EK-Velocity AMD RGB - Nickel + Acryl the third time broken - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 07-13-2019, 01:00 AM - Thread Starter
Rep: 1 (Unique: 1)
Hello,
I'm very upset.
My water block is
EAN: 3831109810316
MPN: 3831109810316
now the third water block is broken.
it's always the RGB lightning cable that does break at its attachment point or the black rubber insulation for the cable retracts and exposes the blank copper wires.
no matter how carefully I mount the water block and believe me I'm not pulling the cable at all!
it is sufficient if the cable swings back and forth, which loosens it up.
the wires are finer than a human hair and have no resistance.
the result is either one or more broken wires or one or two wires touch each other and cause a short-circuit!
this is unacceptable for such high priced €89.90 water block.
this is crap quality here.
this is a serious product defect.
I would like to know what ekwb has to say about this?
and another thing, every time when i get a replacement water block the RGB cable is already loosened, it looks like someone pulled on the cable or it has been incorrectly fastened during assembly.
now not only the EK-Velocity AMD RGB - Nickel + Acryl water block is not glowing anymore, it also had a short circuit in it and has killed my RGB_Header_1 on my €600 motherboard.
thankfully i have another RGB_Header_2 that does work.
as far as I can see the R pin on the RGB_Header_1 (+12V, R, G, B) isn't working anymore and the color Red does not work, only Green and Blue work.
you know what the problem is with the RGB cable?
THERE IS NO STRAIN RELIEF FOR THE RGB CABLE!!!
every serious competent electronics manufacturer uses strain reliefs in his products.
and another thing you should do is fix the black rubber insulation at its end with with a small dot of hot glue.
ekwb is maybe good at making cooling solutions hardware but you just suck at electronics. you have no knowledge whatsoever about it.
now I don't know what to do.
I'm trying to figure out if i can do a strain relief for the cable myself.
perhaps use cable ties or hot glue to fix the RGB cable in place or just forget everything and buy a RGB plexi water block from someone else who knows how to make a quality product.
I'm thinking about reporting the case to the consumer board.
SilverAmd is offline
post #2 of 3 (permalink) Old 07-17-2019, 08:58 AM - Thread Starter
Rep: 1 (Unique: 1)
Hello EKWB,
thank you so much. you guys are great!
I just got the new waterblock and and I've seen improvements.
this is the reason I always buy from you, because you are the best.
thank you again.
Še enkrat hvala.
post #3 of 3 (permalink) Old 07-17-2019, 09:46 AM
Overclocker in training
ThrashZone's Avatar
Rep: 188 (Unique: 113)
Hi,
Yeah love them if you want too
I see no point in outing the wire under the mounting plate and also straight down towards the board.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
