Zen2 waterblock comparison - Page 4 - Overclock.net - An Overclocking Community
post #31 of 69 (permalink) Old 08-12-2019, 02:14 AM
mongoled's Avatar
Rep: 30 (Unique: 23)
I just had this confirmed to me by EK support.
Quote: Originally Posted by EK Support
The R&D guys checked in details the things again and unfortunately, the temps that were displayed in the graphs are correct and this is sort of expected for the monoblock that has the older Supremacy core design (fins), so the best possible option would be to use the Velocity block on the CPU as it has the new core design and that could have made the temps bit lower than with the monoblock.
Now I am off to research the differences between the supremacy and velocity, to see if I can modify my monoblock to improve performance.
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium | Ryzen 5 3600 2016SUS BCLK @107.5625 | EDC @3
Viper Steel Series PVS416G413C9K @ 3800/1900 mhz | 1.552v | 14-15-14-12-26-38-247-16-1T
Asus GTX 780 DCII OC @ 1332/3522 mhz, 1.3v | Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x NF-A12x15 | 2 x ML120 | PWM
mongoled is offline
post #32 of 69 (permalink) Old 08-12-2019, 07:46 AM
zGunBLADEz's Avatar
Rep: 105 (Unique: 76)
This... TDP is what it needs to take care off
Btw with a monoblock you always gonna have higher cpu temps than a cpu block thats just how it works.
Cpu cooling is the most tedious thing to cool on any loop. You can have the best loop ever and the cpu is going to drag.
zGunBLADEz is offline
post #33 of 69 (permalink) Old 08-13-2019, 02:51 AM
mongoled's Avatar
Yeah, of course temps are going to be higher, though looking at other results from custom loops and CPU used etc, im not doing too bad.
Regards the advice from EK, looking at comparative reviews the velocity does not show any significant gains compared to its predecessor.
Probably why the advice from EK was carefully worded to say the following
snip......as the older Supremacy core design (fins), so the best possible option would be to use the Velocity block on the CPU as it has the new core design and that could have made the temps bit lower than with the monoblock.
mongoled is offline
post #34 of 69 (permalink) Old 08-14-2019, 04:41 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Saw this today:
https://hothardware.com/reviews/all-...-with-maingear
3900X PBO 3 4.13GHz on liquid (probably Bitspower Touchaqua kit) = 69.57°C in CB R20
Power draw per Ryzen master = 12% of 1200W so around 144W
EDC current draw per Ryzen master = 26% of 600A which means ~156A
TDC Current draw per Ryzen master = 18% of 540A which means ~97A
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #35 of 69 (permalink) Old 09-17-2019, 05:03 AM
BeeDeeEff's Avatar
Rep: 2 (Unique: 2)
What websites/blogs/forums other than this one should I follow if I'm still interested in comparative waterblock performance for zen 2? Haven't heard much discussion on this topic in a few weeks but I'm still waiting for the 16-core chip to come out to finalize things.
AMD Ryzen 9 3950X
Gigabyte X570 AORUS MASTER
Radeon VII
G.SKILL TridentZ RGB F4-3200C14D-32GTZR
ADATA XPG SX8200 Pro M.2-2280
Corsair HX
Watercool ​HEATKILLER​® IV PRO (​AMD proces​sor) BLACK​ COPPER
Phanteks Glacier for Radeon VII
Hardware L​abs SR2 42​0mm Radiat​or
Thermaltake Core P5 ATX Mid Tower Case
Operating System
Windows 10 Pro
BeeDeeEff is offline
post #36 of 69 (permalink) Old 09-17-2019, 05:43 AM
Rep: 57 (Unique: 43)
Just for some useful information I checked what kind of temperature my setup would get when running fully topped out 3800X with a Alphacool Eisblock XPX.
Mounted in the regular orientation with intake to the left and outflow on the right. That makes the channels run up and down vertically on the block crossing the dies on their short sides up and down. Water coming in just between the IO-die & core-chiplet.
