Water Cooling Loop Questions - Overclock.net - An Overclocking Community
post #1 of 29 (permalink) Old 06-11-2019, 09:58 AM - Thread Starter
Rep: 0
I am looking to build my first custom loop. That current plan is as follows.
Case: Corsair Obsidian 500D SE RGB
Fans: 3 extra Corsair LL120 RGB
Radiator: EK SE 360 and EK SE 240
Pump: EK D5 combo pump
Water blocks: EK RGB blocks
The parts I am cooling are:
i5 3570k @ 4.5ghz
GTX 1080 @ stock
Wanting to have this all Corsair iCue controlled. EK RGB parts will be connected to the Corsair environment with an RGB DAC. Will make custom LED rings to put on the hard tubes next to the fittings for glowing tubes.
The question is will 6 fans, 3 on the big rad and 2 on the small rad with on in the back as exauhst be enough to cool the system at a 4.5ghz overclock? Do I need the extra rear fan (not on a radiator)? Is the two picked out rads adiquite?
Gamer 217 is offline
post #2 of 29 (permalink) Old 06-11-2019, 10:13 AM
Shawnb99's Avatar
Rep: 59 (Unique: 40)
Look at Hardware Labs radiators instead. Look at making them intake rather then exhaust. Also look at Heatkiller blocks.
I'd suggest adding a flow and water temp sensor. Go for Mayhem's tubing and fluids
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #3 of 29 (permalink) Old 06-11-2019, 11:17 AM - Thread Starter
Rep: 0
Will a 240 and 360mm GTS rad keep everything cool with push only Corsair ll120s with my planned overclock?
Does heatkiller make universal GPU blocks? The EK Supremacy Evo can go from Intel to AMD with a bracket swap.
post #4 of 29 (permalink) Old 06-11-2019, 12:09 PM
I can count to potato
Fluxmaven's Avatar
Rep: 52 (Unique: 21)
I agree with everything Shawn said.
Also note that LL120's are designed to look pretty... They are not meant to be radiator fans. That said, with that much radiator space, you will be fine. Hardware labs GTS series should play nice with those fans.
Any D5 combo is going to be perfect for this setup. The EK units are good to go.
Yes, there are universal Heatkiller GPU blocks. They also make GTX 1080 full cover blocks. IDK if the EK Velocity CPU blocks come with both sets of mounting hardware, but my Supremacy Evo's both came with the AMD and Intel mounting stuff. The Heatkiller blocks, you can swap the hardware, but you have to buy it separately.
If you are going to be ordering stuff soon, http://www.performance-pcs.com/ has a few fathers day promo codes and they stock all the brands being discussed. They are the best places to get liquid cooling gear if you are in the US.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #5 of 29 (permalink) Old 06-11-2019, 12:26 PM - Thread Starter
Rep: 0
Thanks for the sale heads up. As for the fans yeah I heard the ll120s aren't that powerful but wanted to see if I could make it work. Think I'll have respectable temps (sustained at 75C or less) at 4.5 ghz under load?
post #6 of 29 (permalink) Old 06-12-2019, 08:53 AM - Thread Starter
Rep: 0
Also in addition to my previous question what prep work should be done aside from assembly itself and how good is distilled water mixed with Primochill Utopia (no additional additives).
post #7 of 29 (permalink) Old 06-12-2019, 09:18 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 440 (Unique: 293)
And I will also agree with everything @Shawnb99 said. But I will totally disagree with @Fluxmaven on the EK pump/res combo. Having had Heatkiller, Monsoon MMRS, XSPC Photon and several others, the EK doesn't come close in quality and construction. Also, if you are looking at PWM D5s, EK's have a lengthy history of issues.
If you are spending all of this money on a loop, why would you possible skimp on fans? I really question relying on the Corsair ecosystem for control, and would certainly never recommend a Corsair case.
ciarlatano is offline
post #8 of 29 (permalink) Old 06-12-2019, 09:56 AM - Thread Starter
Rep: 0
Current motherboard lacks a rgb header so my only options seem to be using a hardware controller (i.e. buttons) or a USB based software controller like iCue. If I can't get Corsair fans to play well with a two hardware labs gts rads then is there any way to get PhanTeks digital halos to work?
post #9 of 29 (permalink) Old 06-12-2019, 10:02 AM
Shawnb99's Avatar
Since you want a new case I suggest you take a look at some of the build logs to get an idea of what you want and are working with. Find what cases you like and see what people have done with them specially when it comes to custom loops.
Then copy what you like and discard the rest. Plan and plan some more then be ready to discard that plan when it doesn't work.
Everyone always suggests a D5 pump but I've always loved the MCP35X2 and even the single models. They are tiny, can be pretty quiet and have a lot of head. You also want a drain valve and a rotary for that, pick one from Bitspower as that's the one part you can't cheap out on since any rotary has the potential to leak.
Mix your distilled water with Biocide and Inhibitor from Mayhem's. I only need 2 drops every 3 months or so for 1.5L. If you're loop is smaller then go with that.
My Baby
(23 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #10 of 29 (permalink) Old 06-12-2019, 10:33 AM
ciarlatano's Avatar
It's not a question of the compatibility with the rads, it's more a question of why are you buying subpar fans in the first place?
Phanteks Halos work perfectly with Phanteks cases....and anyone who has ever owned both Phanteks and Corsair cases will tell you that the Phanteks cases (in the same price class, of course) are far superior....so, you may have an answer right there.
