CPU temps creeping.... - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 06-26-2019, 12:23 AM - Thread Starter
Storx's Avatar
Rep: 0
I was curious if anyone is aware of intel internal thermal substance goes bad over time...
I ask this because I am running an old CPU in my current rig waiting out the release of Zen 2 here in a few months, but something i have noticed since switching my old rig from air to full custom watercooled is the CPU temp is always the hottest part in the system and seems to have increased in temps just slightly since building the rig 9 months ago...
The system:
Corsair 1000D
4x RX480 rads
26x Noctua Relux pressure fans
Intel i7 4770k
2x EVGA GTX1080ti SLI
I am using Heatkillers PRO series CPU and GPU blocks in the rig....
Idling the system, the GPUs sit at 21c and rise to the high 20s during gaming.... typically between 27-29c
The CPU idles 21c, but rises to the low 40s during gaming... when i first built this rig the CPU would max out at 39c during gaming...
Recently i pulled the CPU off to check thermal paste and placed new thermal paste on the CPU with no change in the temps... I'm using thermal grizzly Kryonaut on both CPU and GPU
Storx is offline
post #2 of 8 (permalink) Old 06-26-2019, 01:25 AM
RIP OCN
Rep: 28 (Unique: 21)
Is it summer where you are? A few degrees difference is nothing to worry about, the temperature in the room could be affecting it from the last time you monitored. Low 40's is nothing to worry about.
anti-clockwize is offline
post #3 of 8 (permalink) Old 06-26-2019, 03:18 AM - Thread Starter
Storx's Avatar
Rep: 0
I run the main house at 78F, but I installed a 120v 6k BTU pioneer mini-split in my office keeping the room at 72F about 6 years ago, so I could close the door to the room and game/work since the home a/c just didn't cool the room properly if I closed the door. I work on the computer as a realtor a lot, so I wanted to be comfortable in the room I worked in. I also replaced the room door with an insulated door meant for the front door of a house and insulated the room with Rockwool to stop the sound traveling in and out of the room, because the interior walls were hollow.
Storx is offline
post #4 of 8 (permalink) Old 06-26-2019, 04:01 AM
I Love this Hobby!
Gunderman456's Avatar
Rep: 612 (Unique: 504)
You're good. Those temps are better then mine on a similar configured rig.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
PC-JMK5-Cool 5 Open Frame Case
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is offline
post #5 of 8 (permalink) Old 06-26-2019, 04:42 AM
deepor's Avatar
Rep: 485 (Unique: 330)
Maybe it's related to newer versions of the CPU "microcode" that were released for the "Spectre" and "Meltdown" security issues? When the microcode updates came out, people noticed that their overclock settings behaved differently and needed more Vcore for stability. Perhaps the different behavior also causes a change in temperatures?
This "microcode" thing is first loaded into the CPU by the motherboard when you power on the computer. Then later when Windows boots, it can also load a version of the microcode into the CPU. This means the CPU microcode version you are using can change by itself through a Windows update without you doing anything.
deepor is online now
post #6 of 8 (permalink) Old 06-26-2019, 04:47 AM
apw63's Avatar
Rep: 65 (Unique: 56)
It’s possible you have a small build up of crude in the CPU block. When was the last time it was opened up and inspected?
My System
ASUS ROG Swift PG278Q Owner's club
Asus Maximus XI Formula, 8700K, Corsair Dominator Platinum ROC 3200 16GbB, Asus ROC STRIX 1080 Ti OC version.
apw63 is offline
post #7 of 8 (permalink) Old 06-26-2019, 05:37 AM - Thread Starter
Storx's Avatar
Rep: 0
Actually that was something i was concerned of also, being my first watercooled system and going the route of just pure distilled water with antibacterial added, so when i redid the thermal paste, i took the cpu block apart and this is how it looked after 9 months of use... i found no residue on anything i inspected...
Storx is offline
post #8 of 8 (permalink) Old 06-26-2019, 05:57 AM
Overclocker in training
ThrashZone's Avatar
Rep: 189 (Unique: 114)
Hi,
This could easily just be paste application difference.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
