Does this look ok? - Overclock.net - An Overclocking Community
Does this look ok?
post #1 of 3 (permalink) Old 05-24-2019, 10:12 AM - Thread Starter
CrysisEnthusiast's Avatar
Rep: 0
Hello WC folks. So after my last thread where I showed my slightly corroded gpu block, i decided to buy a new Nickel + plexi block from EK. I assembled the loop yesterday and I can see some bubble-looking shapes in the gpu block as you can see in the pic so Im just wondering if this is normal? I don't want to experience the same thing I had with my previous block so I'm being extra cautious.
Everything in my loop has been cleaned and flushed with distilled water and then EK CryoFuel coolant prior to assembly. Here are all the cooling parts im using:
D5 pump with EK top
EK 250mm rgb reservoir
XSPC Raystorm Neo Metal (copper base) cpu block
2 x EK XE 360 rads
EK nickel + plexi gpu block
Bitspower non chamfer brass link tubes
Bitspower fittings
EK CryoFuel clear coolant
Current Rig
(21 items)
Intel Core i7 3930K
ASUS ROG Rampage IV Extreme
Gigabyte Geforce GTX 980 Ti
16GB (4x4GB) Corsair Dominator GT Quad Channel @2133Mhz
Samsung 840 Pro 256GB (OS)
Intel 530 180GB
Intel 510 120GB
Seagate SSHD 1TB
Enermax Platimax 1200W
Koolance CPU-380I Block
2 x Alphacool White UT60 360mm Radiators
EK-FC Titan X Water Block
Bitspower Crystal Link tubing
Caselabs Mercury S8 White
Operating System
Windows 10 64-bit
ASUS PB278Q
Keyboard
Logitech G910 RGB
Mouse
ASUS ROG Eagle Eye
Mouse
ASUS ROG
Audio
Audio Technica ATH-M50
Audio
Bayerdynamic DT 770 Pro 250ohm
CrysisEnthusiast is offline
post #2 of 3 (permalink) Old 05-24-2019, 10:50 AM
roaming in his fishtank
poisson21's Avatar
Rep: 9 (Unique: 7)
If your loop is brand new, let it a week or two , the bubbles will disappear slowly but surely.
poisson21 is offline
post #3 of 3 (permalink) Old 05-24-2019, 11:15 AM - Thread Starter
Rep: 0
Alright, thanks! I just fear it could be oxidation or something cause these are not exactly coolant bubbles, they look to be stains on the metal, but I'll wait and see.
Current Rig
(21 items)
Intel Core i7 3930K
Intel 530 180GB
Intel 510 120GB
Seagate SSHD 1TB
Operating System
Windows 10 64-bit
ASUS PB278Q
Keyboard
Logitech G910 RGB
Mouse
ASUS ROG Eagle Eye
Mouse
ASUS ROG
Audio
Audio
