All EK aluminum rig Getting very high temps on both cpu and gpu. Help me fix my first system - Page 3 - Overclock.net - An Overclocking Community
post #21 of 85 (permalink) Old 07-29-2019, 06:32 PM
professional curmudgeon
looniam's Avatar
Rep: 840 (Unique: 465)
sorry didn't see alpha's post.
Spoiler!
fwiw, my 280CE (45mm thick) prolly has a higher cooling capacity and my fans run 1450+ just to keep my water temps ~10c above ambient w/3770k (4.7/1.3) 980ti (1500/1.27v) gaming for hours.
check the mounting but really get a bigger rad and crank up the fans - maybe get some noctua leaf blowers?
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
If you need help: Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #22 of 85 (permalink) Old 07-29-2019, 08:26 PM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by AlphaC View Post
I don't think you've been paying attention as he has an aluminum kit. The best option is to get rid of it on Ebay and put in copper components. Putting 1.5-2x the radiator space just to match thermal conductivity of copper is kind of ridiculous.
It's $500 worth of aluminum ($380 if you don't count the case) https://www.amazon.com/PowerSpec-PC-.../dp/B07RN9GVFJ
Ha funny you say that. I priced out what I needed to go copper and it was like $380 with all ek parts. I only need 12 fittings, the gpu block, cpu, and a SE360 rad. Would that be good enough ? I don’t want to add a second rad as spacing is an issue with the distro block and my vert mount.
Slickdall is offline
post #23 of 85 (permalink) Old 07-29-2019, 08:29 PM - Thread Starter
Rep: 1 (Unique: 1)
Spoiler!
Thanks for the help bud. I think I just need to get copper bits and sell my aluminum stuff to the next person, what a expensive learning curve in water cooling!
post #24 of 85 (permalink) Old 07-29-2019, 09:43 PM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Well if you do go with copper parts (best option instead of throwing even more money into aluminum parts that only EKWB makes) I would suggest you go with $51 XSPC TX360 radiator which is 20mm thickness and has 22FPI. Hardwarelabs Nemesis GTS normally is recommended in the 30mm thickness but it's out of stock at PerformancePCs. EKWB's SE radiator is consistently the worst performing slim radiator. Alphacool's ST30 slim radiator is better performing with less flow restriction and similar FPI, but it doesn't have the thermal performance of the HW Labs (highly flow restrictive) or XSPC radiator (a bit more airflow restriction due to higher FPI). Swiftech also makes the Hydrae GT in 27mm thickness with 14FPI but I haven't seen many reviews on it.
I don't know if you can reuse the distribution plate and such , maybe there's no aluminum in the pump + reservoir. S1 pump is probably some sort of DDC variant.
For Intel LGA1151 CPU block there's many options with that kind of aesthetic,
EK Classic RGB $70 http://www.performance-pcs.com/ek-su...kel-plexi.html
XSPC Raystorm Neo $80 https://www.performance-pcs.com/rays...el-chrome.html , https://www.amazon.com/XSPC-RayStorm.../dp/B074G43BKZ
EK Supremacy Evo RGB $85 http://www.performance-pcs.com/ek-su...kel-plexi.html
Aquacomputer Cuplex Kryos Next $88 https://www.performance-pcs.com/aqua...ic-nickel.html
Alphacool Eisblock XPX clear version $83- 90 https://www.outletpc.com/vp3512.html (satin not fully clear), https://www.performance-pcs.com/wate...r-version.html
EK Velocity A-RGB version is $110 (pricey) www.performance-pcs.com/ek-velocity-d-rgb-nickel-plexi.html
Fittings (don't use aluminum fittings with copper products) you can get for about $5 each from Barrow or any mainstream watercooling brand (EKWB, XSPC, Alphacool, Swiftech, etc.)
