Farbwerk 360 - Overclock.net - An Overclocking Community
Farbwerk 360
post #1 of 11 (permalink) Old 05-18-2019, 03:54 AM - Thread Starter
Rep: 0
Farbwerk 360
Nobody has the Farbwerk 360 with the Corsair ML120 Pro RGB ??
I simply can't get the LEDs to work, they stay off
R7 2700X+EkWb-Asus X470 Crosshair VII-G.Skill TridentZ 32Gb Rgb-Radeon VII+EkWb-Samsung 970 Evo 500Gb-Evga P2 850W-Asus MG279Q-Phanteks Evolv Atx TG AF-W10 Pro
Lupo91 is offline
post #2 of 11 (permalink) Old 05-18-2019, 08:30 PM
andrewmp6's Avatar
Rep: 13 (Unique: 12)
I believe you have to use their on controller and software https://www.techpowerup.com/253420/a...led-controller
andrewmp6 is offline
post #3 of 11 (permalink) Old 05-19-2019, 03:40 AM - Thread Starter
Rep: 0
That seems obvious to me, I'm using Aquasuite
The fans are connected through the Splitty4 to the Farbwerk 360, the fans work, but the LEDs do not light up
Lupo91 is offline
post #4 of 11 (permalink) Old 05-20-2019, 01:56 AM
andrewmp6's Avatar
The corsair fans need their lighting node pro,It should have came with the fans if you bought them in a pack.And that lighting node pro hooks into a front usb on the motherboard and uses corsair software.
post #5 of 11 (permalink) Old 05-20-2019, 05:39 AM - Thread Starter
Rep: 0
But no.
Because before I had the Splitty4 to which I had connected the fan and LED cables, then with the RgbPx cable, I connected everything to the Aquacomputer D5 Next.and both the LEDs and the fans worked
Instead now, the Splitty4 is connected to the Farbwerk 360 the fan leds don't work ....
Lupo91 is offline
post #6 of 11 (permalink) Old 05-20-2019, 06:59 AM
GAN77's Avatar
Rep: 0
Perhaps the Splitty4 and Farbwerk 360 are not compatible?
Splitty4 Compatible with:
D5 NEXT (41118)
QUADRO fan controller (53256)
GAN77 is online now
post #7 of 11 (permalink) Old 05-20-2019, 07:20 AM - Thread Starter
Rep: 0
D5 NEXT (41118)
In the description of the Farbwerk 360 I read this:
Compatible with third party LED products
Alternatively to the LED strips offered by Aqua Computer, LED fans made by Corsair and NZXT can be connected using the optional accessory RGBpx Splitty4 (item code 53267, not included in delivery).
https://shop.aquacomputer.de/product...oducts_id=3798
Lupo91 is offline
post #8 of 11 (permalink) Old 05-20-2019, 11:28 AM
Solarity's Avatar
Rep: 14 (Unique: 8)
The Corsair RGB Addressable fans use a 4th pin to pass off data to the next fan (data out). Make sure you have it plugged into the first slot though the next one. They data in and out are wired in series, so if you are missing the first fan in the line, then it won't work at all. I can't speak for Aquacomputer's design, though I know Corsair products very well.
Solarity is offline
post #9 of 11 (permalink) Old 05-20-2019, 11:47 AM - Thread Starter
Rep: 0
The fans are connected in series from the first entrance to the third.
I repeat, in this way with the D5 Next they worked, while with the Farbwerk 360 the LEDs do not light up, so the fan leds are working
Lupo91 is offline
post #10 of 11 (permalink) Old 05-20-2019, 04:00 PM
repsol23's Avatar
Rep: 0
Google search seems to indicate they are working on some form of a 3 pin to 4 pin adapter for corsair.
repsol23 is offline
