Coolant on a graphics card - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 06-27-2019, 01:48 AM - Thread Starter
Sphere07's Avatar
Rep: 8 (Unique: 5)
So the graphics card was plugged into the PCI-E slot, but the 8 + 6 PCI-E power cables were not connected. And sadly the water found a way to bypass my paper towel. Stupid EK flow meter leaked 1 droplet in the fill.
So is my card fine?
I have removed all water, but how long will it take to dry the moisture that probably exists?
Sphere07 is offline
post #2 of 8 (permalink) Old 06-27-2019, 04:13 AM
Missing the Old days
Cerberus's Avatar
give it a day in sunlight to be safe, you can also dampen the area with rubbing alcohol and dry with a paper towel
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is online now
post #3 of 8 (permalink) Old 06-27-2019, 04:51 AM
PC Enthusiast
VeritronX's Avatar
Rep: 31 (Unique: 31)
My mate had a northbridge block leak while his pc was on back in the day and the coolant went all over the back of the card and through the pci-e slot, we got most of it off with paper towels and a hairdryer then let it dry for a few days and it worked fine.. with a bit of a green tinge to it afterwards =P
The coolant he was using was the swiftec stuff that came with the kit mixed with distilled water.
VeritronX is offline
post #4 of 8 (permalink) Old 06-27-2019, 04:58 AM - Thread Starter
Sphere07's Avatar
Rep: 8 (Unique: 5)
Good thing I had the brains to not plug it in yet. Also didn't fall for the trap that a lot of people make which is to check immediately if it still works.
Sphere07 is offline
post #5 of 8 (permalink) Old 07-04-2019, 10:57 AM - Thread Starter
Sphere07's Avatar
Rep: 8 (Unique: 5)
The card works. After taking the backplate off and drying it with paper towel, I left it to dry for a day, and then after borrowing a soldering station, used heat at 160C to blow across the impacted area to dry out any moisture that might be hiding under chips. Did that for 10 minutes. After that, waited another 30 minutes before turning it on. All works.
Sphere07 is offline
post #6 of 8 (permalink) Old 07-05-2019, 03:26 AM
Rarestbreed's Avatar
Rep: 0
You may need to send me a link to a EK flow meter. Never heard of one, can't find one. Nevertheless, It's not the factories fault if we don't nip our fittings up tight.
Case: Corsair 900D. CPU: [email protected] MB: Asus Rog Max XI Formula. RAM: Corsair Vengeance 3000mhz. GPU: GTX 1070 EVGA FTW 2. Drives: 2X Sam 960 Evo 500gb, 2x Sam 850pro 256gb, Sandisk Ultra 11 960Gb, Lacie 4tb external drive (USB type C.) PSU: Corsair RM 1000i.
Watercooling: HWL Nemesis GTX 420/54mm (push only.) Alphacool UT60 420/60mm (push only.) Res: EK X4 250 (R2.0.) Blocks: Cuplex Kryos Next w/Vision. EK Full cover GPU block, EK/ ASUS Crosschill 3. Pump: EK D5.
Aquaero 6 Pro.
Rarestbreed is offline
post #7 of 8 (permalink) Old 07-06-2019, 07:36 PM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
I sure wouldn't promote the idea exactly but in my experience cards are less fragile than they may seem. I've had fairly large spills over graphics cards that were dried with paper towels and plugged right back in, some artifacting was seen so isopropyl alcohol and compressed air was applied with perfect results.
Coolant shouldn't be like spilling tap water at least.
Ashcroft is offline
post #8 of 8 (permalink) Old 07-08-2019, 10:50 AM
Moderately Ancient
Andrew LB's Avatar
Rep: 26 (Unique: 21)
Make sure it is NOT your normal rubbing alcohol. The most common rubbing alcohol is 70% iso and 30% water. Many pharmacies will also carry 91%, which is the stuff you want to use. If you don't see it, you may have to ask the pharmacist. If you buy online, you can also get 99%. I have yet to find a place i can walk into and purchase that strength.
Intel i7-10700K @ 5.2 - Asus Prime z490-A - EVGA GTX 1080 - 32gb Corsair DDR4 3600mhz - Creative X-Fi Titanium HD - Adata 1tb M.2 - Samsung 512gb 860 Evo + 512gb 850 Evo - Phanteks Enthoo Pro M - Watercool DualDDC Top - 2x DDC1-T PWM 10w Pumps - XSPC Raystorm V3 CPU block - AquaComputer Pascal block - Barrow Tube Res - XSPC ex360 Rad w/3x Fractal Venturi 120mm fans - XSPC ex280 Rad w/2x 140mm Phanteks 140mm fans - Aquaero 5LT + Flow Meter - 14mm Barrow Fittings - Crystal-Link Acrylic Tubing
Andrew LB is offline
