Mayhems Blitz kit - Overclock.net - An Overclocking Community
Mayhems Blitz kit
post #1 of 13 (permalink) Old 05-23-2019, 07:32 PM - Thread Starter
Pinnacle Fit's Avatar
Rep: 24 (Unique: 18)
Mayhems Blitz kit
Not sure if this has been asked (I’m sure it has) :
What are people’s general thoughts on mayhems blitz? I have a kit but I already put my loop together. Can I add part 2 and flush it out in 24hrs?
Also is there any negative from not using part 1? I just rinsed with hot water a few times.
Sent from my iPhone using Tapatalk
i9-9900k OC to 5.0GHZ @ 1.285V Delidded/Direct Die Cooled
Gigabyte Z390 Aorus Master
GTX 1080Ti FE
Lian Li O11 Dynamic, white
Pinnacle Fit is offline
post #2 of 13 (permalink) Old 05-23-2019, 07:37 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 736 (Unique: 388)
Yes, you can run part 2 in your whole system from what I understand. It's not gonna do much though I don't think. It's not hugely necessary, but definitely can prevent new-hardware issues. I'll assume you're also using his coolants or drops? Just keep an eye on your Ph, if it starts getting high, you should strip down n run 1 & 2.
step one - acid bath, gets out all the nasty you won't get out with hot water.
step 2 - system stabilizer n stuff.
Add me on Steam, same name
skupples is offline
post #3 of 13 (permalink) Old 05-23-2019, 07:58 PM - Thread Starter
Understood...so do I need to take the loop apart and run part 1? These are new black ice nemesis rads.
I run his red dye in there but I haven’t noticed too much color change (diluting but not a change like I saw with my other alphacool rads-red to purple)
I can take the loop apart since i know I already have the pieces to assemble back but I’d rather not if possible. Are hardware labs rads particularly dirty or is that caveat for companies that are?
GTX 1080Ti FE
post #4 of 13 (permalink) Old 05-23-2019, 08:03 PM - Thread Starter
Mayhems Blitz kit
I also haven’t been checking pH. I use their coolant additive, as well as biocides and corrosion inhibitor. I’m just considering going with pastel red now...
Actually now that I see it, it looks like it is turning purple after all. Funny thing is - PPCs has a review from somebody that says the exact same thing, that after a week it started going from red to purple. I wonder if that means that the dye is breaking down due to pH or if the loop is contaminated.
GTX 1080Ti FE
post #5 of 13 (permalink) Old 05-23-2019, 09:38 PM
Shawnb99's Avatar
Rep: 61 (Unique: 42)
It's recommended to run both parts when using Mayhem's fluids. At the very least I'd run part 2. If you're able I'd say take out the rads and run part 1 as well.
Part 1 is just for the rads out of the loop. Part 2 is used when the loop is back together and can clean out the whole loop. IE Mayhem's tubing needs a flushing when first used.
Make sure you totally flush it all out before you add the Mayhem's fluid.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 13 (permalink) Old 05-24-2019, 07:58 AM
Mayhem's Avatar
Rep: 278 (Unique: 197)
Our Bio+ and Inhib + are extremely strong, if you use too much you will get colour change. Only a tiny amount is needed in a system this stuff is industrial strength, we haven't weakened it in any sense..
Some old Guy who messes on in his little factory.
Started in Kichen, worked up to owning a factory!
How i did it i haven't got a clue and still don't know how i do it to this day!
All i can say is my Hobby is my job and i love my job.
Mayhem is offline
post #7 of 13 (permalink) Old 05-24-2019, 08:31 AM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 125 (Unique: 102)
As already mentioned, the Part 1 is only for radiators. If you take your loop apart for sure use the Blitz Part 1 especially with red coolant.
At the very least you should use the Part 2 on the entire system, just make sure you flush at least three times after to get it all out.
When fluid turns purple it's usually caused from radiators that are not clean enough. The Hardware Labs radiators are generally considered some of the cleanest out of the box.
My personal experience with Mayhems red dye is that it fades out quickly, starting just days after putting in the system, just like in your picture.
I would recommend using a red coolant if you want to run red.
I sampled a bunch of different red coolants, and dyes awhile back. Here's the link https://www.overclock.net/forum/27740298-post424.html
Devastator
(14 items)
Secondary Rig
i9-7900X
Asus Rampage Extreme VI
2x EVGA 2080Ti XC Gaming
G.Skill TridentZ Royal 32GB 3600 16-16-16-36
Intel Optane SSD 480GB
Samsung 850 EVO 2TB
2x Seagate Iron Wolf Pro 12TB
EVGA SuperNOVA 1600 T2
Hardware Labs Black Ice SR2 Radiators 4x 560mm + 2x 280mm
Aquacomputer Aquaero XT + Aquaero LT
2x Aquacomputer D5s with custom chrome plated Bitspower mod kits
2x Aquacomputer Aqualis 880ml Reservoirs with Nano Coating & Aquabus Interface
CaseLabs THW10 with Custom Powder Coating
Operating System
Windows 10 Pro
Intel Core i7-4790K
Asus Maximus Extreme VI
EVGA GTX 980 ti Classified
G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 2400
Samsung 850 Pro 500GB
Seagate Desktop HDD 4TB
EVGA SuperNOVA 1300 G2
EK 420 Rad + EK 280 Rad
Corsair 750D
Operating System
Microsoft Windows 10 Pro 64-bit
Acer XB271HU
Keyboard
Microsofte Natural Ergonomic 4000
Mouse
Logitech G502
Barefooter is offline
post #8 of 13 (permalink) Old 05-24-2019, 09:33 AM
NewType88's Avatar
Rep: 5 (Unique: 3)
What's the PH range coolant should be at ?
NewType88 is offline
post #9 of 13 (permalink) Old 05-24-2019, 09:56 AM - Thread Starter
Can I run stage 1 in the blitz with my pump and res as well? As in can I connect my rads together with my res and pump?
Thanks I have a few other choices to look at now. Never considered aquacomputer’s dye.
GTX 1080Ti FE
post #10 of 13 (permalink) Old 05-24-2019, 10:39 AM
Shawnb99's Avatar
Nope Stage 1 is just for the radiators. You'll be leaving it in them for 8-12 hours and then flushing. Only stage 2 can be used with the connected loop.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
