Why do CPUs benefit so much less from good cooling than GPUs? - Overclock.net - An Overclocking Community
post #1 of 22 (permalink) Old 06-11-2019, 05:59 AM - Thread Starter
aabeba's Avatar
Rep: 0
So I'm a bit phobic of high temperatures in my system because I had a couple overheat and essentially become defective back in my prebuilt days. Therefore, now it's "the cooler the better".
Anyway, I delidded my 8700K recently because my 5.0 OC @ 1.35 V was hitting temps of 90+ under stress on all cores. It worked, except not entirely--now one core and the package are still close to 90 while the other cores hover around 70. Should I try reapplying the liquid metal?
Anyway, I'm considering getting into custom water cooling to replace my Noctua U14S and cool my GPU. However, I've heard that it might not make much of a difference at all. Why is it that GPUs can drop from 75 to 40 C under load when you switch from the stock (aftermarket) fan solution to a fully custom loop, while CPUs hardly seem better off? Is it worth the trouble?
aabeba is offline
post #2 of 22 (permalink) Old 06-11-2019, 06:07 AM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Usually yes delid is funky is why a core of more will be wonky hotter than others
Water depends just like air cooling depends on room temperature more than anything only a chiller can break this barrier
Both depend a lot on mounting to connect the dots of heat transfer
Delid complicates it because now you have liquid metal and it's spread to deal with instead of pigeon poop or solder in the past and now back to the present in 99..k & x series.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 22 (permalink) Old 06-11-2019, 06:35 AM - Thread Starter
aabeba's Avatar
Rep: 0
But why are CPUs specifically harder to cool as well as GPUs? And do you recommend I try delid my CPU again?
aabeba is offline
post #4 of 22 (permalink) Old 06-11-2019, 06:59 AM
ThrashZone's Avatar
Hi,
Can't add much more than I already posted
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 22 (permalink) Old 06-11-2019, 07:05 AM
OG AMD
Redwoodz's Avatar
Rep: 582 (Unique: 459)
Switch to AMD and you won't have that problem anymore. Cheap old Intel can't afford to put a decent heatspreader on their CPU's. Sad.
https://valid.x86.fr/cache/banner/4d8m5e-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(4 items)
RCPC#1
(17 items)
Professional
Ryzen 2200G
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Ripjaws PS850G
AMD Phenom II X6 960T
Asus M4A88T-VEVO
Asus Strix R7 370
SuperTalent Perfomance
GSkill Snipers
Monster Daytona
Seagate Barracuda 500GB 7,200 RPM 16Mb cache
Optical Drive
Memorex DVD/RW
Corsair GS500
Corsair H60
In Win H-Frame
Operating System
Windows 8N
IBM 9494 19" LCD
Keyboard
IBM
Mouse
OCZ Behemoth
Mouse
Wolfking
Audio
JBL Creature
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #6 of 22 (permalink) Old 06-11-2019, 07:14 AM
ThrashZone's Avatar
Hi,
Well you would have to specify which gpu not all are created equally
But water blocking a gpu would also cover core/ memory chips/ vrm's under the water block.
Water blocking a cpu only covers the chip
You still have memory and vrm's still on air.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #7 of 22 (permalink) Old 06-11-2019, 08:18 AM
TeslaHUN's Avatar
Rep: 20 (Unique: 18)
In my opinion there are 2 reason why VGA is responding much better on watercooling then CPU's.
-GPU chip has direct contact to VGA block , while CPU chip is not (there is a cap/heatspreader top on the chip itself)
-CPU has much more voltage then GPU (GPU 1V vs CPU 1,3V or so) so its harder to cool it . If u could reach: lets say 6ghz with only 1V ,ur CPU would be same hot as ur VGA (40-45C)
TeslaHUN is offline
post #8 of 22 (permalink) Old 06-11-2019, 08:40 AM
Not New to Overclock.net
fragamemnon's Avatar
Rep: 249 (Unique: 187)
I'd attribute it to two main things:
- Direct mount vs thermal interface materials used between the die and cooler/IHS
- Heat density - for example the RTX 2080 Ti has a die size of 754 mm^2 while an i9-9900k has a die size of 314 mm^2 (the former being 140% bigger). The GPU draws ~250W under torture while the CPU draws upwards of 160W even at stock settings (which is <60% difference).
Surely there are plenty of other factors, but I reckon these two are the most significant.
MEGATRON
(17 items)
GIGATRON
(10 items)
Ryzen 7 1700
Crosshair VI Hero
Gigabyte RX 580
2x8 G.Skill Trident 3200 CAS14 @ 3466 CAS14
2x1TB WD Black RAID 0
3TB WD Red
Samsung 840 Evo 250GB
FSP Aurum PT 1200W
Stock... hue hue
Thermaltake Core X9
Benq XL2411Z
Dell U2412M
Dell U2412M
Keyboard
KBC Poker II MX Clears
Mouse
Zowie ZA11
Mouse
old school Razer Goliathus
Audio
Aune T1 -> Yamaha A-720 -> Sennheiser HD650 | Sony MDR-XB500
Intel Xeon E5-2650 v4 @ 2.00GHz
SuperMicro X10DAL-i
nay
2x8GB (for now) Kingston DDR4 @ 2133MHz/C16
Samsung 840 120GB
SeaSonic SS850-AM
EK-Vardar F4 on an Arctic Freezer i11
overrated
Operating System
Ubuntu Server 16.04
fragamemnon is offline
post #9 of 22 (permalink) Old 06-11-2019, 09:27 AM
professional curmudgeon
looniam's Avatar
Rep: 791 (Unique: 451)
Direct mount Heat density
BOOM
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #10 of 22 (permalink) Old 06-11-2019, 10:13 AM
Tech Enthusiast
deafboy's Avatar
Rep: 439 (Unique: 335)
Pretty much this, but I'd also go one step further on the heat density part
GPU intensive applications are better at utilizing the "cores" so the workload is more evenly spread across the entire die
CPU applications are in many ways still single core/thread bound and as such the load isn't spread across the entire die but a small portion of it, ergo the heat spreader to begin with.
Direct mount helps though regardless in optimal uses
IN HONOR OF SYRILLIAN, R.I.P.
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
2 year anniversary In Remembrance of a Great - RIP Syrillian
Overkill FreeNAS
(10 items)
Intel Xeon E5-1680 V2
Asus Rampage IV Black Edition
nVidia Titan XP (2100/5200)
Corsair Dominator Platinum 32GB
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
2x Swiftech D5 w/ EK Dual Pump Top
XSPC EX480, EX360 & 2x Phobya 1080
EK Supremacy EVO CPU Block
EK Advanced 250mL Res
Lamptron FC-5V2
EK Rampage IV BE Water Block
Copper Tubing w/ push fittings
EK-FC Titan XP Copper/Acetal
Silverstone TJ07, heavily modified
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Sennheiser HD595 / HD428 / HD280
Audio
Corsair SP2500
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
12x HGST 4TB CoolSpin
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
deafboy is offline
