Farbwerk 360 - Page 3 - Overclock.net - An Overclocking Community
Farbwerk 360
post #21 of 25 (permalink) Old 07-15-2019, 08:32 AM
Shawnb99's Avatar
Rep: 21 (Unique: 14)
I see you also have the Aquaero is the FabWerk connected to it? If so disconnect it and try again. There is a know issue with Quadro’s losing RGB control when connected to the AQ, maybe the FabWerk has the same issue.
Otherwise if it’s showing up in Aquasuite it should work, if not then yeah something is wrong with it and I’d RMA it.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #22 of 25 (permalink) Old 07-15-2019, 11:37 AM - Thread Starter
Rep: 0
Quote: Originally Posted by wheatpaste1999 View Post
Sounds like it's all connected correctly. Hubby7 shouldn't make any difference, as it looks like Aquasuite sees the Farbwerk360 just fine.
In your image, all of your LED controllers only go out to the 15th LED. Have you tried stretching this out to LED 90 (hover over the edge with your mouse and drag the LED controller bar), just to eliminate that variable? It's completely possible that the LEDs for your fans are not within the range of LEDs that the controller is setup for (in this case LEDs 1-15 only).
I would also make the LED controller active for all profiles 1-4, just to troubleshoot and eliminate variables until you can get the base functionality sorted out.
Other than that,I don't see any other option but to get an RMA on the Farbwerk360.
I tried to put it up to 90 LEDs, but they don't turn on anyway
Could there be a specific interval, in which the LEDs light up, or nothing changes?
I also tried disconnecting it and the factory reset, but nothing has changed
R9 3900X+EkWb-Asus X570 Crosshair VIII Formula-G.Skill TridentZ 32Gb Rgb-Radeon VII+EkWb-Samsung 970 Evo 500Gb-Evga P2 850W-Asus MG279Q-Phanteks Evolv Atx TG AF-W10 Pro
Lupo91 is offline
post #23 of 25 (permalink) Old 07-15-2019, 01:51 PM
wheatpaste1999's Avatar
Rep: 2 (Unique: 2)
On most of the different effects types you can control brightness and speed from a data source, which could also cause the LEDs to not light up, but it doesn't look like that is applicable to your case.
Only other things you can try (or confirm that you've already tried):
1. Your LED controllers appear to only be active for Profile 1. Confirm Profile 1 is the current active profile by clicking on the Profiles tab under the Farbwerk 360 section in Aquasuite. Current profile is listed and color coded at the top of this section.
2. Under the System tab for the Farbwerk 360 in Aquasuite, check that the strips are set to "on" and brightness is 100% under the Basic RGBpx settings in this section.
3. Try a new RGBpx cable from the Splitty4 to the Farbwerk 360.
4. Try a new Splitty4.
That's about all I can think of at this point. Might need to consider an RMA for the Farbwerk 360 if the above doesn't get you anywhere.
i9 7900x
(8 items)
i7 7700k
(8 items)
i9 7900x
Asus Rampage VI Extreme
EVGA 1080Ti SC2 2-Way SLI
Corsair Vengence RGB
Corsair AX1600i
Custom Loop
Lian-Li O11-Air/Dynamic
Other
Aquaero 6LT
i7 7700k
Asus Maximus IX Hero
EVGA 1080Ti SC Black
Corsair Dominator Platinum
EVGA 1000G3
Custom Loop
Phanteks P400S
Other
Aquaero 6LT
wheatpaste1999 is offline
post #24 of 25 (permalink) Old 07-16-2019, 05:42 AM - Thread Starter
Rep: 0
1) Profile 1 was already active
2) Done
3) Done
4) Done
Lupo91 is offline
post #25 of 25 (permalink) Old 07-16-2019, 10:27 AM
Rep: 2 (Unique: 2)
2) Done
3) Done
4) Done
Well, looks like you've exhausted all of the sticking points that I can think of.
Seems like your best bet is to RMA the Farbwerk 360.
i9 7900x
(8 items)
i7 7700k
(8 items)
i9 7900x
Corsair AX1600i
Custom Loop
Other
Aquaero 6LT
i7 7700k
EVGA 1000G3
Custom Loop
Phanteks P400S
Other
Aquaero 6LT