3800X 1.525V @ 4450Mhz CPU with 4x8GB 4266Mhz MEM & LLC ULTRA EXTREME (no vdroop)
CB R20 ~160W, 86A = 90-91C
IBT Very High 10x ~180W, 100A = 95-100C
I pushed full RPM on all fans to reach 28C water temperature with 24-25C Ambient.
Though I have to note my GPU says 26C so maybe water temp is even lower.
1x360 & 2X120mm 45mm thick radiators with a DDC-1T Plus.
Wattage = PPT
Amperage = TDC
Gigabyte X570 AORUS XTREME, Ryzen 7 3800X PBO boost, 2x8GB 4866/1900 18.27.24.48.90.tRFC 680 1T 1.650V [Micron Rev.J]
4x8GB 3800/1900 13.23.17.30.66.tRFC 600 1T 1.700V Kingston HX434C19FB2K2/16 3466C19 1.2V (Micron Rev.E 19nm [D9VPP]),
2x8GB Kingston HX436C17FB3K2/16 3600C17 1.35V (Micron Rev.J 17nm),
2x8GB 3866/1933 15.21.20.32.60.tRFC 448 1T 1.590V Kingston HX436C17FB3K2/16 3600C17 1.35V (Hynix DJR 17nm)
Nighthog is offline
post #37 of 69 (permalink) Old 09-17-2019, 12:28 PM
Rep: 2 (Unique: 2)
Looking for some feedback
moved to separate thread
Ryzen 3950X Build
(18 items)
3950X
Gigabyte X570 Aorus Extreme
PowerColor RX 5700XT Liquid Devil
MSI RX 5700 XT Water cooled
GSkill F4-3600C16D-32GTZN X 2
Samsung NVMe EVO 970
Samsung SSD 850 Pro
GB Aorus NVMe Gen4 SSD
Optical Drive
LG BDDVDRW
Seasonic
Optimus Foundation water block/custome loop with 360 rad.
Lian Li 011 Dynamic XL
Operating System
MS Win10 Pro
Samsung LC27HG70QQNXZA
Keyboard
Logitech G815
Mouse
Logitech G502
Other
Liquid Metal Conductonaut used on CPU and GPU
jfrob75 is offline
post #38 of 69 (permalink) Old 10-22-2019, 09:24 PM
jakemfbacon's Avatar
Rep: 8 (Unique: 7)
So I am in need of a new cpu waterblockfor my 3900x. Which should I go with and what is the best site to buy from these days? I'd like to get on amazon if possible.
jakemfbacon is offline
post #39 of 69 (permalink) Old 12-03-2019, 11:41 AM
Haldi's Avatar
Rep: 1 (Unique: 1)
Yeah... i'm stuck on the same one here.
Using Google you find almost nothing. Seems like all those cheap AiO's totally killed the last bit of surviving Waterblocks reviews.
Seems like the "Watercool HEATKILLER® IV PRO" is the thing to go. (Difference Pro vs Basic: https://watercool.de/wbb/index.php/T...-basic-vs-Pro/)
Price difference is like 10.-
Other things that fit AM4 would be:
Bykski AMD AM4 CPU-RYZEN-X-MK-S
XSPC RayStorm Neo WaterBlock
Aquacomputer cuplex kryos NEXT AM4
Though i'm not sure others than the Bykski and XSPC RayStorm have a big enough groundplate to fill the whole CPU....
Anything i missed?
Haldi is offline
post #40 of 69 (permalink) Old 12-03-2019, 11:49 AM
Old dog, likes new tricks
Bart's Avatar
Rep: 83 (Unique: 68)
Anything i missed?
Nope, you listed the only block that really matters. But seriously, Watercool makes amazing gear. EK's cheap crap cannot compare to anything in the HeatKiller line. Once you hold one in your hands, you'll understand. They might not be as widely available than other supposedly 'top' brands (lulz), their quality is LEAGUES above stuff like EK and Corsair. I'd order directly from them if you can't find them anywhere else. If they can ship DHL to Canada in a decent time frame, and not let Canada Customs ruin it, they can ship anywhere.
Bart is offline
