O ring cpu block.... - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 05-25-2019, 06:50 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Hi all,
So im about to tear down my secondary rig for complete cleaning, changing coolant and replace all o-rings on all my fittings.
However i do not have a replacement o-ring for my Koolance 380 cpu cooler, can i still use the o-ring after cleaning (if needed)?
I read somewhere that if you leave the o-ring alone for a couple of hours it will go back to its original shape thickness....?
Either way i always replace o-rings on my fittings with every tear down.
When i have to clean my cpu block the first time i do not replace the o-ring for the cpu.
However this is now my second time i will tear down my secondary rig so can i re use the o-ring on my cpu for a second time?
Lastly how often can you re use a cpu block o-ring?
Thx in advance
Cobra26 is offline
post #2 of 13 (permalink) Old 05-25-2019, 08:25 PM
NewUser16's Avatar
Rep: 56 (Unique: 37)
GPU/CPU O-rings are rated to last 8-10 years if carefully removed, just don't tear it and you can easily reuse it over again. When you remove it and you can put your hands on Parker O-lube or other rubber lubricants, they can come in liquid or in the tube I use liquid, submerge the o-ring in it for 15-20min, remove and rinse well with distilled water and O-ring is like new again.
If you don't have access to any lubricant, just rinse and dry it, it will be fine as well.
NewUser16 is offline
post #3 of 13 (permalink) Old 05-26-2019, 04:04 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Thank you for the reply,
I see i should have no issues i think my cpu block is now around 5 years old maybe a little more. Hopefully it can go for another cycle.
Cobra26 is offline
post #4 of 13 (permalink) Old 05-26-2019, 04:28 PM
Missing the Old days
Cerberus's Avatar
I literally take a drop of Vaseline in my palm and "string" the o ring through it, just get it shiny, that's all it needs.
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #5 of 13 (permalink) Old 05-26-2019, 06:40 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Thanks, so after the "string" then what dry it to remove the vaseline or not? Say you dont remove the Vaseline on your o-ring will it have negative effects when it comes in contact with the coolant?
Cobra26 is offline
post #6 of 13 (permalink) Old 05-26-2019, 06:43 PM
Cerberus's Avatar
Usually I gently run it through my dry fingers after, Vaseline is pretty inert stuff, its just petroleum jelly, a dab in a whole cooling system wouldn't hurt it tooooo much (can't say for certain)
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
Corsair RM750X
big metal box
Operating System
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Corsair 650w
Cerberus is offline
post #7 of 13 (permalink) Old 05-26-2019, 09:49 PM
NewUser16's Avatar
Yap, Vaseline will do it to, its waterproof and has no chemical properties to harm rubber
post #8 of 13 (permalink) Old 05-26-2019, 09:55 PM
NewUser16's Avatar
I have old Heatkiller block for 780Ti on my old system that has been taking apart by my son several times and the last time I checked it looked still like new so again, as long as you don't rip it and use either of the lubricating suggestions, it will last 10 years and beyond
post #9 of 13 (permalink) Old 05-26-2019, 10:55 PM
rdr09's Avatar
Rep: 893 (Unique: 643)
I was gonna say it might degrade rubber. But if it is gentle for the skin, then its gentle for the oring.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #10 of 13 (permalink) Old 05-27-2019, 05:49 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Thanks for all the suggestions and help guys!
I think i will go with the Vaseline on my cpu o-ring next time when i tear down my rig for maintenance.
Cobra26 is offline
