LGA 1366 Xeon HAF 932 water cooling - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 05-10-2019, 01:04 AM - Thread Starter
8564dan's Avatar
Rep: 21 (Unique: 20)
Hey everyone,
I'm changing up an old rig and adding in a Xeon X5675 cpu.
Going to overclock to 4.5 at least and use this as a test rig for water cooling so I'm more prepared for doing it on my new Threadripper build once Computex is over.
There are no kits that support LGA 1366 anymore that I can find. I did once try out the XSPS Rasa kits back in 2012 but failed and sold it lol.
I need some help getting my parts together.
The list of blocks I've found are here.
The Coolermaster HAF 932 case is ok ... not the best nowadays but what res/pump combo would be recommended?
What recommendations on tubing size are there? I'm probably going to go soft tube in this case and PTEG tube in my Threadripper build (not sure what case yet until Computex is over).
The radiator will just be a 240 at the top as that's all that would fit. Are XSPC rads recommended?
I've read about not mixing metals ... so what metal is recommended? Does this mean the block, rad, fittings etc... should all be either aluminium/nickel or copper? What does it mean when a block is gold plated?
Thanks
My Rig
(15 items)
i7 930 @ 3.8 1.256v
Asus P6tD Deluxe
ATI 5870
12GB Corsair 1600MHz DDR3
Samsung EVO 500GB
1TB + 500GB HDD
Optical Drive
LG Bluray Writer + DVD RW
EVGA Supernova G2 650w
Noctua u12p
Operating System
Windows 10 64Bit
Dell u2711
Keyboard
Blackwidow Ultimate
Mouse
Deathadder 3500dpi
Audio
KRK Rokit RP6
8564dan is offline
post #2 of 3 (permalink) Old 05-10-2019, 02:06 AM
andrewmp6's Avatar
Rep: 13 (Unique: 12)
For rad go hardware labs brand,Pump res combo really whatever can fit in the space you have will work they are all pretty much even today.And what block you see is gold color?There is copper bare blocks maybe thats what you seen thinking its gold ?
andrewmp6 is offline
post #3 of 3 (permalink) Old 05-10-2019, 02:09 AM
ezveedub's Avatar
Rep: 142 (Unique: 100)
HAF932 can fit a XSPC RX360 radiator, as I have been running it for several years already. Radiator is about 55mm thick, you just loose the full length of the top 5.25” bay, but still fits a fan controller. Mounted with ports are rear, you can take the PSU plate out if you need to get at the rear fittings, then put it back. I’d use a 5.25 bay reservoir, as that what fits easily, unless you use a EK DDC pump/ reservoir combo on the floor at the 120mm fan mounting. As for 1366 CPU coolers, I believe all the 1156 EKs blocks fit, it’s the rear plate that may be needed. You can still find them, but they are limited supply at this point, as I have the universal and then later one now installed. Easiest tubing to set up is soft hose tubing of course. I’d use Mayhems clear tubing 10/16mm with compression fittings. As for PETG tubing, it does cloud over time some what AFAIK and is not compatible with propylene glycol based coolants, unlike acrylic tubing. Water components can mix as long as you use good coolant and no aluminum parts. Aluminum cooling systems have to use all aluminum parts, or you’ll get galvanic corrosion.
HAF 932 with X58 mobo installed...RX360 radiator was removed for cleaning, but you can see there’s room up top for it with the fans.
Sent from my iPhone using Tapatalk Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
Intel i7 7700K
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
EVGA RTX2080 Ultra Gaming XC
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
ezveedub is offline
