All EK aluminum rig Getting very high temps on both cpu and gpu. Help me fix my first system - Page 2 - Overclock.net - An Overclocking Community
post #11 of 85 (permalink) Old 07-29-2019, 06:51 AM
Overclocker in training
ThrashZone's Avatar
Rep: 189 (Unique: 114)
Hi,
SE is a poor choice PE is best ek low end rad series.
If draining might as well get a flow meter and water temperature sensor they will pretty much answer any questions about flow and why temperatures are what they are.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is online now
post #12 of 85 (permalink) Old 07-29-2019, 07:11 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 453 (Unique: 299)
Quote: Originally Posted by Slickdall View Post
Any idea what’s causing these high temps?
What you are describing is typically indicative of poor contact. We have a seen a number of cases of this on the GPU with these blocks, but this is the first I have seen with a CPU.
Do you have an inline temp sensor? That would certainly help in diagnosing the issue (not to mention it is really a necessity for proper liquid cooling).
And as mentioned, the SE is a really poor rad choice. Between that and the aluminum blocks, you need to temper your expectations.
ciarlatano is offline
post #13 of 85 (permalink) Old 07-29-2019, 07:28 AM - Thread Starter
Rep: 1 (Unique: 1)
I will try a reseat and see what happens. No inline temp sensor but maybe I can add one when I drain. But I get fine idle temps, wouldn’t a bad seat b evident then>?
Also my distro block has flow meter and it’s moving pretty fast
Slickdall is offline
post #14 of 85 (permalink) Old 07-29-2019, 07:40 AM
I can count to potato
Fluxmaven's Avatar
Rep: 56 (Unique: 24)
Do you have a an 8700k and a 2080 all being cooled by a single aluminum 360mm? How fast are you running your radiator fans?
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
64GB TridentZ 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #15 of 85 (permalink) Old 07-29-2019, 08:30 AM
ciarlatano's Avatar
Poor contact will typically show only slightly elevated idle temps, and will only become problematic under load.
post #16 of 85 (permalink) Old 07-29-2019, 08:39 AM - Thread Starter
Rep: 1 (Unique: 1)
Yes, single aluminum rad.
Fans are running around 1200 rpm and they are High static pressure fans
post #17 of 85 (permalink) Old 07-29-2019, 03:29 PM
ThrashZone's Avatar
Hi,
As you've seen if all suggestions do little than more rad space will help a little more to dissipate the heat.
You should look into different rads
Hardware labs is usually the go to rad around here
Whether GTS or other anything would be better than SE series
That reservoir is cool looking but limits where rads can go
About all that is open for another rad is the back
If stuck with EK PE series minimum and x2 top and back.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #18 of 85 (permalink) Old 07-29-2019, 04:28 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Quote: Originally Posted by ThrashZone View Post
Hi,
I don't think you've been paying attention as he has an aluminum kit. The best option is to get rid of it on Ebay and put in copper components. Putting 1.5-2x the radiator space just to match thermal conductivity of copper is kind of ridiculous.
It's $500 worth of aluminum ($380 if you don't count the case) https://www.amazon.com/PowerSpec-PC-.../dp/B07RN9GVFJ
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #19 of 85 (permalink) Old 07-29-2019, 06:19 PM
ThrashZone's Avatar
Hi,
Only items I read that were aluminum were the cpu and gpu blocks
SE series rad is copper
One can mix metals with the right liquid but it is risky but can be done obviously not with just distilled water.
Didn't see anything about buying a 500.us aluminum kit seeing the op got a nice bitspower I believe reservoir.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #20 of 85 (permalink) Old 07-29-2019, 06:27 PM
⤷ αC
AlphaC's Avatar
He wrote:
All ek aluminum parts. Parts below
COOLING: EK-FG PC-011 Distribution Plate
EK-FG Velocity AX Intel 115X – Plexi
EK-AC GeForce RTX
EK-Vardar S 120ER D-RGB
EK-HDC ALU Fitting 12mm – NICKEL
EK-Alustream SE 360 Lite (Triple)
Alustream is aluminum
https://www.ekfluidgaming.com/ek-fg-360-expansion-pack
EK-AluStream 360 RADIATOR
It offers high-class cooling performance for its thickness of just 27.5mm. Dense aluminum fins combined with a slim profile provide a huge cooling surface, while the radiator remains highly compatible with larger cases on the market. The EK-AluStream SE 360 radiator is optimized for maximum heat dissipation across the entire operational range of the fan thus delivering exceptional performance at both low and high airflow operation.
https://www.microcenter.com/product/...-lite---triple
Material: Aluminum
AlphaC is offline
