All EK aluminum rig Getting very high temps on both cpu and gpu. Help me fix my first system - Page 9 - Overclock.net - An Overclocking Community
post #81 of 85 (permalink) Old 08-09-2019, 06:20 PM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by EKJake View Post
Glad it got resolved then!
For the instructions, could anything have been clear or different? We're in the process of analyzing our instruction manuals and updating them accordingly.
I could be wrong but I think I received only 1 size thermal pad, all 1mm. That caused confusion for me as I was trying to follow the directions.
I had to order some off amazon to be sure
Slickdall is offline
post #82 of 85 (permalink) Old 08-15-2019, 10:11 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
Did you get the thin one with multiple little rectangle pieces already pre-cut? And then 2 single piece slightly thicker 1mm pads? There should have been 3 types in all according to the manual.
EKWB Forum Rep
EKJake is offline
post #83 of 85 (permalink) Old 08-16-2019, 06:00 AM
SubZero is the Goal
HardheadedMurphy's Avatar
Rep: 73 (Unique: 63)
Quote: Originally Posted by Jedi Mind Trick View Post
I recommend unplugging the PSU from everything, hooking up just the pump to the PSU (with an adapter if necessary), and then starting it up with a paperclip or something (look for a pin out/see which pins need to be connected).
Personally, I have a old external 5.25" kit (sata/IDE to usb + small power supply with a single molex connector) that I use just for stuff like this. Saved my dumb self a few $$ more than once (got distilled water all over everything because sometimes I cannot think properly. Wound up air drying stuff for 24hrs a few times, but no computer for a day or two > no computer until having enough money to replace what died.
Personally, I took a cheap $20 psu I got off Amazon. Did a little modding ... I.e. snipped the power leads on the 24pin and soldered in a small switch with an extra 18" of wireing, then terminated everything but a single molex and sata cable. I use that as my watercooling test psu.
On a side note, you can also pick up a 24pin adapter that shorts the power lead for you allowing you to use power switch on psu, with adapter for 3 or 4 pin fan connecter you are golden.
Just my 2c
Sent from my OnePlus 7 Pro using Tapatalk
"It is impossible to defeat an ignorant man in an argument" McAdoo
Peace begins when we care about someone other than ourselves.
"Hell is still Overburdened, I must stand and wait in line" Disturbed
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
EVGA GeForce GTX 1080 FTW Hydro Copper GAMING, 08G-P4-6299-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
EVGA GeForce GTX 970 04G-P4-2974-KR 4GB SC GAMING w/ACX 2.0, Silent Cooling Graphics Card
Corsair Vengence RGB Pro
Mushkin Enhanced Source M.2 2280
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
Barrow RGB 115X CPU Block
EK-360 Radiator
Phobya 12v DC PWM Pump
Black Ice Nemisis 240mm stealth Rad
Alphacool 5.25 pump / resivoir combo DC-LT
Phobya Balancer 250mm Res - Black Nickle
Corsair Obsidian 900D
Operating System
Windows 7 Professional
LG 34" Ultrawide IPS 21:9
HP 27xw ips
HP 27xw IPS
Keyboard
Corsair Strafe RGB MX Silent
Mouse
Corsair M65 Pro RGB
Audio
Corsair Void Pro RGB
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Zotac Zbox CI320 Nano
Operating System
Win 10 Pro
HardheadedMurphy is offline
post #84 of 85 (permalink) Old 08-21-2019, 02:41 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
Just my 2c
I'm using a simple 12V PSU and soldered a molex on it. Works great to test my pumps.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #85 of 85 (permalink) Old 08-21-2019, 04:31 AM
SubZero is the Goal
Never thought of that lol
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
EK-360 Radiator
Operating System
HP 27xw ips
HP 27xw IPS
Keyboard
Mouse
Corsair M65 Pro RGB
Audio
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Operating System
Win 10 Pro
