Fans for radiator - Overclock.net - An Overclocking Community
Fans for radiator
post #1 of 19 (permalink) Old 06-22-2019, 11:27 AM - Thread Starter
tistou77's Avatar
Rep: 21 (Unique: 17)
Fans for radiator
Hello
It seems that the new Noctua a12x25 are slightly better than the Gentle Typhoon
Quieter at equal speed for the same performance and so it would be possible to increase the rpm of the Noctua to have more performance with a "noise" equal to the GT
Currently, my GTs are around 700rpm (P/P), and I'm wondering if I could have more performance with the Noctua and for less noise or identical noise
What do you think ?
Thanks for your advice
Sorry for my english
tistou's config
(19 items)
i9 10980XE
Asus Rampage VI Extreme Encore
EVGA RTX 2080ti XC Ultra
G.Skill Trident Z Royal @4000 C16
Intel Optane 905P PCIe (with WB)
Samsung 970 EVO Plus
Seasonic Prime Ultra Titanium 1000W
Alphacool VPP755 x2
Mod Pump Bitspower
Mod Pump Ek Waterblock
Ek Magnitude
Waterblock EVGA Hydro Copper XC
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Logitech Illuminated K740
Mouse
Logitech MX Revolution
Audio
Asus Xonar Phoebus
tistou77 is offline
post #2 of 19 (permalink) Old 06-22-2019, 01:03 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 453 (Unique: 299)
That information is readily available - https://www.techpowerup.com/review/n...x25-pwm/5.html
Essentially, you could run the Noctuas at 1000 rpm with the same dB rating as the GTs at 750 rpm.
ciarlatano is offline
post #3 of 19 (permalink) Old 06-22-2019, 02:24 PM - Thread Starter
tistou77's Avatar
Thanks for the link
Dark side GT are the same than Scythe GT (same characteristic I suppose) ?
tistou's config
(19 items)
i9 10980XE
Alphacool VPP755 x2
Mod Pump Bitspower
Ek Magnitude
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Mouse
Audio
Asus Xonar Phoebus
tistou77 is offline
post #4 of 19 (permalink) Old 06-22-2019, 05:10 PM
ciarlatano's Avatar
They are the same fans. GTs are made by Nidec, were marketed by Scythe. Now available through Darkside and with the Nidec branding.
Last edited by ciarlatano; 06-23-2019 at 06:27 AM. Reason: Because OCN sucks on mobile.
post #5 of 19 (permalink) Old 06-22-2019, 05:19 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1461 (Unique: 735)
mobile OCN takes another victim
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #6 of 19 (permalink) Old 06-22-2019, 06:01 PM
Section31's Avatar
Rep: 39 (Unique: 18)
Yes, you are right on Noctua A12x25. I am doing exactly what you are thinking (I can run fans at 1400rpm vs 1200rpm on GT2150). You can also look at the artic bionix p120/f120 if you want cheaper.
Section31 is offline
post #7 of 19 (permalink) Old 06-23-2019, 12:28 AM - Thread Starter
tistou77's Avatar
Ok, and you had a gain in performance (water temperature) or just a gain for the noise ?
Thanks
tistou's config
(19 items)
i9 10980XE
Alphacool VPP755 x2
Mod Pump Bitspower
Ek Magnitude
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Mouse
Audio
Asus Xonar Phoebus
tistou77 is offline
post #8 of 19 (permalink) Old 06-23-2019, 01:09 AM
TeslaHUN's Avatar
Rep: 23 (Unique: 21)
Quote: Originally Posted by tistou77 View Post
Hello
What do you think ?
700 rpm push /pull is already overkill for most radiator (especially for your Mo-ra3 wich has very low fpi 9 or 10, i dont remember ), maybe on monsta (86mm thick with high dense fins) u would realize some benefit from 1000rpm fans . I would not waste money on new fans if the performance is the main factor. Better solution is : add more radiator surface.
I have Mo-ra 420 with 9x noctua nf a14pwm pull , max 700 rpm on full load . I tested with extra 4x 20cm fan on the push side , and the imporvement was like 1 - 2celsius . That rad isnt airflow restrictive at all . Im planning to buy another Mo-Ra in the future if i can find one cheap on used market
TeslaHUN is offline
post #9 of 19 (permalink) Old 06-23-2019, 01:47 AM - Thread Starter
tistou77's Avatar
If I can increase the rpm to have more performance, and keep quiet, it suits me
No room for a 2nd MORA
tistou's config
(19 items)
i9 10980XE
Alphacool VPP755 x2
Mod Pump Bitspower
Ek Magnitude
MORA 3 9x120 (x2)
Lian Li A77FA
Operating System
Windows 10 Pro x64
Dell U2417H
Keyboard
Mouse
Audio
Asus Xonar Phoebus
tistou77 is offline
post #10 of 19 (permalink) Old 06-24-2019, 08:15 AM
Section31's Avatar
More radiator will drop temperature not fan.
Explore chiller route or add internal radiator.
