what's smaller pump than DDC ? silent ? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 05-09-2019, 07:45 AM
Food Editor
skupples's Avatar
Rep: 725 (Unique: 381)
correct, it's an alphacool product.
you really should just go with a DDC. alphacool? more like alphastool.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #12 of 14 (permalink) Old 05-09-2019, 09:24 AM - Thread Starter
Rep: 0
Well my only option now is DDC pump 🙂
Calico88 is offline
post #13 of 14 (permalink) Old 05-09-2019, 09:56 PM
battlenut's Avatar
Rep: 58 (Unique: 52)
http://www.performance-pcs.com/alpha...ic-12v-dc.html
Scroll down past the specs and you will see the Res and pump block down there. This little pump does a good job of moving fluid. Ran for 2 years before I tore the pc down for parts
CPU: AMD Ryzen R9 3900X
Mobo: Asrock X570 Extreme 4
VGA:Sapphire RX 5700 XT Nitro For games Asrock Phantom Gaming Radeon VII for folding
RAM: G-Skill 3600 RipJaws F4-3600C19D-32GVRB X 2
Storage: Samsung M.2 850 EVO 1TB
PSU: Seasonic Prime Ultra 1000 Platinum
Cooling: HeatKiller For CPU & Bykski for GPU
battlenut is offline
post #14 of 14 (permalink) Old 05-10-2019, 04:22 AM
News Fiend
ryan92084's Avatar
Unless you absolutely cannot fit a ddc the dc-lt is the much weaker option. From what I've heard it is far from silent as well unless turned way down which makes it even weaker. I will give it points for not being able to find reliability complaints.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