For GPU RTX 2080 block there's many options,
$145 Heatkiller Acrylic + Nickel RGB variant https://modmymods.com/watercool-heat...rgb-15601.html
$140 Eisblock GPX https://modmymods.com/alphacool-eisb...m01-11662.html
$128 EK Classic Nickel Plexi https://www.amazon.com/EKWB-EK-FC-Cl.../dp/B07PMLTY4S / https://www.ekwb.com/shop/ek-fc2080-...classic-nickel
$160-175 EKWB Vector (not worth it over Heatkiller...) https://www.microcenter.com/product/...--nickel-plexi , https://www.amazon.com/EKWB-EK-Vecto.../dp/B07GZZT78Y
Should be right around $300 considering how many fittings you have to swap.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #25 of 85 (permalink) Old 07-30-2019, 01:21 AM
looniam's Avatar
you're welcome. hey, atleast you didn't have a leak that soaked the rig, making it a really expensive lesson.
alpha has some good suggestions for copper parts. you can also look at http://thermalbench.com/ and https://www.xtremerigs.net/ for what stuff does (rads, pumps and blocks) to get an idea what kind of heat dissipation you can expect. you can also take a cruise through the watercooling pic thread (stickied in this sub forum) and see the show offs (meant nicely). might give you a better idea where/how to put stuff.
i'm lazy, i bought the EK 280P kit added a uni block for my gpu a little later. i could have gotten better/cheaper buying individually but well i had no idea what all i would need. however you're halfway there having built a rig already.
i suggest you consider going a little over kill on the rad and getting a nice strong pump.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EKWB P280 kit
EK-VGA supremacy
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
looniam is offline
post #26 of 85 (permalink) Old 07-30-2019, 02:51 AM
dontworkSundysormedaysoff
buellersdayoff's Avatar
Rep: 7 (Unique: 7)
If your gpu temp is shooting straight up almost instantly under load then you're probably looking at poor contact. However if it's a gradual rise in temps then it's more likely insufficient cooling. A copper system over aluminum won't be a huge difference.
AIRBOURNE
(10 items)
buellersbox
(17 items)
i7 7700k
asus maximus viii hero
msi 1080ti gaming x
corsair 3200mhz
samsung 950 nvme
corair rm850x
cryorig r1 universal
TT modified
Operating System
win10
acer predator x34
i7 6700k
Asus maximus VIII Hero
Msi gtx 980ti
Corsair
samsung 950 pro m.2
samsung ssd
2tb spinner
Optical Drive
blu-ray rw
Corsair RM850x
custom EKWB
Phanteks
Operating System
windoze 10
Acer X34 gsync
Keyboard
Logi Orion G910
Mouse
Logi G502
Mouse
Logi 440
Audio
Kingston Hyperx cloud II + Edifier R1280T
buellersdayoff is offline
post #27 of 85 (permalink) Old 07-30-2019, 04:40 AM
Overclocker in training
ThrashZone's Avatar
Rep: 189 (Unique: 114)
Hi,
Not sure why heatkiller iv pro cpu block wasn't suggested about the best block around
Seems silly to suggest a heatkiller gpu block and not the cpu block
I too was a 280p ek kit buyer
CE series rad that are mediocre at best
EK fans suck but can probably get you by for a little while if they work at all
And of course ek premix cryocrap fluid I still have nightmares from using
Live and learn.
Like I said that pretty reservoir limits rad space if it's aluminum too don't get used to distilled water only which is not recommended anyway.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is online now
post #28 of 85 (permalink) Old 07-30-2019, 05:19 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
A 360 SE isn't super good tool cool all the stuff, but the watertemp should stay around 45°C imo. And this means the GPU should stay under 65°C as well. If you're seeing 80°C on the GPU, then something isn't right.
I'd check the screws and thermalpads on the GPU. Maybe the screws are too long or the thermalpads are too thick. And remount everything. My 1080TI was around 50°C with a single 360GTS and with my dual rad setup, the temps dropped to 40°C.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #29 of 85 (permalink) Old 07-30-2019, 05:33 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 453 (Unique: 299)
Quote: Originally Posted by ThrashZone View Post
Hi,
@AlphaC specified that the blocks shared the type of look the OP was going for. The HeatKiller IV is great, but has a totally different look.
ciarlatano is online now
post #30 of 85 (permalink) Old 07-30-2019, 05:48 AM
ThrashZone's Avatar
Hi,
Plexi is plexi
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
