Buy new 560 radiators or keep my existing 480 - Overclock.net - An Overclocking Community
post #1 of 32 (permalink) Old 06-25-2019, 08:28 PM - Thread Starter
elderan's Avatar
Rep: 6 (Unique: 6)
I am working on a new build, I want to do a 4x rad setup. My old build which I am replacing already has 3x XSPC RX480 Radiator V3 on it with 12 LL120 corsairs fans.
Would changing to 4x 560 rads and Corsair LL140 fans see a significant cooling from the 480 rads and 120 fans?
If so what 560 rads should I get for these fans. Yes I want to stick to these fans for looks.
elderan is offline
post #2 of 32 (permalink) Old 06-25-2019, 09:04 PM
ttnuagmada's Avatar
Rep: 10 (Unique: 10)
Why LL's? Those aren't even in the top 3 best rad fans that Corsair makes.
ttnuagmada is offline
post #3 of 32 (permalink) Old 06-25-2019, 09:13 PM - Thread Starter
elderan's Avatar
Rep: 6 (Unique: 6)
All due to looks, I want RGB and I have tried multiple ones and the Corsair LL is by far the best looking out of the options. It has been a while since I had really nice fans though, before these the best real fans I had were corsair ML120 and before that Noctua NF-A14 140.
elderan is offline
post #4 of 32 (permalink) Old 06-25-2019, 09:25 PM - Thread Starter
elderan's Avatar
Rep: 6 (Unique: 6)
I would be willing to consider the corsair ML RGB series if I switch to 140 fans. I am not sure how they look compared to the LL series, I am sure not as bright but would consider it.
I guess my main question is 4x 460 vs 4x 560 and is it worth it given I already have 3x XSPC 480 rads and the fans.
Either way I would like to know the best 560 rad for the LLs and maybe the MLs.
elderan is offline
post #5 of 32 (permalink) Old 06-25-2019, 09:35 PM
ttnuagmada's Avatar
Well that depends on what you're cooling really. 3 480's should really be fine for just about anything at super low fan speeds. I have a 560/480/280 and it's enough to keep a heavily OC'd 3770K and 2 heavily OC'd 1080 Ti's at low temps with like 400 rpm fan speeds. My 1080 ti's don't see temps north of 40C in most cases (21C ambient).
post #6 of 32 (permalink) Old 06-25-2019, 09:39 PM - Thread Starter
elderan's Avatar
Rep: 6 (Unique: 6)
Doing a 2 loop system,2 rads per loop, 1 loop is cooling a 2990wx cpu block and vrm block, 1 loop is cooling 4x vega 64.
I have a thermaltake wp200(top and bottom) case so I can fit up to 2x 560s in top and the bottom sections. I dont want any raids in the main sections I dont think.
elderan is offline
post #7 of 32 (permalink) Old 06-25-2019, 09:44 PM
ttnuagmada's Avatar
You'd probably definitely see some improvement on the GPU end of things. 2 560's is probably overkill for the CPU though. Maybe 1 560 for the CPU and 3 for the GPU's? You're probably looking at twice the heat output on the GPU side of things vs the CPU.
post #8 of 32 (permalink) Old 06-25-2019, 09:53 PM - Thread Starter
elderan's Avatar
Rep: 6 (Unique: 6)
While I agree, I think having 2 different sizes/amount in the top and bottom will look funny.
If I went with corsair ML140 fans what is the best 560 rad to go with? I was debating on the EK CE 560 rad.
elderan is offline
post #9 of 32 (permalink) Old 06-25-2019, 10:00 PM
ttnuagmada's Avatar
I'm a big fan of the HWL SR2. It performs near the top in almost any scenario and it has a lot of port flexibility.
post #10 of 32 (permalink) Old 06-25-2019, 10:09 PM - Thread Starter
elderan's Avatar
Rep: 6 (Unique: 6)
So if I go the 560 route I should get the Hardware Labs Black Ice SR2 560mm? And do some corsair ML140 RGB fans if I want to stick to RGB which I am pretty sure I do.
elderan is offline
