM
News Fiend
ryan92084's Avatar
If you are looking for a bare pump the swiftechs are already pretty reasonable.
As for what this is just looks like a Chinese d5 clone. Could be decent one that a worker made after their shift was over, could be a pump that didn't meet laing's standard, or it could be complete garbage in a d5 shell. It is a dice roll.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #9 of 14 (permalink) Old 05-07-2019, 04:01 AM
Rep: 0
Yep...on my reserches i ear good things about those "old" swiftechs versions...
Mordorr is offline
post #10 of 14 (permalink) Old 05-07-2019, 04:24 AM
Vlada011's Avatar
Rep: 39 (Unique: 29)
Only Swiftech MCP655 wSpeed Controller non PWM or Laing D5 from Dazmode site, but not Strong version, normal.
Vlada011 is offline
