Farbwerk 360 - Page 2 - Overclock.net - An Overclocking Community
Farbwerk 360
post #11 of 25 (permalink) Old 05-20-2019, 04:03 PM
repsol23's Avatar
Rep: 0
Nvm. My bad. Just looked up splitty 4 and realized that is probably what they were working on. Not sure why it isnt working for you. Sorry.
repsol23 is offline
post #12 of 25 (permalink) Old 07-03-2019, 07:36 AM - Thread Starter
Rep: 0
I also changed the splitty4, but they still don't work
Is it possible that there is no one with the Spltty4 and the Farbwerk 360 with Corsair Rgb fans ??
R9 3900X+EkWb-Asus X570 Crosshair VIII Formula-G.Skill TridentZ 32Gb Rgb-Radeon VII+EkWb-Samsung 970 Evo 500Gb-Evga P2 850W-Asus MG279Q-Phanteks Evolv Atx TG AF-W10 Pro
Lupo91 is offline
post #13 of 25 (permalink) Old 07-03-2019, 07:46 AM
Shawnb99's Avatar
Rep: 22 (Unique: 14)
Considering the Farbwerk 360 just came out I’d say that’s likely.
Try asking on the Aquacomputer forums, might have better luck there
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #14 of 25 (permalink) Old 07-03-2019, 07:53 AM - Thread Starter
Rep: 0
I have also asked in the Aquacomputer forum, and their assistance
Lupo91 is offline
post #15 of 25 (permalink) Old 07-03-2019, 08:18 AM
Shawnb99's Avatar
Yeah not very helpful there are they.
Has AQ support been no help either?
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #16 of 25 (permalink) Old 07-03-2019, 08:52 AM - Thread Starter
Rep: 0
The official support, I had already contacted him a couple of months ago, but they told me to send him my fans to do tests, obviously I refused.
Now I have contacted them again, and I feel if there are any news.
Lupo91 is offline
post #17 of 25 (permalink) Old 07-03-2019, 09:22 AM
Shawnb99's Avatar
Yeah sending your fans is a bit much.
Well hope you find a solution
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #18 of 25 (permalink) Old 07-08-2019, 07:58 PM
wheatpaste1999's Avatar
Rep: 2 (Unique: 2)
Not 100% your use case, but I tested with Corsair LL120 RGB fans and the LEDs work for me. I am on Aquasuite 2018-11. Here's how I have everything connected:
-LL120 4-pin LED cables connected to Corsair headers on a Splitty4
-Splitty4 connected to one of the RGBpx headers on a Farbwerk360 via included RGBpx cable (small 4-pin cable)
-Farbwerk360 connected direct to motherboard via USB cable (no aquabus)
Is this the same way you have everything connected?
Does the Farbwerk360 show up in Aquasuite and can you create LED controllers for the RGBpx port/header that the Splitty4 is connected to? Are the LED controllers that you've setup active for the Farbwerk 360 profile that you're using?
Do other RGBpx strips work when plugged in directly to the Farbwerk360?
i9 7900x
(8 items)
i7 7700k
(8 items)
i9 7900x
Asus Rampage VI Extreme
EVGA 1080Ti SC2 2-Way SLI
Corsair Vengence RGB
Corsair AX1600i
Custom Loop
Lian-Li O11-Air/Dynamic
Other
Aquaero 6LT
i7 7700k
Asus Maximus IX Hero
EVGA 1080Ti SC Black
Corsair Dominator Platinum
EVGA 1000G3
Custom Loop
Phanteks P400S
Other
Aquaero 6LT
wheatpaste1999 is offline
post #19 of 25 (permalink) Old 07-14-2019, 12:24 PM - Thread Starter
Rep: 0
I connected, everything like you did.
Except that in the middle I have the Hubby 7 Aquacomputer, because I also have the Aquaero 6
I tried to connect it directly to the motherboard, but nothing changes
The LED strips connected through the RgbPx cable to the Farbwerk 360, work normally
This is a screen from FarbWerk 360
The first controller is where the fans are connected, and although it is set, the LEDs do not work
Lupo91 is offline
post #20 of 25 (permalink) Old 07-15-2019, 06:50 AM
Rep: 2 (Unique: 2)
Sounds like it's all connected correctly. Hubby7 shouldn't make any difference, as it looks like Aquasuite sees the Farbwerk360 just fine.
In your image, all of your LED controllers only go out to the 15th LED. Have you tried stretching this out to LED 90 (hover over the edge with your mouse and drag the LED controller bar), just to eliminate that variable? It's completely possible that the LEDs for your fans are not within the range of LEDs that the controller is setup for (in this case LEDs 1-15 only).
I would also make the LED controller active for all profiles 1-4, just to troubleshoot and eliminate variables until you can get the base functionality sorted out.
Other than that,I don't see any other option but to get an RMA on the Farbwerk360.
i9 7900x
(8 items)
i7 7700k
(8 items)
i9 7900x
Corsair AX1600i
Custom Loop
Other
Aquaero 6LT
i7 7700k
EVGA 1000G3
Custom Loop
Phanteks P400S
Other
Aquaero 6LT
