Why do CPUs benefit so much less from good cooling than GPUs? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 22 (permalink) Old 06-11-2019, 10:17 AM
pmc25's Avatar
Rep: 7 (Unique: 7)
I think decent cooling will make a huge difference to the new Ryzen 3 chips. 7nm is so dense.
It makes a big difference to Vega 20 (much bigger difference than 14nm Vega 10).
pmc25 is offline
post #12 of 22 (permalink) Old 06-11-2019, 01:44 PM - Thread Starter
aabeba's Avatar
Rep: 0
Good responses. I appreciate the knowledge. Can anyone give me an answer on whether I should give delidding another go? I suspect I didn't replace the heat spreader quite as well as I could have. Is it worth it or do I just deal with a higher package/core 3 Tmax?
Quote: Originally Posted by deafboy View Post
Direct mount helps though regardless in optimal uses
Can you mount a waterblock directly to a CPU die?
aabeba is offline
post #13 of 22 (permalink) Old 06-11-2019, 02:20 PM
white owl's Avatar
Rep: 136 (Unique: 103)
You can direct die a CPU with a water block but you're looking at a 5c difference over what you had with the IHS.
GPUs can usually gain 100 maybe even 200Mhz when you water cool them, the CPU isn't likely to gain much of anything unless you're thermally limited instead of power limited.
Exactly why it's harder to cool a CPU is a bit unclear but there are a few things to note:
CPUs are sold pretty close to max OCs already while GPUs (since Pascal) have the BIOS completely locked down so we can't apply voltage and power the way we can with a CPU, the cards will not apply more power unless you cool them.
A 200w CPU means your CPU alone is pulling 200w while a 300w GPU means the whole board is splitting the power, not all of it is going to the die you're trying to cool.
As always delidding is an effective option and so is researching and getting an AIB card with a good cooler. Beyond that watercooling has almost no value unless you have the best possible GPU and still want a slight bump in perfomance, you're always better off going from a 2080 to a 2080 TI instead of spending even more on a loop.
Cooler is really only "better" if you're chasing higher clocks...otherwise there's nothing wrong with having a CPU that runs in the 80s under stress and a GPU that games in the high 70s. IF you still have a 10-20c delta between you coolest and hottest cores, yeah it might be a good idea to check the delid, there could be too much silicon making a gap or the TIM could be spread poorly.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #14 of 22 (permalink) Old 06-12-2019, 12:21 AM - Thread Starter
aabeba's Avatar
Rep: 0
While more performance is always nice, I'm quite happy with my 1080. But, more pertinently, my rationale would be that spending $1300 on a loop that would last me many years--with the occasional refill and replacement--would be a better investment than spending $1300 on a card I would likely replace within 5 years. And it would be a fun first time project, I'm sure. But it is disheartening that you can't get sub-60 temps on a fully overclocked CPU.
aabeba is offline
post #15 of 22 (permalink) Old 06-12-2019, 01:02 AM
professional curmudgeon
looniam's Avatar
Rep: 775 (Unique: 445)
get a 9X140 rad with noctua leaf blowers in push/pull and you'll be fine.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #16 of 22 (permalink) Old 06-12-2019, 07:17 AM
Andrew LB's Avatar
Rep: 23 (Unique: 18)
I've always had best results by delidding, then lapping the surface on the underside edge of the heatspreader so when you re-install it onto the chip, it sits a little lower and makes better contact. If the newer Intel chips are anything like my 4670k, there is a fairly substantial gap betweeen the core and the IHS. doing this also dropped my CPU temp an additional 15'c on top of the 15-20'c i got before i lapped the IHS.
Andrew LB is offline
post #17 of 22 (permalink) Old 06-12-2019, 02:38 PM
Rep: 0
My old AMD 2500 [email protected] was very happy at watercooling, and no way a air cooler could even match this system.
So i have difficulty to understand this GPU/CPU talk. They are diferent. Period.
Mordorr is offline
post #18 of 22 (permalink) Old 06-14-2019, 06:15 AM
broodro0ster's Avatar
Rep: 2 (Unique: 2)
A GPU has a much later die, so more heat transfer. And a CPU consumes less power than a GPU. So a CPU is more limited by heat exchanging capacities than by the cooler itself.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #19 of 22 (permalink) Old 06-14-2019, 06:42 AM
Overclocker
JackCY's Avatar
Rep: 309 (Unique: 225)
Dize size difference, die height difference, direct vs heat spreader cooling, GPUs are often very power limited or don't run at full blast/utilization of all it's parts at the same time, CPUs can burn hard and utilize a lot but again some instructions and loads run hotter than others, sometimes the hottest are simple repetitive loads, Linpack burner, Prime burner, ...
The heat density nowadays is very high on CPUs. Even GPUs.
JackCY is offline
post #20 of 22 (permalink) Old 06-19-2019, 05:14 AM
Ryzen Overclocker
Ph42oN's Avatar
Rep: 5 (Unique: 4)
If thats true, great. I feel like i didn't benefit much from watercooling my 1600x, only that i wouldn't have been able to run 4.2ghz at low ambient without.
RyzenAsus
(14 items)
Ryzen 5 1600X
Asus Prime X370-Pro
Asus RX 480 Dual 4GB
G.Skill Flare X 3200 CL14
WD10EZEX
ST3000DM008
XFX 550w
chinese water pump
Heatkiller IV
Barrow Dabel-60a 360
Cooler Master n300
Keyboard
Logitech G810
Mouse
CM Storm Xornet II
Mousepad
Blackstorm Iced
Ph42oN is offline
