Took The Plunge - Overclock.net - An Overclocking Community
Took The Plunge
post #1 of 9 (permalink) Old 05-18-2019, 04:20 PM - Thread Starter
MoreBusSpeed's Avatar
Rep: 1 (Unique: 1)
Took The Plunge
So I took the plunge, removed the Corsair CLC and built my first custom loop. Went with hard tubing which, was interesting, to say the least, as I had never even run soft tubing before. Anyone have thoughts on this before I run cleaner than, fill it up? Also have a drain valve that isn’t pictured yet. Ran a fitting short. Will be here tomorrow. Sorry for the phone pic.
------------------------------------------------------------------I need that Szechuan Sauce-------------------------------------------------------------------------------
Asus Z390 Rig
(12 items)
i7 8700K @ 5233 MHZ
Asus Maximus XI Hero Z390
32GB G. Skill Ripjaws V
Samsung 970 Evo Plus M.2 NVMe 500GB
Mushkin 1TB SSD
Corsair RM 850X
Corsair H115i PRO
Bitfenix Enso Mesh
Operating System
Windows 10 X64
Samsung
Keyboard
iClever Wireless - Chargeable
Mouse
iClever Wireless
MoreBusSpeed is offline
post #2 of 9 (permalink) Old 05-18-2019, 04:23 PM
Martin778's Avatar
Rep: 17 (Unique: 17)
Hmm....welll..umm...this looks kinda awful...did you use the correct sillicone inserts for the tube? You simply CANNOT do it without inserts or the tube will collapse.
I think you've heated the tubes way too much or haven't used the right inserts.
Honestly I would've gone with 90 deg hard tubing everywhere but that's helluva expensive due to the amount of fittings needed.
Threadripper 3960X @ broken PBO EDC=40 | Aorus TRX40 Xtreme | Enermax Liqtech II 360 TR4 + EK Clear flush + 3x Noctua A12x25 | 4x8GB G.Skill TridentZ Neo 3800C14 @ 3733 CL14-15-15-30 CR1 | EVGA Kingpin 2080Ti @ 2115MHz / 8250MHz + Noctua A12-25 | 4x1TB 970 PRO raid0 | Corsair MP600 2TB | Seasonic Prime Platinum 1300W | In Win D-Frame 2.0 Gold | ASUS PG349Q
Martin778 is offline
post #3 of 9 (permalink) Old 05-18-2019, 04:29 PM - Thread Starter
Rep: 1 (Unique: 1)
Yeah, was worried about that. The insert seemed a bit small but was specified for 16/12 mm tubing. I did order a second set of tubing as well to re-do that. Think I should re-do it before trying it out?
Asus Z390 Rig
(12 items)
i7 8700K @ 5233 MHZ
Mushkin 1TB SSD
Corsair RM 850X
Corsair H115i PRO
Bitfenix Enso Mesh
Operating System
Windows 10 X64
Samsung
Keyboard
Mouse
iClever Wireless
post #4 of 9 (permalink) Old 05-18-2019, 04:35 PM
Rep: 2 (Unique: 2)
The bends are bad, it's way from perfect but it has style.
Do a leak test with demi water and if all stays dry, run the biatch!
You can use the running loop as some sort of template while making other bends. I'd keep it this way for now. Wrong but it be still effective.
That_1_Hz_Extra is offline
post #5 of 9 (permalink) Old 05-18-2019, 04:36 PM
PC Evangelist
ZealotKi11er's Avatar
Rep: 1806 (Unique: 1179)
Should have gone with soft tubing for the first time.
Yamato
(10 items)
Ishimura
AMD Ryzen 7 3700X
ASUS TUF Gaming X570-Plus (Wi-Fi)
AMD Radeon RX 5700 XT
G.SKILL Trident Z RGB (2x8GB) DDR4 3200MHz CL14
Samsung SM961 512GB
HGST DeskStar NAS 6TB
EVGA SuperNOVA 750 P2
Gamdias Chione M1A-280R
Fractal Design Meshify C TG
Operating System
Microsoft Windows 10 Pro 64 Bit
Intel Core i7-3770K @ 4.8GHz
ASRock Z77E-ITX
AMD Radeon Vega Frontier Edition
AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
SanDisk Ultra II 960GB
Toshiba X300 5TB
EVGA SuperNOVA 750 G3
Corsair H100i GTX
Fractal Design Define Nano S
Operating System
LG OLED55C7P
Keyboard
Cooler Master MasterKeys MK750
Mouse
Finalmouse Air58 Ninja
ZealotKi11er is offline
post #6 of 9 (permalink) Old 05-18-2019, 04:39 PM - Thread Starter
Rep: 1 (Unique: 1)
Yup, gotta re-do the bends. First time. Think the insert was the issue. Going to run it though and see how it works temp wise at least. Figured go with the hard tubing to learn. Not going to wimp out and go with soft yet lol.
Thanks for the input! I will keep you guys posted.
Asus Z390 Rig
(12 items)
i7 8700K @ 5233 MHZ
Mushkin 1TB SSD
Corsair RM 850X
Corsair H115i PRO
Bitfenix Enso Mesh
Operating System
Windows 10 X64
Samsung
Keyboard
Mouse
iClever Wireless
post #7 of 9 (permalink) Old 05-19-2019, 12:42 AM
Martin778's Avatar
Also consider adding a valve at the bottom to drain the loop. I would not fill it at the moment because you'll have to plug all the ports afterwards as there will still be water dripping out of the rad and res when you move the case around.
Using bending tools on a flat surface makes bending a lot easier: https://www.amazon.com/BXQINLENX-PET.../dp/B01GNP8Y4E
post #8 of 9 (permalink) Old 05-19-2019, 09:16 AM - Thread Starter
Rep: 1 (Unique: 1)
Yup, I have one. Mentioned that in the opening post. Got a nice Bitspower valve that I’ll be installing. Missing fitting, new tubes, and new insert, should be here today and than I’m gunna fill it. I re-checked the insert I ordered on Amazon and it is indeed the wrong size. Whoops! Round 2 here I come.
Asus Z390 Rig
(12 items)
i7 8700K @ 5233 MHZ
Mushkin 1TB SSD
Corsair RM 850X
Corsair H115i PRO
Bitfenix Enso Mesh
Operating System
Windows 10 X64
Samsung
Keyboard
Mouse
iClever Wireless
post #9 of 9 (permalink) Old 05-30-2019, 06:24 PM - Thread Starter
Rep: 1 (Unique: 1)
This is an update. Need to re-visit the front tube with the valve on it.
Asus Z390 Rig
(12 items)
i7 8700K @ 5233 MHZ
Mushkin 1TB SSD
Corsair RM 850X
Corsair H115i PRO
Bitfenix Enso Mesh
Operating System
Windows 10 X64
Samsung
Keyboard
Mouse
iClever Wireless
