what's smaller pump than DDC ? silent ? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 05-08-2019, 02:44 AM - Thread Starter
Rep: 0
building a really small watercool pc, but I can not find a good smaller pump than DDC.
can anyone point me same brand or where to look ?
tried aliexpress but can not find one.
Calico88 is offline
post #2 of 14 (permalink) Old 05-08-2019, 03:06 AM
Amatuer Specialist
cx-ray's Avatar
Rep: 6 (Unique: 4)
Have you considered a DDC PWM pump? Use a PWM fan header for speed control through BIOS and power the pump itself directly with the PSU. At around 1800RPM they're quite silent.
cx-ray is offline
post #3 of 14 (permalink) Old 05-08-2019, 07:03 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
Would something like an XSPC Ion work?
ciarlatano is offline
post #4 of 14 (permalink) Old 05-08-2019, 07:45 AM
News Fiend
ryan92084's Avatar
It wouldn't be smaller but you could do a ddc 3.1 (if anyone still sells them) instead of a ddc 3.2 if you are against pwm.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #5 of 14 (permalink) Old 05-08-2019, 08:08 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 734 (Unique: 386)
I think you can get the old ones on Ebay still, the ones with the peach impeller?
there's really nothing smaller that you'd wanna use... you'd have to source the obscure part, then figure out a way to make it PC compatible.
best off just using a DDC & heavily dialing back the RPMs.
Add me on Steam, same name
skupples is offline
post #6 of 14 (permalink) Old 05-08-2019, 04:33 PM
News Fiend
ryan92084's Avatar
All 4 of the current models use the same impeller its just the wattage that is different iirc. Swiftech still sells 3.1 under their mcp-350 name.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #7 of 14 (permalink) Old 05-08-2019, 05:07 PM
Vermin Supreme 2020
skupples's Avatar
oh, hmm... I've always assumed the not-blue impeller ones were some different model.
skupples is offline
post #8 of 14 (permalink) Old 05-08-2019, 10:41 PM - Thread Starter
Rep: 0
Is digital storm Spark using DDC pump ?
https://images.app.goo.gl/gr55Kp2S4VvV4yqc9
Calico88 is offline
post #9 of 14 (permalink) Old 05-09-2019, 04:36 AM
News Fiend
ryan92084's Avatar
It never came out as far as I can tell so it is hard to get a good picture of the parts but no. Wrong shape to be a ddc and too stubby to be a d5. Looks like it is an alphacool dc-lt.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #10 of 14 (permalink) Old 05-09-2019, 07:18 AM - Thread Starter
Rep: 0
I think it’s DC-LT, that is expensive little pump.
Dc-lt only use by alphacool ?
Can not find the exact pump other than alphacool brand.
Even on aliexpress...
That’s the size I’m looking for.
But is not on my budget
Calico88 is offline
