Looking for the XSPC Raystorm AM4 mounting kit - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 05-15-2019, 04:43 PM - Thread Starter
japanesegorilla's Avatar
Rep: 16 (Unique: 16)
So I plan on upgrading to the new Ryzen whenever AMD releases it. I would like to use my original XSPC Raystorm block but I can't find any place that has the AM4 mounting kit in stock. I've checked every NA vendor that XSPC has listed. FrozenCPU will let you order it and says it will be back in stock but given that everyone else is out of stock I have my doubts about whether it will ever be back in stock.
Does anyone have any suggestions? Will the AM2/AM3 mounting kit not work with AM4? I see that the AM4 kit has more of a dash shape for the screw holes instead of circles.
Intel I5-2500K (@ 4.5GHz), Asrock P67 Extreme4 Gen3, 16GB G.Skill DDR3 1600 F3-12800CL9D-8GBXL @ 8-8-8-20, EVGA GTX 980Ti SC+, Thermaltake Core X71, XSPC Raystorm CPU, EX 120, EX360, EX480, MCP35X
japanesegorilla is offline
post #2 of 6 (permalink) Old 05-16-2019, 05:47 AM
News Fiend
ryan92084's Avatar
The mounting holes are different so you'll need to buy/modify the bracket unless you have one of those motherboards that came with both am3 and am4 holes.
If the rest of the mounting kit is the same between am3 and am4 (check with xspc/the manuals) then you can buy the rgb brackets for the raystorm and pro from Amazon.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #3 of 6 (permalink) Old 05-16-2019, 05:49 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 422 (Unique: 282)
Performance-PCs has the bracket in stock - http://www.performance-pcs.com/xspc-...t-amd-am4.html
I believe that the screw kit is the same as the AM3, but you would need to confirm that with XSPC customer service. Also, XSPC customer service may be able to help you in acquiring the whole mounting kit. In other words.....you should really contact XSPC customer service, as they would be the definitive help in this matter.
ciarlatano is offline
post #4 of 6 (permalink) Old 07-04-2019, 08:11 AM
jamsomito's Avatar
Rep: 1 (Unique: 1)
In the same boat here. Any update, OP? How did this work out for you?
jamsomito is offline
post #5 of 6 (permalink) Old 07-04-2019, 03:19 PM - Thread Starter
I happened to see it come back in stock at performance-pcs and got one a couple weeks ago. You might give them a call to see if they are getting more in stock. I signed up for their stock alert on the product page but it did not notify me when they came back in stock, I just happened to check.
If you are going from Intel mounting to AM4, avoid the RGB upgrade kits as they don't come with screws and the mounting screws for AM4 are different than the ones used for Intel.
post #6 of 6 (permalink) Old 07-05-2019, 05:51 AM
jamsomito's Avatar
Rep: 1 (Unique: 1)
Very helpful. Thanks much!
